Capture the world around you with our range of camera sensors. Whether it's for a Raspberry Pi, or simple surveillance system, we've got you covered.
Items 26-50 of 73
  1. Raspberry Pi Camera Board v2 - 8 Megapixels
    99% of 100
    SKU: CE04421 Brand: Raspberry Pi Guides (17)
    The Raspberry Pi Camera Module v2 is a high quality 8 megapixel, Sony camera module featuring a fixed focus lens designed for the Raspberry Pi. It's capable of 3280 x 2464 pixel static images, and also supports 1080p30, 720p60 and 640x480p60/90 video.
    33 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
    Delivered by Aug 15th
  2. Adafruit OV5640 Camera Breakout - 120 Degree Lens
    SKU: ADA5673 Brand: Adafruit
    Hobby-level microcontrollers are finally getting big and powerful enough to start handling camera modules that historically would have required a full...
    Available with 7 to 12 day lead time
  3. Arducam 5MP Plus OV5642 Mini Module Camera
    SKU: AC-B0068 Brand: Arducam
    Arducam-Mini-5MP-Plus(OV5642) is performance improved version compared to its predecessor Arducam-M-5MP.
    Available with 14 to 17 day lead time
  4. 4K 8MP IMX219 Autofocus USB Camera Module With Dual Microphone
    SKU: AC-B0292 Brand: Arducam
    This 8MP 4K Autofocus USB Camera is based on a 1/4” 8MP IMX219 image sensor, autofocus, UVC compliant USB 2.0 cameras.
    4 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  5. Arducam 2MP Global Shutter USB Camera Board (OV2311)
    SKU: AC-B0322 Brand: Arducam
    Shoot high-speed moving objects in crisp sharp images. Avoid the rolling artifacts to get a much more accurate complete picture than the rolling shutter cameras.
  6. OV9281 Monochrome Global Shutter 1MP Camera Module
    SKU: AC-B0411 Brand: Arducam
    Features best-in-class near-infrared (NIR), quantum efficiency (QE), and a V2-like form factor.
  7. 12MP IMX378 Camera Module
    SKU: AC-B0412 Brand: Arducam
    Based on Sony’s IMX378 high-quality image sensor, Arducam IMX378 camera module is a ready-to-use embedded vision solution for the Raspberry Pi.
    Special Price $59.20 AUD, inc GST
    Regular Price $69.65 AUD, inc GST
  8. 120fps Monochrome Global Shutter USB Camera
    SKU: AC-B0332 Brand: Arducam
    Arducam B0332 is a new member of the Arducam's USB camera family. It's a 1MP, based on the 1/4" monochrome global shutter OV9281 image sensor.
    13 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  9. 1080P HD Wide Angle WDR USB Camera Module
    SKU: AC-B0203 Brand: Arducam
    A 2MP, UVC compliant, wide angle, wide dynamic range camera
    $104.95 AUD, inc GST
    As low as $97.60 AUD, inc GST
  10. 16MP Autofocus USB Camera with Microphone
    SKU: AC-B0290 Brand: Arducam
    It is based on the 1/2.8" IMX298 image sensor, UVC-compliant, autofocus USB 2.0 camera and microphone.
    17 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  11. Arducam High Quality Camera, 12.3MP 1/2.3 Inch IMX477 HQ Camera Module
    SKU: AC-B0249 Brand: Arducam
    This High-Quality camera module for Jetson Nano/Xavier NX/Raspberry Pi.
    23 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  12. Arducam 2MP Ultra Low Light STARVIS IMX462 Motorized IR-CUT Camera
    SKU: AC-B0423 Brand: Arducam
    Arducam 2MP IMX462 Motorized IR-CUT Camera is capable of capturing visible and near-infrared images with very low noise even in extremely low-light conditions or no light (near 0 lux).
  13. Arducam Complete High Quality Camera Bundle for Jetson Nano/Xavier NX
    SKU: AC-B0250 Brand: Arducam
    This complete High-Quality camera bundle for Jetson Nano/Xavier NX is perfect for machine learning projects.
  14. ArduCAM USB3.0 Shield Plus: High-Speed Multi-Camera Control Board for PC & Embedded Systems
    SKU: AC-B0317 Brand: Arducam
    Explore the versatile ArduCAM USB3.0 Camera Shield Plus, a high-performance USB camera control board for PCs and embedded systems, supporting a wide range of camera modules up to 21MP, featuring advanced MIPI camera support and enhanced USB3.0 bandwidth for robust imaging solutions.
  15. 16MP IMX519 Autofocus Camera
    SKU: AC-B0371 Brand: Arducam
    A resolution of 16 megapixels (compared to 8MP and 12MP), an autofocus lens, and a V2-like form factor.
    8 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  16. Arducam IMX477 UVC Camera Adapter Board
    SKU: AC-B0278 Brand: Arducam
    Connect this camera adapter board to a PC, laptop, Android device, or Raspberry Pi via USB port to act as a webcam.
    18 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  17. ArduCam Mini Camera for Jetson Nano
    SKU: AC-B0251 Brand: Arducam
    This is a Arducam Mini High Quality Camera with M12 mount lens. Rated at 12.3MP 1/2.3″ 477P HQ for use with the Jetson Nano/Xavier NX/AGX Orin/Orin Nano/Orin NX
  18. ArduCam Global Shutter Color USB Camera
    SKU: AC-B0385 Brand: Arducam
    The ArduCam B0385 is a 1MP 120fps OV9782 USB 2.0 camera board. As it is UVC compliant, native drivers built into Windows, Mac, as well as most Linux distros work out of the box.
  19. Arducam 8MP IMX219 Auto Focus Camera Module
    SKU: AC-B0393 Brand: Arducam
    Raspberry Pi Camera: Designed for Raspberry Pi, this 8MP HD camera module has a Sony IMX219 8MP pixel sensor with an autofocus lens.
  20. IMX291 1080p Low-Light USB Wide-Angle Camera Module
    SKU: AC-B0202 Brand: Arducam
    This IMX291 is a 2MP CMOS USB camera with a pre-installed IR-filtering 160° wide-angle M12 lens
  21. ArduCam Mega 3MP Camera
    SKU: AC-B0400 Brand: Arducam
    The most versatile camera made for microcontrollers.
    9 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  22. Ultra Tiny USB Camera with GC0307 Sensor
    SKU: ADA5733 Brand: Adafruit
    This unbelievably small USB camera is great for embedded projects that have USB host support for standard UVC cameras, and not a lot of space. Sure you...
    6 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  23. OV5647 Optical Image Stabilization Camera Module for Raspberry Pi, 5MP
    SKU: WS-22980 Brand: Waveshare
    OV5647 Optical Image Stabilization Camera Module for Raspberry Pi, 5MP...
    Available with 9 to 12 day lead time
  24. PureThermal 3 - FLIR Lepton Smart I/O Board with Lepton FS
    SKU: DEV-20813 Brand: Sparkfun
    The PureThermal 3 FLIR Lepton Smart I/O Module is a hackable thermal webcam module for the FLIR Lepton Longwave Infrared (LWIR) camera core...
  25. OV5647-62 FOV Camera Module for Raspberry Pi
    SKU: SS114110127 Brand: Seeed Studio
    This camera module benefits from Fisheye Lens to achieve 62 Field of View, utilizing the OV5647 sensor to reach 2592 x 1944 active array size image show,...
