This camera module benefits from Fisheye Lens to achieve 62 Field of View, utilizing the OV5647 sensor to reach 2592 x 1944 active array size image show,...
This Arducam quadrascopic camera bundle incorporates four 16MP IMX519 autofocus cameras, and the cutting-edge MIPI stereo camera breakthrough from Arducam – The Arducam Camarray HAT.
Explore the Grove Vision AI V2 Kit, a powerful TinyML camera development platform featuring dual-core Arm Cortex-M55 and Ethos-U55 NPU for efficient edge AI processing, compatible with TensorFlow and PyTorch frameworks.
Discover the AtomS3R WiFi Camera Kit, a compact programmable controller featuring ESP32-S3, 0.3MP camera, 9-axis sensors, and 8MB FLASH/PSRAM, perfect for IoT monitoring and educational development.
Explore the AtomS3R IoT camera kit featuring ESP32-S3, 3MP OV3660 sensor, and built-in motion sensors - a compact programmable controller perfect for IoT monitoring, USB webcam applications, and embedded development projects.
Hobby-level microcontrollers are finally getting big and powerful enough to start handling camera modules that historically would have required a full...
Coming soon! Sign up to be notified when these are in stockHobby-level microcontrollers are finally getting big and powerful enough to start handling...
It is an MCU-based vision AI module powered by Arm Cortex-M55 & Ethos-U55. TensorFlow and PyTorch frameworks are supported. Compatible with Arduino IDE...
This long-wave IR thermal imaging camera uses a hybrid ofmicrobolometer technology and a 80x62 thermopile pixel array. It will detect the IR distribution of objects in the field of view, calculate the data into surface temperature, and then generate thermal images.
This OV5640 Camera for XIAO ESP32S3 Sense (With Heat Sink) offers a wide active array from 320*240 (QVGA) up to 2592*1944 (QSXGA). It has 8/10-bit RGB RAW...
Electronics products and services for Makers to Engineers. Fusion PCB manufacture, PCB Assembly, CNC milling services and more. Affordable and reliable....
The Gravity: Huskylens AI Vision Sensor is an easy-to-use camera and vision sensor that brings sophisticated artificial intelligence capabilities to your...
Website features/issues
Content errors/improvements
Missing products/categories
Product assignments to categories
Search results relevance
