Items 26-50 of 56
  1. HDMI 4K Switcher, 3 In 1 Out, One-Click Switch
    SKU: WS-23120 Brand: Waveshare
    HDMI 4K Switcher, 3 In 1 Out, One-Click Switch...
    Delivered by Jul 22nd
  2. PCIe TO 4-Ch SATA 3.0 Expander, 6Gpbs High-speed SATA Interface, Supports CM4
    SKU: WS-22247 Brand: Waveshare
    PCIe TO 4-Ch SATA 3.0 Expander, 6Gpbs High-speed SATA Interface, Supports CM4...
    Available with 9 to 12 day lead time
  3. Industrial USB Switch (4 to 2 Selectable USB Ports, External power supply)
    SKU: WS-23062 Brand: Waveshare
    Industrial Grade USB HUB, Extending 4x USB 2.0 Ports, Switchable Dual Hosts...
    3 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  4. Satechi USB-C NVME/SATA SSD Enclosure
    SKU: CE09173
    This tool-free NVMe SSD enclosure can easily connect an M.2 NMVe SSDs or M.2 SATA SSDs with your computer to expand storage, upgrade the system, back up...
    Available with 4 to 6 day lead time
  5. Industrial USB Hub (3 Port HUB with Ethernet Interface)
    SKU: WS-23064 Brand: Waveshare
    Industrial Grade Multifunctional USB HUB, Extending 3x USB ports + 100M Ethernet Port...
    4 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  6. Ultraleap 3Di Stereo Hand Tracking Camera
    SKU: ADA5571 Brand: Adafruit
    The Ultraleap 3Di Stereo Hand Tracking Camera is designed to be connected to an interactive screen. Together with Ultraleap’s world-leading...
  7. Leap Motion Controller with SDK
    SKU: ADA2106 Brand: Adafruit
    The Leap Motion Controller is a fascinating new computer sensor that uses multiple cameras and IR light to detect motion in a 3D space. It tracks both hands and...
  8. EEPROM Data Storage Module For Arduino
    SKU: DFR0117 Brand: DFRobot
    If you want more storage for your Arduino project, this module is designed for you. This EEPROM data storage module supplies an extra 32k byte for your project. Simply wired them via I2C.
    1 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  9. Waveshare 7inch LCD IPS 1024×600
    97% of 100
    SKU: WS-11199 Brand: Waveshare
    This 7inch IPS display is a perfect option for a portable Raspberry Pi setup with HDMI input, USB power, capacitive touch and 1024x600 resolution.
    11 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  10. 8BitDo SN30 Pro Bluetooth Gamepad (G Classic Edition)
    SKU: CE05642 Brand: 8Bitdo
    This Retro GamePad from 8BitDo resembles one of our favorite Retro Gaming controllers, and feels exactly like it. The team over at 8BitDo have put countless hours into the finest details of their Retro Gaming Controllers to deliver an incredibly authetic experience, with the size of the controller, button feedback and even the D-Pad feels right!
  11. USB 3.0 Capture Card
    SKU: WS-24211 Brand: Waveshare
    USB Port High Definition HDMI Video Capture Card, For Gaming / Streaming / Cameras, HDMI To USB...
  12. HDMI Splitter 1x4
    SKU: CE09615 Brand: Core Electronics
    Split your HDMI output to 4 screens or monitors.
    $10.70 AUD, inc GST
    As low as $7.81 AUD, inc GST
    13 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  13. HDMI Splitter - 1:2
    SKU: CE09616 Brand: Core Electronics
    Split your HDMI output to 2 screens or monitors.
  14. HDMI Switch - 3:1
    SKU: CE09617 Brand: Core Electronics
    Seamlessly switch between 3 different HDMI outputs!
    43 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  15. HDMI Switch - 5:1
    SKU: CE09618 Brand: Core Electronics
    Seamlessly switch between 5 different HDMI outputs!
    $28.46 AUD, inc GST
    16 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  16. HDMI Matrix - 4:2
    SKU: CE09619 Brand: Core Electronics
    Explore the HDMI Matrix 4:2; a versatile switch offering 4 HDMI inputs and 2 outputs for a streamlined multimedia setup. Ideal for hobbyists and tech enthusiasts, this compact solution supports seamless device management without the need for additional software.
  17. SSD to USB Adapter (2 pack)
    SKU: AC-U6193 Brand: UCTRONICS
    These SATA to USB 3.0 cables can help you expand the functions of your Raspberry Pi or upgrade the hard drive in your laptop by adding external SSDs.
    20 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  18. HP 32GB MicroSD (Class 10)
    SKU: CE09737 Brand: Core Electronics
    A microSD card perfect for storing a Raspberry Pi image or capturing video
    12 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  19. 10mm x 5m Hook and Loop Tape
    SKU: CE09749 Brand: Core Electronics
    Secure wires, sensors or modules in style, and reusable!
  20. Leap Motion Controller 2 - The Leap2
    SKU: ADA5758 Brand: Adafruit
    The second generation of Ultraleap's iconic hand-tracking camera allows you to use your own hands in digital worlds.
  21. Bonelk Long-Life USB-C to 4 Port USB 3.0 Slim Hub (Space Grey)
    SKU: CE07936
    The Bonelk USB-C hub is a great solution to connect up to 4 additional USB-A high speed devices to your laptop, smart device or desktop computer. Built...
  22. Ctrl C/V Shortcut Keyboard For Makers
    SKU: WS-26464 Brand: Waveshare
    Ctrl C/V Shortcut Keyboard For Programmers, 3-Key Development Board, Adopts RP2040 Microcontroller Chip, Programmable Key Function, Dual Type-C Ports,...
  23. Qwiic USB Development Kit - SAMD21
    SKU: SPX-24639 Brand: Sparkfun
    A USB development board for the SparkFun Qwiic system...
    Available with 5 to 8 day lead time
  24. 2.5" SATA III to USB 3.0 Adapter Cable - 30cm long
    SKU: ADA5622 Brand: Adafruit
    This 2.5" SATA III to USB 3.0 Adapter Cable allows you to connect a standard 2.5" hard drive (HDD or SSD) to your computer. SATA III is like, a...
    Available with 7 to 12 day lead time
  25. USB 3.0 Type A to Type C 1m
    SKU: CE09934 Brand: Core Electronics
    Connect all of your USB-C devices with this handy cable!
    226 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
Enhance your home lab with PC power-ups, including Raspberry Pi Compute Module 4, Makedo tools, motion sensors, and various breakout boards for endless project possibilities.
