Items 51-57 of 57
  1. USB 3.0 Type A to Type C 1m
    SKU: CE09934 Brand: Core Electronics
    Connect all of your USB-C devices with this handy cable!
    17 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
    Delivered by Apr 3rd
  2. USB 3.0 Cable Type-C to Type-C (1m)
    SKU: CE09935 Brand: Core Electronics
    95 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  3. Raspberry Pi USB 3.0 Hub
    SKU: CE09941 Brand: Raspberry Pi
    Need more USB ports? This handy accessory turns one USB-A port into four!
    157 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  4. USB TO 2.5G Ethernet Port Converter
    SKU: WS-27688 Brand: Waveshare
    USB TO 2.5G Ethernet Port Converter, High-Speed Networking, Driver-Free, Windows / macOS / Linux / Android Multi-system Support, 2.5G USB Ethernet Adapter...
    Available with 9 to 12 day lead time
  5. Upcycled 3.5" Floppy Drive - Sony MPF-920 or Compatible
    SKU: ADA6037 Brand: Adafruit
    Before SSDs or USB keys or email attachments or SD cards or even CD-ROMs, there was the mighty floppy disk! These lil guys could store about a megabyte or...
    Available with 8 to 12 day lead time
  6. PiKVM Switch Multiport Extender
    SKU: CE10137 Brand: HiPi.io
    This allows a single KVM to control and monitor multiple computers.
    Available with 20 to 30 day lead time
  7. HDMI Dummy Plug
    SKU: CE10160 Brand: Core Electronics
    The solution for seamless virtual display emulation.
    $6.60 AUD, inc GST
    50 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
Enhance your home lab with PC power-ups, including Raspberry Pi Compute Module 4, Makedo tools, motion sensors, and various breakout boards for endless project possibilities.
