Raspberry Pi tutorials served straight up from the creative team at Core Electronics. We cover a range of uses from software through to hardware. We're here to help as well, technical support on our forum and sales support via 02 4058 2818
This is a quick crash course on how to set up, use, and change virtual environments in Thonny on a Raspberry Pi.
In late 2023 Bookworm OS for the Raspberry Pi rolled out and this new OS restricted the ability to install externally managed...
The Raspberry Pi 5 was announced just a few weeks ago and across the internet, we have seen some recurring questions, so in this article, we tried our best to answer some of them.
Contents:
Overclocking Questions
Cooling Quest...
Contents:
Cooling Quest...
The Raspberry Pi 5 is here and one of the biggest questions is, how does it stack up against the previous Pi 4? Well, we already have one to take a look at so let’s run some benchmarks and compare the two.(We also have another articl...
The Raspberry Pi 5 is here! Our favourite credit card-sized computer has just gotten an update and we already have one here to take a look at, so let’s power it up, run some tests, and see what’s new!
(If you want to s...
It is time for an Airplane Tracking Raspberry Pi! The final setup here will let you personally collect data on the exact whereabouts of airplanes over 400km away. It will update one to four times each minute. Be passenger planes, cargo air...
Welcome to the best article on setting up an OpenMediaVault-based NAS on a Raspberry Pi Single Board Computer! This guide is the fastest and best way to go about it. Raspberry Pi single-board computers are purpose-built to run 24/7, with a...
What if I told you that you could have the power to detect a lightning strike from 40km away? You'd probably think I've gone mad watching too many Marvel movies. But it is true! All thanks to the DFRobot Gravity: Lightning Sensor. Accessib...
Force-sensitive resistors (FSR) are remarkable electrical components and are proper unsung heroes in the Makers World. Name me a better variable touch input device which has basically no moving parts, all whilst being available in such a t...
Let's unlock Biometric Control on our Raspberry Pi Single Board Computers! Biometric Technology uses unique physical or behavioral attributes that are individual to each person and not (easily) replicable. Extraordinarily everyone on Earth...
This guide will demonstrate exactly how to control any large DC Motors that we stock with a Raspberry Pi Single Board Computer, through code or through a Bluetooth Controller. To clarify (in my mind) a large DC Motors runs at 12+ Volt...
This is an update to an older guide done so that we can provide you with the fastest, most modern, and best way to set up your system.
Nothing beats bright shiny colourful lights and this guide demonstrates the fastest and most customizab...
Time to create a Little Red Advertisement Devouring Monster. This will be a self-hosted, network-wide, ad-blocking system running on a Raspberry Pi Single Board Computer. It will also stop access to malware sites and phishing websites. Fur...
This guide will teach you exactly how to use a Raspberry Pi Single Board Computer to independently control 4 relays. A Relay is an electrically operated switch. This is all possible thanks to the PiRelay V2 HAT from SB Components. These re...
This guide will demonstrate exactly how to control Standard Stepper Motors and DC Motors with a Raspberry Pi Single-Board Computer. To do this as seamlessly as possible we will utilise a HAT. HAT stands for Hardware Attached on Top. HAT bo...
If you ever needed a performance boost when running Machine Learnt AI Systems (like facial recognition) with a Raspberry Pi Single Board Computer then I have a solution for you. The OAK-D Lite. The Oak-D Lite is the Leatherman Multi-tool o...
Geophones are devices that generate electric signals proportional to the particle velocity in a sound/compression wave. More simply a Geophone is a super low frequency microphone for the ground. Geophones are used around the world to measu...
Love your Raspberry Pi but wish it had even more connectivity akin to your mobile phone. Then the Waveshare 4G HAT is the solution for you! HAT simply means Hardware attached On Top. With this installed on your Raspberry Pi Single Board Co...
It is time for a high-quality, complete package, 1920x1200 (HD) display set up with a Raspberry Pi Single-Board Computer. In regards to touch screens with Raspberry Pi have looked at Tiny GPIO HAT LCD displays, medium-sized AMOLED maker di...
This will be a quick 101 on how to use the Raspberry Pi Imager so that you can Flash a new Micro-SD Card. Everything you need to use this Software will be found in this article. The contents of this guide can be seen below.
- Download Loc...
- Download Loc...
It has finally happened, they figured it out! The new frontier of Colour Electronic Paper is here and I'm very impressed. People have been demanding this ever since the first E-Paper readers hit the market in the noughties. That black and ...
Flawless high-quality audio output on a Raspberry Pi Single Board Computer! All is achieved by the IQaudio DAC+ HAT. This dedicated DAC lets you enjoy high-quality, distortion-free, artifact-free, low noise, and high-bitrate audio playback...
Radio Frequency IDentification (RFID) uses electromagnetic fields to identify and communicate with tags. Each RFID module emits radio waves that energise the passive tag, which then responds with its own identifying number or data, as reque...
Let's get started with the PiicoDev® Magnetometer. In this guide we'll connect the Magnetometer to our Raspberry Pi, get it working as a compass, and read the magnetic field strength of a nearby magnet. Finally, we'll remix the code to ...
Ever wanted a pocket computer with a Full HD screen (1080x1920)? Love tiny GPIO screens like this 3.5 Inch from Waveshare but want one that is a little bigger and higher resolution so that it is easier to read? Or want a really premi...
While the Raspberry Pi Compute Module 4s (CM4s) share a lot with the regular Pi 4 Model B, getting started with the flashing process can be quite different depending on which model you pick! This article aims to demystify that, so without f...
This guide covers the configuration steps required to use the Makerverse Supercap Real Time Clock module as a backup RTC on a Raspberry Pi. This is required for remote applications when Internet access is impractical and accur...
[Update – Until there is correct compatibility of OPEN-CV with the new Raspberry Pi ‘Bullseye’ OS I highly recommend at this stage flashing and using the previous Raspberry Pi ‘Buster’ OS onto yo...
This guide will teach you how to control up to 992 5V Servos through the GPIO pins on your Raspberry Pi! But more practically, without stacking multiple HATS (Hardware Attached on Top), this guide will teach exactly how to control sixt...
[Update – Until there is correct compatibility of OPEN-CV with the new Raspberry Pi ‘Bullseye’ OS I highly recommend at this stage flashing and using the previous Raspberry Pi ‘Buster’ OS onto y...
This will be a quick article showing the process to flash the legacy Raspberry Pi OS 'Buster' Debian 10 (or any previous OS iteration) to a Micro-SD card. With any exciting new Operating System (OS) release, there are always small ...
Let's play tones and melodies on a PiicoDev® Buzzer Module with a Raspberry Pi. This guide will cover connecting the hardware, running an example to make sure everything works, and playing simple melodies.
To follow along...
To follow along...
With the newest update to Raspberry Pi OS (Debian Version 11 - nicknamed ‘Bullseye’) there have been some changes to the terminal commands which control attached cameras. This is one of the biggest changes with the new up...
Let's get started with the PiicoDev® 3x RGB LED Module. In this guide, we'll connect the LED Module to our Raspberry Pi Pico and get it working with some example code to display colourful patterns.
To follow along, it's best to ...
Let's read colour data from a PiicoDev® Colour Sensor with a Raspberry Pi and create a colour sorting machine. This guide will cover connecting the hardware, downloading some example code and remixing it.
To follow along,...
To follow along,...
Let's get started with the PiicoDev® OLED Module SSD1306. In this guide, we'll connect the PiicoDev OLED to our Raspberry Pi and get it working with some example code to display text, shapes, and animations.
To follo...
To follo...
Near Field Communication (NFC) is used all and everywhere. As it stands there are over two billion NFC-enabled devices (many of them smartphones) in use today. This basically means over 20% of the world’s population has access t...
[Update – Until there is correct compatibility of OPEN-CV with the new Raspberry Pi ‘Bullseye’ OS I highly recommend at this stage flashing and using the previous Raspberry Pi ‘Buster’ OS ...
Pimironi Picade Pan-Tilt Hat lets you mount and control a pan-tilt module right on top of your Raspberry Pi palm-sized computer. Setting up a Pan and Tilt system has never been easier with absolutely no soldering required! Pe...
Let's get started with the PiicoDev® Capacitive Touch Sensor. In this guide, we'll connect the PiicoDev Capacitive Touch Sensor to our Raspberry Pi and get it working with some example code to detect touch events. We'll also remix the c...
Here is a solution so you can turn your Raspberry Pi handheld computer on and off from the power plug (power cycle it) just like any other appliance in your home! And it can all be done through only one setting.
With a normally set-up Rasp...
[Update – Until there is correct compatibility of OPEN-CV with the new Raspberry Pi ‘Bullseye’ OS I highly recommend at this stage flashing and using the previous Raspberry Pi ‘Buster’ OS onto your Mi...
There is a whole range of Sub-4 Inch Displays that attach directly to the GPIO pins of Raspberry Pi Palm-Sized Computers. Many of them are touch devices and increase the usability of your Raspberry Pi whilst making almost no size sacrifices...
This guide will help you read barometric pressure data from your PiicoDev® Pressure Sensor with a Raspberry Pi single-board computer.
A Raspberry Pi (model 3, 4, Zero or Zero W)...
[Note - Terminal Commands talked about here have been superseded with the new 'Bullseye' Raspberry Pi OS. Link here for new 'Bullseye' camera commands.
If you want to use the commands found on this page download and flash the old 'Bu...
All Argon ONE Cases for the Raspberry Pi 4 Model B have formidable feature sets, with my personal favourite feature being a safe On and Off button. Once the Pi has been installed to the case you can obtain full On and Off functionality...
There are so many types of cameras modules and lenses that are plug-and-play for Raspberry Pi Single Board Computers and that number is steadily increasing. From day to night, you can keep track, photograph, and record your surrou...
This guide will help you read temperature data from your PiicoDev® Precision Temperature Sensor and a Raspberry Pi single-board computer
A Raspberry Pi (model 3, 4, Zero or Zer...
This guide will teach you how to control any small and big servos with a Raspberry Pi 4 Model B (worth noting any Raspberry Pi Board with GPIO pins can be able to be used in this scenario. Servos are an immensely useful way to turn ele...
Here is how to control a 12 Volt Solenoid with a Raspberry Pi using a 5 Volt Relay. Solenoids are an immensely useful way to turn electrical energy into a linear motion. Solenoids come in a variety of different specifications with 5 Volt an...
Break your television and monitors free from the confines of their edges with Hyperbian! This is an open-source ambient light software that will improve the way you enjoy your favourite media.
Hyperion for the Raspberry Pi ∴ Hy...
This guide will help you read weather data from your PiicoDev® Atmospheric Sensor and a Raspberry Pi single-board computer
A Raspberry Pi (model 3, 4, Zero ...
This guide will help you read distance data from your PiicoDev® Distance Sensor and a Raspberry Pi single-board computer
A Raspberry Pi (model 3, 4, Zero W) This tutorial will u...
This guide will help you read light intensity data from your PiicoDev® Ambient Light Sensor and a Raspberry Pi single-board computer
A Raspberry Pi (model 3, 4, Zero W) This tut...
Raspberry Pi Boards are a great gateway for learning about how to get to grips with computers, at a price that makes it hugely accessible and a size that fits right in your hand. Raspberry Pi boards are chock a block full of features a...
There are many different ways to use your mobile phone to remotely control and manage any Raspberry Pi and one of the best options out there to date is the phone application RaspController (you can also find it for free in the Google P...
This is going to be easier than you thought (or at least much easier than I thought)! Today we will create a Raspberry Pi 4 Model B UPS PiJuice System that will be completely powered by a Solar Panel. It's coming up to winter over here so I...
Now I'm not talking about a delivery service - I'm talking about an Uninterruptable Power Supply for your Raspberry Pi 4.
So if your Raspberry Pi project needs to be powered all the time relying solely on the mains power system may leave y...
[Update 18-02-2021 - Made a Vesa Mount for the Argon One M.2 Case as well so nobody missed out]
A quicky article for those who have their Raspberry Pi 4 Model B all tucked in snug by the very stylish Argon One Case but wish they could...
You ever wanted an Ad-Free and Bloatware Free Media Streaming Device that can run 4K movies with clean audio that transforms any Screen into a Smart TV. Sounds almost too good to be true but Raspberry Pi, Kodi and LibreELEC OS have swooped ...
[Update: The OMXPlayer system, needed for the video looper, has been dropped with the recent 'Bullseye' Raspberry Pi OS. Updates are coming out fast and all the teething troubles from this new OS will be ironed out.
For now, download and f...
Being productive and efficient on a computer has become synonymous with dual-screens. Being able to run two application and have both take up a whole screen or run four text documents each taking up an A4 sized half screen really improves e...
After the release of the Raspberry Pi 4 Model B 1 GB and 2GB and 4GB generations there was a design revision. Now if you have any other Raspberry Pi board in your hand the impact of this design revision will not affect you. If you happen to...
Raspberry Pi Compute Modules have developed in tandem with the many generations of Raspberry Pi single-board computers. These boards are in every right a microprocessor just like their bigger cousins however they are a very different form f...
It is long overdue. Time for a table with all the info comparing every generation and style of Raspberry Pi from the genesis to now! We have come a long way to have our hands on the Raspberry Pi 4 Model B 8 GB so it is time we give you the ...
The ONESIE family of cases come in three distinct models; Stealth, Maker and Hats. This will be a guide introducing the ONESIE family, the 3D printable monocoque stealth cases for Raspberry Pi 4 Model B, talk about what makes them di...
The Raspberry Pi as we know it today is just the “tip of the iceberg”, the product of more than a decade of development, spanning 4 generations with up-to 18 boards and counting released so far. Alongside this development, there...
If you've had issues getting your Raspberry Pi 4 to work with specific HDMI displays (monitors, TV's etc.) this tutorial has got you covered! It's a quick fix that just requires a bit of tinkering in the config.txt file that's present on al...
Ubuntu 19.10 was recently released on 17 October 2019 and is powered by the all-new GNOME 3.34 and version 5.3 of the Linux kernel.
This is for the benefit of users who do not know about Ubuntu! If you already know what is Ubuntu and its...
First of all, why subject your Raspberry Pi to this level of stress? In the case of Raspberry Pi 4, the A72 CPU is so powerful that it can overheat if it doesn't have enough cooling. This results with the CPU being governed (slowed do...
To update software in Raspbian, you can use the apt tool in a terminal. Open a terminal window from the taskbar or application menu:
First, update your system's package list by entering the following command:
Nex...
Nex...
The New Version of the Raspberry Pi 4 has started going out to makers everywhere. If you are wanting to upgrade your old RPi3 project to take advantage of all the cool new features there are a few steps we are going to have to take first to...
The Raspberry Pi 4 Model B is finally here! This is a huge leap forward for single-board computing and what better way to explore it than power one up, run some tests and stress it out!
Here are the test results for those peopl...
There is a new board in the Raspberry Pi family!
In this Tutorial, we will walk you through the steps to set up your new Raspberry Pi 3 Model A+.To setup your Raspberry Pi 3A+ you will need:
A Raspberry Pi 3A+
A Preloaded NOOBS SD Card...
A Raspberry Pi 3A+
So you've got your Raspberry Pi 3 Model A and need a case to house it in. In this short guide we're going to step through the considerations you should take when designing your own case, as well as provide you with all the files you need t...
Sometimes a good Raspberry Pi project needs to be in a place that just hard to reach. The Raspberry Pi 3 Model A+ has a small form factor and is well suited for being tucked away inside a box, ceiling, or wherever your project demands. It...
There is a new Raspberry Pi! The long-awaited upgrade to the Rasberry Pi 1 Model A+ (Rpi1 A+). In this article, we are going to look at how much improvement the new Raspberry Pi 3 Model A+ (Rpi3 A+) is over the Rpi1 A+ as well as how ...
To get your Raspberry Pi working, you'll need an SD card with a working operating system written to it.
While NOOBs (New Out of Box Software) is a great headstart into the world of Raspberry Pi operating systems. It comes preloaded with Ra...
A big project request for the Raspberry Pi is the ability to make a digital sign, that loops images/videos/other media fullscreen with no interactivity. This can be a great way to display dashboards, promotional videos and other media. For ...
What is Node-RED?
Node-RED is a tool originally created by IBM for flow-based programming, and has built-in support for the Raspberry Pi and it's GPIO capabilities. It runs on top of Node.js, and can be accessed with just a web browse...
What is Node-RED?
In this tutorial, we are going to connect a Motor to the Raspberry Pi and create a hypnotic self-spinner. We are first going to look at how to wire the Raspberry Pi to the motor controller and the motor. We will then look at using the raspb...
Pulling the power to your Raspberry Pi can cause image corruptions & other issues that can damage your Pi! In this article, we will create a small push button that will work as a ‘Safe-Shutdown’ option. We’ll connect i...
The Raspberry Pi 3 Model B+ (I’ll be calling it the Pi 3+ for short) is an update to the existing Raspberry Pi 3 Model B and was released on Wednesday 14th March 2018. It has some very interesting changes:
The Broadcom BCM2837 has ...
Like many things in the Raspberry Pi ecosystem, functions such as rotating the display output can be a little unintuitive at first. Or perhaps you’re not sure how to get rid of that annoying black outline on your screen. So, we’...
--- NEW UPDATED GUIDE CLICK HERE ---This tutorial is aimed at getting some instant gratification from your WS2812 LEDs (also known as NeoPixels). We'll briefly cover a bare-bones setup for Raspberry Pi. This tutorial will work with ANY mod...
Running a virtual Raspberry Pi on your computer can be a neat way to experiment in a Raspbian-like environment without being tethered to a physical Pi. In this video, I'll walk you through the process of installing Raspberry Pi Desktop on a...
The Raspberry Pi is an amazing piece of technology, and it’s the platform of choice for all kinds of projects. Something that makes it great is the integration of complex hardware that is taken care of for you. For example, if you wan...
The Pimoroni Unicorn HAT lets you add 64 dazzling RGB LEDs to your Raspberry Pi, and makes for a sickeningly colourful display. I'll show you how to get yours set up, and we'll have a go at modifying an example script.
This tutorial i...
This tutorial i...
After lovingly crafting your project on a Raspberry Pi, you might want to share it with the world. The easiest way is of course just to publish a list of the commands that you executed to get everything up and running. For complex proj...
Let's have a very quick look at Git and Github - Git is an enormous topic, so this won't be an exhaustive tutorial but by the end of it we'll have a working knowledge of basic git workflow.
I'll be showing this tutorial on a Rasp...
Not quite sure how to get started with your Pimoroni Blinkt module? Let's set one up and have a play around! We'll guide you through the installation, open up some examples and try our hand at writing a simple program.
You'll need:
A Ra...
You'll need:
A Ra...
So what does it mean to run headless?A computer setup without a monitor is said to be running headless. You might want to do this if you're installing your Pi into some project, or want to keep power-usage and cost minimal. This kind of se...
Who should follow this tutorial?
If this is your first experience with Raspberry Pi, and you're using a starter kit for a Raspberry Pi Zero W, then this tutorial is for you. We'll plug everything into where it needs to be, install an ...
If you’ve ever pulled an SD card out of a Raspberry Pi and attempted to re-flash it with another disk image, you may have noticed something funny…
"My X Gigabyte SD card has shrunk to a few megabytes! What gives?" No, your S...
In this tutorial we'll be writing our first bash script for Raspberry Pi. We'll create a directory to keep this and future scripts, write the actual script, and set it up as something that can be executed from the shell.
Scripts are an inc...
In this tutorial we’ll be getting familiar with basic use of the Raspberry Pi terminal. We’ll cover navigating the file-system, making directories, writing and editing text files, and just touch on the use of wildcards.
To get ...
To get ...
What is MQTT?
MQTT (Message Queue Telemetry Transport) is a simple and ‘lightweight’ way for internet-connected devices to send each other messages. This is important for home-automation because devices need to send messag...
What is MQTT?
UPDATE: This tutorial has been updated for the Krypton release of Kodi (Version 17)
If you have built yourself a home media center using a Raspberry Pi, you're one step ahead of most people out there. The pure joy that comes from having a ...
A new day is upon us, and it is glorious. After all, it’s not often that a new Raspberry Pi board is released. As you’re probably aware, the current iteration of the popular Raspberry Pi microcomputer is the Raspberry Pi 3. It h...
How many young people are able to assemble a computer, from scratch? Sure, adults can do it. There are even IT professionals and avid PC enthusiasts that take it to the next level; customizing everything down to the color of the Power LED a...
Part of the joy that is Raspberry Pi is getting stuck into it at a slightly lower level and finding out exactly what you can do with it if you take a look under the hood. One of the most popular experiments to do with your Raspber...
We have a more recent guide to Stress testing your Raspberry Pi, this guide has been kept here for reference.
Part of the joy that is Raspberry Pi is getting stuck into it at a slightly lower level and finding out exactly what yo...
Part of the joy that is Raspberry Pi is getting stuck into it at a slightly lower level and finding out exactly what you can do with it if you take a look under the hood. One of the most popular experiments to do with your Raspberry Pi is o...
This tutorial works great for Raspberry Pi 3 Model B, however if you need a Video Kiosk/Digital Sign for the newer Pi Models, we've written this guide on how to do it.
One of the most requested projects for Raspberry Pi is how to set ...
What fun would a computer be without a screen to see what you’re doing? Well if you own a Raspberry Pi and are curious about the different ways you can connect an external display or monitor up to it, then look no further. Today we&rs...
8Bitdo controllers are the best retro-gaming controllers you can buy. You could pick one up for your RetroPie gaming system so you can relax back on your lounge with your wireless gaming controller. We did a great write up on the process of...
Ah, what a glorious time we live in, where we have to compare which micro-computer is going to best suit our needs. If you’ve been in the maker sphere for just a short time, you’ll be sure to have heard of Raspberry Pi the mirac...
Show of hands, who loves Raspberry Pi? We all do, and one of the most common questions we get asked is which Raspberry Pi kit is going to best suit my project, which one has the right components in it etc. So today we’re going to be l...
What’s even better than the world’s most popular microcomputer sitting on your desk? When it’s sitting there in a case which protects it, makes it easier to use, and gives your desk some style.
If you buy a Raspberry Pi i...
So you’ve got your Raspberry Pi, you’ve got your sensors and external components and you’re ready to build a world-conquering robot beyond compare. But hang on a minute, the sensor you have only operates on 5V and you vagu...
I SPI with my Raspberry Pi, something beginning with…S! Serial-Peripheral-Interface (SPI)! Welcome to our Raspberry Pi SPI communication tutorial. Today we’re going to look at how to use the SPI bus on our Raspberry Pi ...
Media centres are everywhere nowadays, from smart TV’s with built in media apps, to standalone lounge room boxes to watch all your favourite shows on. With the new features found on the Raspberry Pi 3, it makes sense for it to become...
Raspberry Pi right? It’s amazing! Raspberry Pi has taken the world by storm and changed the way that people think about computing. The Raspberry Pi 3 builds on this with some amazing new features, however one feature that is still ab...
Ever thought it would be cool if your Raspberry Pi could see the world like you do? You’re in luck, camera support is an integral part of the Raspberry Pi hardware, it comes with a built in CSI connector for connecting camera ...
Hello there, how’s your day been? Good? Fantastic! Not so good? Don’t worry it’s about to get a lot better, because today we’re going to take a look at how to use the I2C interface on our Raspberry Pi to control I2C ...
Is it hot in here, or is it just my Raspberry Pi? A Raspberry Pi sitting on a desk doing nothing is kind of boring. However, a Raspberry Pi that can measure the temperature and make decisions based off that information is awesome!
The Rasp...
The Rasp...
Yep, Raspberry Pi is a very cool platform, so cool that they offer a range of stylish HATs to go with them. No not headwear, but fully functional hardware modules that are designed to plugin directly to the Raspberry Pi GPIO headers, and op...
Hi there! If you’re wondering what all the hype and interest surrounding Raspberry Pi is about, you’ve come to the right place.
The original Raspberry Pi debuted in 2012, and is a credit card sized computer that has ports for U...
So you’ve got your Raspberry Pi. You’ve gotten NOOBS setup on it, explored Raspbian a bit, and you’re feeling like a bit of a pro. Awesome! Now let’s get down to the nitty gritty side of things, what it’s ...
NOOBS has made installing Operating Systems (OS) on the Raspberry a super simple process. If you haven’t purchased a Raspberry Pi NOOBS MicroSD card, you can download NOOBS onto a blank SD card in a couple of quick, easy steps.
Today we’re going to take a look at how to get started and setup that fancy Raspberry Pi you’ve just bought. If you’re still not sure exactly how the Raspberry Pi works, or what it can do, check out ‘What is a Ra...
The Raspberry Pi has revolutionized the world of single-board computers, offering a platform for learners, hobbyists, and professionals to explore, create, and innovate. From its inception, the Raspberry Pi series has been a beacon of techn...
Welcome to our tutorial for using NOOBS (New-Out-Of-Box-Software) to install an OS (Operating System) for use with your Raspberry Pi. The NOOBS package includes access to seven popular Operating Systems:
Raspbian
Windows ...
Raspbian
Windows ...
Today we’re going to look at installing the Windows 10 IoT (Internet of Things) core onto a Raspberry Pi 3.
Traditionally Windows has been the resident overlord of desktop devices, however in recent years we’ve seen it t...
Website features/issues
Content errors/improvements
Missing products/categories
Search results relevance
