PiicoDev Magnetometer QMC6310 - Guide for Raspberry Pi
Updated 13 January 2025
This guide is for the previous revision of the PiicoDev Magnetometer QMC6310 - if you have the latest revision featuring the MMC5603 - head to the guide for updated links and instructions.
Let's get started with the PiicoDev® Magnetometer. In this guide we'll connect the Magnetometer to our Raspberry Pi, get it working as a compass, and read the magnetic field strength of a nearby magnet. Finally, we'll remix the code to create a graphical compass display.
If you prefer not to use the PiicoDev Adapter for Raspberry Pi, there are other connection options in our PiicoDev Connection Guide.
If you haven't set up a Raspberry Pi to be used like a desktop computer before, head over to our Raspberry Pi Workshop for Beginners to get started.
Connect the Magnetometer to your Pi
Mount the PiicoDev® Adapter on your Raspberry Pi and plug connect your Magnetometer to the Adapter via the PiicoDev cable.
The adapter connects to the 40-pin GPIO header on the Raspberry Pi -  ensure the header is mounted correctly, with the "Ethernet" label on the same side as the Pi's ethernet adapter (for a Pi 4. On a Pi 3 this will be the USB connector).
connect-magnetometer-qcm6310-piicodev-sensor-to-raspberry-pi
Pictured above: A Raspberry Pi 4 Model B with USB Power and HDMI (two white leads). The PiicoDev Adapter is placed on the 40-pin header, and connects to the weather sensor with a PiicoDev Cable.
Enable I2C
raspberry-pi-enable-i2c
Install PiicoDev
Example 1 - Compass and Calibration
In this first example, we'll calibrate the magnetometer and use it like a magnetic compass.
Download the example script: compass.py (right-click, "save link as"). Save this somewhere you can find it - like a "PiicoDev" directory in your home directory.
Open main.py in Thonny and run the script (click the Green Play Button, or Ctrl+R). You will be prompted to calibrate the magnetometer: Slowly rotate the sensor on a flat surface until calibration is complete. You can see the calibration progress shown by a progress bar in the shell.
piicodev-magnetometer-qmc6310-calibration
Once calibration is complete, your Pi will begin printing the measured heading into the shell. This is the same heading that you would read off a magnetic compass. The heading is the direction the top edge (with the PiicoDev label) of the module is pointing when placed on a level surface like a table.
piicodev-magnetometer-qmc6310-heading-example
piicodev-magnetometer-qmc6310-heading-compare
You may notice a new file named calibration.cal has appeared on your Pi - this is the calibration data. This calibration data will be automatically loaded every time the script runs, so you can comment-out compass.calibrate() if you don't want to calibrate on every power-up. It's still a good idea to calibrate periodically, or if you notice your heading has drifted.
Remix - True North
So far we have been working with Magnetic North - this is the direction a magnetic compass will point. To find a true heading, we need to input some more information. Magnetic Declination is the difference between Magnetic North and True North (or "Geographic North"). The value for declination changes depending on location. In Newcastle, Australia, the declination is about 12° (as of 2022). There are lots of online tools that will help you find the declination in your area (here's one example). Once you know the declination in your area, you can input that angle into the setDeclination() function. Re-run your script and you should notice the heading data has been offset slightly. Your magnetometer is now indicating its measurement for True North.
Example 2 - Detect a Magnet
In this example, we'll measure magnetic-field strength. This is useful to detect the presence of a nearby magnet.
Download the example script: detectMagnet.py (right-click, "save link as") or copy+paste the following code into Thonny.
magSensor = PiicoDev_QMC6310(range=3000) # initialise the magnetometer
threshold = 80 # microTesla or 'uT'.
    strength = magSensor.readMagnitude()   # Reads the magnetic-field strength in microTesla (uT)
    myString = str(strength) + ' uT'       # create a string with the field-strength and the unit
    print(myString)                        # Print the field strength
    if strength > threshold:               # Check if the magnetic field is strong
        print('Strong Magnet!')
    sleep_ms(1000)
A note about calibration: In Example 1 we performed a 2-axis calibration (rotating the magnetometer on a flat surface. For best results in this example a 3-axis calibration is necessary. To calibrate 3-axes, call the calibrate() function, and rotate the device slowly in all axes.
piicodev-magnetometer-qmc6310-field-strength
Example 3 - Raw Data
Download the example script: rawData.py (right-click, "save link as") or copy+paste the following into Thonny
# Prints the raw axis readings in micro-Tesla
magSensor = PiicoDev_QMC6310() # Initialise the sensor (defaults to range=3000uT)
magSensor.setRange(1200)
    print(raw_data)             # Print the data
    sleep_ms(200)
Project - Graphical Compass
So far we've been using the shell to visualise information collected from the magnetometer. Now for a fun mini-project. We can use a PiicoDev OLED Module to display a digital compass-needle that always points north. The following code is really similar to Example 1, except there's extra code to drive the display, and handle drawing an indicator on the display.
Download the example script: graphicalCompassNoText.py (right-click, "save link as") or copy+paste the following code into Thonny.
# Similar to the compass example, this demo uses a PiicoDev OLED module to show a compass graphic
from PiicoDev_SSD1306 import create_PiicoDev_SSD1306, WIDTH, HEIGHT
from math import sin, cos, radians # for calculating the compass-needle co-ordinates
compass = PiicoDev_QMC6310(range=1200) # Initialise the sensor with the most sensitive range. Valid ranges: 200, 800, 1200, 3000 uT
oled = create_PiicoDev_SSD1306()
# compass.calibrate() # only need to calibrate once
# Declination is the difference between magnetic-north and true-north ("heading") and depends on location
compass.setDeclination(12.5) # Found with: https://www.magnetic-declination.com/Australia/Newcastle/122944.html
centreX = int(WIDTH/2)
centreY = int(HEIGHT/2)
# This function draws the artwork onto the OLED display. It takes a heading and draws a line at that angle from the centre of the display - along with some other nice stuff.
def drawCompass(heading):
    rads = radians(heading + 180) # convert heading to radians and offset by 180 degrees (to account for y increasing down the display)
    length = 25 # compass needle length (in pixels) from centre
    # Convert polar coordinates (length, angle) to cartesian coordinates (x,y) for plotting on display. Offset the coordinates by half the screen width/height to draw from the centre - rather than the top-left of the display.
    x = int( length * sin(rads) + WIDTH/2 )
    y = int( length * cos(rads) + HEIGHT/2 )
    # Plot the compass on the display
    oled.fill(0)
    oled.line(centreX, centreY, x, y, 1) # draw the compass needle
    oled.circ(x,y,4)                     # put a north-indicator on the end
    oled.show()
    heading = compass.readHeading()
    if compass.dataValid(): # only draw for valid data - prevents errors
        heading = round(heading)
    print(heading)
    sleep_ms(100)
The drawCompass() method converts the heading into x,y coordinates that draw a line to the centre of the display. A circle is drawn on the end of the line and the heading in degrees is shown in the bottom corner of the display.
piicodev-magnetometer-qmc6310-project-raspberry-pi-animated-compass
Above: a compass needle is animated on the OLED to point North, even if the whole assembly is rotated.
We can measure the properties of magnetic fields using a 3-axis magnetometer. Build-in functions allow us to easily measure the sensor's heading in a magnetic field, and we've even built a cool graphical compass project using an extra display module.
If you make something cool with this starter project we'd love for you to share it on our forums! And if you'd like some help with this guide, start the conversation below - We're full-time makers and here to help!
Resources
Magnetometer Library: PiicoDev Unified MicroPython module for QMC6310
OLED Library: PiicoDev Unified MicroPython module for SSD1306
compass field hall magnet
