This guide will help you get started with a PiicoDev® Magnetometer - get it working as a compass, and read the magnetic field strength of a nearby magnet.
This guide is for the current revision of the PiicoDev Magnetometer, featuring the MMC5603. All of the video content is still relevant for both revisions.
For more information on the differences, select the "Check Revision" tab
To get started - select your dev. board below.
We have tried our hardest to make it a drop-in replacement, the measurement directions and code should work in place of the previous Magnetometer featuring the QMC6310,
The biggest change is to the main IC being used, the previous revision features the QMC6310, while the current revision features the MMC5603.
Hardware and Connections
- A PiicoDev Magnetometer MMC5603
- A PiicoDev Cable - longer cables are useful to keep your Magnetometer away from magnetic interference.
- (Optional) A magnetic compass - to compare measured headings.
- (Optional) A PiicoDev OLED Module and additional cable for the final project.
Plug your Pico into the expansion board. Make sure it is plugged in the correct orientation - Pin 0 on the expansion board should be to the left of the Pico's USB connector.
- A PiicoDev Magnetometer QMC6310
Mount the PiicoDev® Adapter on your Raspberry Pi and plug connect your Magnetometer to the Adapter via the PiicoDev cable.
The adapter connects to the 40-pin GPIO header on the Raspberry Pi - ensure the header is mounted correctly, with the "Ethernet" label on the same side as the Pi's ethernet adapter (for a Pi 4. On a Pi 3 this will be the USB connector).
Pictured above: A Raspberry Pi 4 Model B with USB Power and HDMI (two white leads). The PiicoDev Adapter is placed on the 40-pin header, and connects to the weather sensor with a PiicoDev Cable.
- A MicroBit V2
- A PiicoDev Adapter for MicroBit
Plug your micro:bit into the Adapter - make sure the buttons are facing up, as shown in the picture below. Connect your magnetometer to the Adapter via the PiicoDev cable, and finally connect your micro:bit to your computer with a USB lead.
Setup Thonny
Select your dev board from the tabs above to get ready for programming with Thonny for the first time.
If you have already programmed with PiicoDev modules before, there's probably no need to follow these steps again.
Download / Install PiicoDev Modules
We will need these files to easily drive the PiicoDev Magnetometer:
- Save the following files to your preferred coding directory - In this tutorial, we save to My Documents > PiicoDev.
- Download the device module: PiicoDev_MMC5603.py (right-click, "save link as")
- Upload the files to your Pico. This process was covered in the Setup Thonny section.
The PiicoDev Unified Library is responsible for communicating with PiicoDev hardware, and the device module contains functions for driving specific PiicoDev devices.
Example 1 - Compass and Calibration
We're ready to go with our first example on the Magnetometer! The following example compass.py, first requests to calibrate the magnetometer:
# Calibrate the sensor by turning it in a circle
# Display the heading with compensation for magnetic declination
from PiicoDev_MMC5603 import PiicoDev_MMC5603
from PiicoDev_Unified import sleep_ms # Cross-platform compatible sleep function
compass = PiicoDev_MMC5603() # Initialise the sensor
# Calibration recommended for best results.
compass.calibrate() # only need to calibrate once
# Optional: Declination is the difference between magnetic-north and true-north ("heading") and depends on location
# compass.setDeclination(12.3) # Found with: https://www.magnetic-declination.com/Australia/Newcastle/122944.html
heading = compass.readHeading() # get the heading from the sensor
if compass.dataValid(): # Rejects invalid data
heading = round(heading) # round to the nearest degree
print( str(heading) + "°") # print the data with a degree symbol
sleep_ms(100)
Slowly rotate the sensor on a flat surface until calibration is complete. You can see the calibration progress shown by a progress bar in the shell.
Once calibration is complete, your console will begin printing the measured heading into the shell. This is the same heading that you would read off a magnetic compass. The heading is the direction the top edge (with the PiicoDev label) of the module is pointing when placed on a level surface like a table.
You may notice a new file named calibration.cal has appeared on your micro:bit - this is the calibration data. This calibration data will be automatically loaded every time the script runs, so you can comment-out compass.calibrate() if you don't want to calibrate on every power-up. It's still a good idea to calibrate periodically, or if you notice your heading has drifted.
Remix - True North
So far we have been working with Magnetic North - this is the direction a magnetic compass will point. To find a true heading, we need to input some more information. Magnetic Declination is the difference between Magnetic North and True North (or "Geographic North"). The value for declination changes depending on location. In Newcastle, Australia, the declination is about 12° (as of 2022). There are lots of online tools that will help you find the declination in your area (here's one example). Once you know the declination in your area, you can input that angle into the setDeclination() function. Re-run your script and you should notice the heading data has been offset slightly. Your magnetometer is now indicating its measurement for True North.
Example 2 - Detect a Magnet
In this example, we'll measure magnetic-field-strength. This is useful to detect the presence of a nearby magnet. Replace the code in main.py with the following code.
magSensor = PiicoDev_MMC5603() # initialise the magnetometer
# magSensor.calibrate()
threshold = 120 # microTesla or 'uT'.
strength = magSensor.readMagnitude() # Reads the magnetic-field strength in microTesla (uT)
if magSensor.dataValid(): # Rejects invalid data
myString = str(strength) + ' uT' # create a string with the field-strength and the unit
print(myString) # Print the field strength
if strength > threshold: # Check if the magnetic field is strong
print('Strong Magnet!')
sleep_ms(1000)
A note about calibration: In Example 1 we performed a 2-axis calibration (rotating the magnetometer on a flat surface. For best results in this example a 3-axis calibration is necessary. To calibrate 3-axes, call the calibrate() function, and rotate the device slowly in all axes.
Example 3 - Raw Data
# Prints the raw axis readings in micro-Tesla (or unscaled raw data)
magSensor = PiicoDev_MMC5603() # Initialise the sensor
print(raw_data) # Print the data
sleep_ms(200)
Project - Graphical Compass
So far we've been using the shell to visualise information collected from the magnetometer. Now for a fun mini-project. We can use a PiicoDev OLED Module to display a digital compass-needle that always points north. The following code is really similar to Example 1, except there's extra code to drive the display, and handle drawing an indicator on the display.
To follow along with this project, you'll need to save PiicoDev_SSD1306.py onto your Pico.
# Similar to the compass example, this demo uses a PiicoDev OLED module to show a compass graphic
from PiicoDev_SSD1306 import create_PiicoDev_SSD1306, WIDTH, HEIGHT
from math import sin, cos, radians # for calculating the compass-needle co-ordinates
compass = PiicoDev_MMC5603(range=1200) # Initialise the sensor
oled = create_PiicoDev_SSD1306()
# compass.calibrate() # only need to calibrate once
# Declination is the difference between magnetic-north and true-north ("heading") and depends on location
compass.setDeclination(12.5) # Found with: https://www.magnetic-declination.com/Australia/Newcastle/122944.html
centreX = int(WIDTH/2)
centreY = int(HEIGHT/2)
# This function draws the artwork onto the OLED display. It takes a heading and draws a line at that angle from the centre of the display - along with some other nice stuff.
def drawCompass(heading):
rads = radians(heading + 180) # convert heading to radians and offset by 180 degrees (to account for y increasing down the display)
length = 25 # compass needle length (in pixels) from centre
# Convert polar coordinates (length, angle) to cartesian coordinates (x,y) for plotting on display. Offset the coordinates by half the screen width/height to draw from the centre - rather than the top-left of the display.
x = int( length * sin(rads) + WIDTH/2 )
y = int( length * cos(rads) + HEIGHT/2 )
# Plot the compass on the display
oled.fill(0)
oled.line(centreX, centreY, x, y, 1) # draw the compass needle
oled.circ(x,y,4) # put a north-indicator on the end
oled.text(str(heading),100,57) # show the heading in the bottom-right corner
oled.show()
if compass.dataValid(): # only draw for valid data - prevents errors
print(heading)
sleep_ms(100)
The drawCompass() method converts the heading into x,y coordinates that draw a line to the centre of the display. A circle is drawn on the end of the line and the heading in degrees is shown in the bottom corner of the display.
Above: a compass needle is animated on the OLED to point North, even if the whole assembly is rotated.
We can measure the properties of magnetic fields using a 3-axis magnetometer. Build-in functions allow us to easily measure the sensor's heading in a magnetic field, and we've even built a cool graphical compass project using an extra display module.
Resources
- Magnetometer library: PiicoDev® Magnetometer QMC6310 MicroPython Module
- Hardware Repository for the PiicoDev Magnetometer
- OLED Library: PiicoDev Unified MicroPython module for SSD1306
