In this guide, we go over some common ways of adding motion to your project with actuators such as stepper motors, servos and linear actuators, to help you choose which one is most appropriate for your situation. The start of this guide c...
MOSFETs for Makers: Getting Started with High-Power Control
In this guide, we’ll learn how to harness the power of MOSFET transistors to easily control higher-powered components like solenoids, motors, and Peltiers with a microcontroller. First, we will cover an easy-to-follow example using s...
#analogue #transistors #switches #raspberry pi pico
In this guide, we'll learn what a Servo is, when we might use one, how to choose a Servo, and finally how to use one with a Raspberry Pi Pico. To follow along you'll need: A Positional Servo, such as the Feetech FS90 Micro Servo A Con...
Getting Started With Relays | Examples with Raspberry Pi Pico
In this guide, we'll learn what a Relay is, why we might use one, how to choose a Relay, and finally how to use one with a Raspberry Pi Pico. To follow along you'll need: A 5V SPDT Relay - I'll be using a 5V Single Channel Relay M...
#relay #raspberry pi pico
Getting Started with Rotary Encoders | Examples with Raspberry Pi Pico
In this guide, we'll learn what a Rotary Encoder is, when and why we might use a Rotary Encoder, and how to use a Rotary Encoder with a Raspberry Pi Pico. To follow along all you'll need is: A Rotary Encoder - we recommend using our br...
#raspberry pi pico #rotary encoder
Linux In Windows
The Windows Subsystem for Linux (WSL) is a powerful new feature that lets you run a Linux terminal from within windows. You may wonder why you would want this, but it actually is great for developers. A lot of Web and open source toolchains...
#windows #linux #micropython #development tools #toolchains
Infinity Mirror Kit Kickstarter Hall of Fame Backers
The Infinity Mirror Kit was made possible by all the people who backed our Kickstarter!  Kits are where it's at. With our Desktop Infinity Mirror Kit you'll get to make something wonderful with your hands, all in the span ...
#infinity mirror kit #hall of backers #kickstarter
Infinity Mirror Kit V2 - Assembly and Tutorials
The Infinity Mirror Kit V2 is a desktop display that creates a dazzling optical illusion - a tunnel of light that tears through space! The Infinity Mirror Kit V2 entered production in October 2018, and now ships with an Adaf...
#arduino #kit #infinity mirror kit #assembly #infinity #infinity mirror #infinity mirror kit v2 #instructions #mirror #trinket
Python Quick Reference
Python is one of the fastest growing programming languages in the world! To help you master this language we have made a quick reference guide and are going to cover a few of the basics things to be aware of when starting out with python.&#...
#python #cheat sheet #poster
C Programming for Makers
Welcome to the C Programming Workshop for Makers! Here you'll be able to follow along with our series of easily digestible videos that cover everything you'll need to know to on your way with C programming and start making awesome projects...
#programming #workshop #c
Infinity Mirror Kit V1 - Assembly and tutorials
The Infinity Mirror Kit is a desk-top display that creates a dazzling optical illusion - a tunnel of light that tears through space! Note: This tutorial is for the Infinity Kit V1. We updated have updated to the Infinity Kit V2 as of ...
Universal 2 Factor Authentication with Key-ID's USB Key
Before we dive into the FIDO Certified Key-ID Security Key and how it's used, let's get a handle on what authentication online means at the moment. Authentication is simply the process of identifying a user based on a set of unique factors...
#fido #key #security #u2f
Serial Monitoring with Tera Term
Monitoring what’s happening inside your microcontroller is an invaluable tool for prototyping and debugging. One of the best ways to do this is to send/receive data over a serial port. Most microcontrollers have a serial port that can...
#arduino #serial #uart #pi #raspberry #particle #monitor #rx #tera #terminal #tx
Our Ozobots Review and Educational Tips
In the Spring of 2012, a tech-gadget company called Evollve Inc. was founded with the goal of creating innovative ways for tech-savvy youngsters to play, learn and interact in a digitally expanding world. There's absolutely nothing wrong wi...
#educational #programming #blockly #learning #robots
So you’ve got your microcontroller/development board ready to go, you’ve got your sensors and external components and you’re ready to build an IoT device to make the world your slave. But hang on a minute, the sensor you h...
What Are NeoPixel LEDs?
So in case you haven’t heard yet, digital LEDs are the go-to solution for any project that uses RGB LEDs and you want to avoid the rat's nest that ensures when using multiple RGB LEDs, each colour requiring its own connectio...
#led #neopixel #rgb #dotstar
So in case you haven’t heard yet, digital LEDs are the go-to solution for any project that uses RGB LEDs and you want to avoid the rat's nest that ensures when using multiple RGB LEDs, each colour requiring its own connection. Digital...
How to Use Rotary Encoders
Hello and welcome to our tutorial on using rotary encoders. Today we’re going to be taking a look at what is a rotary encoder, how does it work, why we would use it over other sensory inputs and creating code to use them. Rotary encod...
#arduino #teensy #encoders #interface #rotary #switch #ui
Programming with USB-Serial Converters
Thanks to huge advancements in technology over the last decade, the maker community that we know and love has thrived. It’s now easier than ever before to get started with programming and tinkering due to the innovation from brands su...
#arduino #serial #usb #converter #ftdi #programming #ttl
Counting with Hexadecimal, Binary, and Decimal
Welcome to Counting with Computer 101. Have you ever looked at a colour on a computer and seen something like this #28FE9A? Or perhaps the T-shirt stating ‘There are 10 types of people in this world, those who understand binary, and t...
#binary #conversion #counting #decimal #hex #hexadecimal
Items 1 to 10 of 20 total
Page
Show per page
