We're full time makers and use 3D Printers almost daily. We've learnt our lesson with kit / DIY printers, time is precious and since when is quality ever not-important. That's why we only use trusted 3D Printers that are backed by innovative leaders within the industry.
To help kickstart you into your 3D Printing projects, we've put together a range of tutorials and guides. We're here to help as well.
In this guide, we are going to be assembling and setting up your Bambu Lab A1 so you can get printing quickly!
A quick but important note: consult your included instruction manual alongside this guide. The packaging layout and shipping mate...
#3d printing#bambu lab
In this guide, we will be exploring how to use PETG as a support interface layer for PLA prints (and vice versa), a multi-material technique that allows you to print perfectly clean and smooth overhangs. We are going to be looking at the ba...
In this guide, we are going to be unboxing and setting up your Bambu Lab H2C so you can get printing quickly!
A quick but important note: always consult your included instruction manual alongside this guide. The packaging layout and shippin...
Sometimes an electronic component will be so stunningly beautiful that you can't help but encase it in gold. That's what happened to me with the Pimoroni Micro Dot pHAT for Raspberry Pi Zero. Hopefully, you can relate. My goal was to create...
Speed or Perfection? That choice is what an understanding of Layer Heights whenever Resin 3D printing is going to provide you. Any Traditional Resin 3D Printer worth its salt will let you print with Layer Heights between 10 Micron to 100 Mi...
#3d#layer#print#resin#software#height
Nothing beats a good cheat sheet. So wouldn't it be great to have a single image, that encapsulated a tonne of handy 3D printing tips and information and have it be ready to hang on the wall in your own Makerverse. Well, we agreed so much s...
#poster#resin#cheat#info#sheet
Layer Exposure Time is the crucial parameter that when dialed in will change average 3D resin printed components into awesome, crispy, final results that capture every single detail of the CAD model. As a general rule for Normal Layer Expos...
So you have a 3D CAD (Computer-Aided Design) file and you want to 3D print it with a resin printer. Then look no further, you have come to the right place. So before you can print your CAD model we are going to need a sliced file of that mo...
So, you have set up your shiny new resin 3D printer and now want to produce beautiful models. Well, this tutorial will tell you exactly what to do from filling the tank, starting a print via USB then the removal, cleaning, and final UV ligh...
Resin 3D printers are an immensely powerful tool in the hands of a maker and they have never been more accessible. This will be a rundown on this technology, contrasting it to filament 3D printing and an explanation of tools whilst teaching...
#printing#3d#uv#printers#resin#creality
The FEP film is a layer of transparent thin plastic (that is double layered) that is installed on the bottom of a resin tank (or Vat) in all resin 3D printers. This film creates a way for the UV light or laser light to cure the liquid resin...
#repair#install#printer#resin#fep
This will likely not become a video but I have just achieved a great result doing this so I thought it best to tell the world before someone else demonstrates it and it becomes common knowledge. It is totally possible to have multiple colou...
#printing#print#colours#resin#multiple#single
No gamer cave is complete without a retro gaming console and 8Bitdo Controllers are the best retro-gaming controllers you can buy. These controllers are simply that good. But there is nothing worse than rushing downstairs eager to play the ...
#8bitdo#controller#pro#3d#print#charge#dock#pro 2
Demonstrated here are two metallic finishes, that you can do to any 3D print, that will astound your friends and family when you tell them 'It was actually 3D printed and these are not metal at all'. These finishes are perfect to use for co...
Let me introduce a new 3D printable case for the Raspberry Pi Pico and the PiicoDev ecosystem. There are variants of the case, one which allows you to wall-mount the system and another variation that makes it possible to charge the device d...
#case#enclosure#developer#pico#piicodev#raspberry pi pico
Whenever you want to print larger than your 3D printer build space you are going to find yourself wanting to combine 3D printed parts together. Furthermore, as you wrap your head around 3D printing, you learn to save on filament by printing...
#components#3d#printed#combine#glue
A super quick article for those who just got their hands on the Raspberry Pi Pico and want to keep it safe and snug in a case. Either with a resin printer or fused filament printer both can produce excellent cases. It was very pleasant prot...
#case#enclosure#pico#raspberry pi pico
One of the special properties of transparent resin prints created by DLP 3D printers like the Creality LD-002R and SLA printers like the Formlabs Form 3 is how vibrantly you can colourise them with Alcohol Inks. Simply by dabbing on just a ...
Print-in-Place mechanism is one of the special things about additive manufacturing that all other manufacturing methods just cannot replicate. They use various hinges, linkages and joints to create moving parts that are printed as a single ...
Co-Polyester is an astounding material in terms of properties, all the best properties of Tough PLA and ABS which are then dialled up just that extra bit in regards to both ruggedness and durability. Ultimaker offers two versions of Co-Poly...
#printing#ultimaker#cpe#petg#trick
If you hang around 3D printers, X-Y plotters, CNC machines, drawing machines, or people who use any of them G-code is a term that will universally come up no matter where you find yourself in the world. But what is it? And how is it being u...
This is the process I go through to make Polymaker Polywood look like actual wood (or at least I had a good go at it)! It will assume you already have a 3D printed components made from Polymaker Polywood Filament. This is a PLA (polylactic ...
#printing#3d#create#post#processing#wood
★ Achievement unlocked - 3D Print "Glass" ★ Your friends will not believe the results but this guide will tell you all the secrets to have a 3D printed component which is beautifully transparent to the point of being able to perfectly see-t...
Cura is constantly being improved upon and half the fun is keeping on top of all the new changes and new offerings it gives. For completely free software, they are doing an amazing job. Nailing the recipe for a 3D prints will let you get th...
One of the swell things about 3D printers is being able to lay fabric onto a build plate and create components directly on top of or embedded with fabric material through them. This lets you easily sew designs onto clothes or create interes...
#flexible#movement#3d#diy#fabrics#print#onto
A special part of me enjoys it when people go ‘I cannot believe that was 3D printed’ and one of the best ways to get that reaction is through post-processing. Now not to belittle the beauty of a raw print result you can achieve from a corre...
#3d#post#processing#fantastic#finishes#printed
The eternal question of ‘does it print in more colours?’ is often one of the most common community desires. And yes you can! One of the best ways that this need is delivered is through dual-extrusion printing. Dual-extrusion printing is the...
#cura#printing#3d#dual#tips#colours
Fused filament fabrication and transparent prints! No, surely you mean SLA prints. And true you can get excellent transparent prints effectively using SLA however consumer-grade fused filament fabrication can be mistaken for glass when corr...
This guide is all about doing clever things in a software to get the best results out of a 3D printer. The main focus is turning intricate CAD files into a format that you can print without small details or thin walls being neglected by the...
The built-in remote monitoring camera and the live feed it provides makes for a fantastic tool of the Ultimaker S5 and Ultimaker S3 3D printers. You can now keep tabs on your prints remotely, easing the pain of a long-distance relationship ...
#camera#fix#ultimaker#clear#focus
Of the many great objects you can create using any 3D printer lithophanes are definitely up there. Traditionally lithophanes were an etched or moulded artwork created on a very thin translucent porcelain that can been seen clearly only when...
#3d printing#images#lithophanes
Each and every day it has become easier to print the natural and human-made world around us. So, if you ever worried that you would run out of things to 3D print fear not! There are many ways of producing 3D models and most of these methods...
Dual-extrusion printing is an absolute treat and Polyvinyl Alcohol (PVA) as a support structure is truly worth a celebration! You can produce immensely detailed models with a ton of supports and not be concerned about removal. Just immerse ...
Filament grinding is very unlikely to occur if your running an Ultimaker S5 3D Printer with Ultimaker materials or 3rd party supported materials. Filament grinding occurs when the knurled feeder gear slips against the filament instead of sm...
If your utilizing a correctly set up Ultimaker S5 3D Printer you should have no issues with first layer printing. So long as there are print profiles available on Cura, which most likely it will, with a correctly set up 3D printer you will ...
#3d printing#cura#ultimaker#models#first#layer
If your 3D printer is an Ultimaker S5 then your prints will almost always come out looking brilliant. Although achieving desirable 3D printed components can sometimes require troubleshooting to resolve print errors. These errors often can b...
In your foray into the 3D printing sphere, you will likely just run into moments when using a new extruder nozzle type would be beneficial. An often-overlooked detail, different nozzles give all different kinds of advantages and with the ri...
Ultimaker Cura is an excellent slicing software to get the best out of your 3D printers and make the greatest models it possibly can, but it can do so much more! Cura is a brilliant means to inspire and expand your own creativity particular...
#3d printing#cura#ultimaker#exciting#features
This will be a guide giving an overview of Cura, the open-source 3D printing slicing application from the smart cats at Ultimaker. Put simply Ultimaker Cura is a software which allows you to turn the computer file of your design into a reci...
Installing filament into your Ultimaker 3D printers will quickly become an intuitive process. But until that happens I'll be here to help run down the process and to teach you exactly how to do it whilst keeping your awesome 3D printer safe...
For Ultimaker 3D printers it is crucial to have a flat and level build platform which is parallel to the path of the nozzle. By having a correctly set up print space it will ensure the best possible results for all 3D printed components. As...
This will be an overview, initial setup and first print guide for the Ultimaker 2 and Ultimaker 2 Extended . Quick links for the contents of this guide is seen below.
Printer Overview
Printer Characteristics
Everything in the Box
Controls...
Printer Overview
Controls...
The realm of 3D printers is currently the forefront of new technology. The capabilities of these machines are under relentless progression determined hugely by the technologies available and needs from the community. Reliability, accuracy a...
#3d printing#filaments#ultimaker#dual-extrusion
In this world not all machines are made equal and this is especially true in the sphere of 3D printing. One of the best ways to compare 3D printers is by the magnitude of materials it is capable of producing high-quality components from. Yo...
One of the most critical parts of a successful 3D print is the correct material choice and through its careful consideration you will get the best result for the final component you had in mind.
Ultimaker has a wide range of 3D printing fil...
By default, FFF/FDM 3D Printers require the 3D Models they print to grow up from the Print bed at an angle of 45 or more. This is by far the biggest limitation of all 3D Printers. To print models that don't follow that rule, and have parts ...
#cura#meshmixer#overhangs#supports
Out of the box, a LulzBot 3D Printer comes tuned to perform exactly as you need it to. But over time we flash new firmwares, take our printers cross country, swap tool heads, perform cold pulls and a whole swathe of other things that could ...
#3d printing#first layer#z-offset
Recently, we've talked a lot about Slicing software, settings, materials and the like. It's time to take a deeper dive into the actual design of model files. We've got a basics guide for Computer Aided Design available here. We're going to ...
#design#3d printing#fdm#cad#manufacture
OctoPrint Integration is one of my favourite new features in Cura 2.6+: LulzBot Edition. In short, this integration means that you can print and control your 3D Printer via it's OctoPrint server. All from within your slicer window on your P...
#octoprint#cura 2.6
After some serious touch time your LulzBot 3D Printer and the quick print options in Cura 2, it's more than likely that you want to make more specific changes to the way 3D Models are printed. Whether it be, changing the support type and st...
#guide#cura 2#expert settings
Now that we are all on track with our Slicer software, having just installed Cura 2 and upgraded our printer firmware, let's work on turning some 3D Model files into G-Code for our 3D Printer to create. We're going to be using our LulzBot M...
#beginner#guide#cura 2
In November of 2017, our friends over at LulzBot released a major software update to their Slicing software, Cura. In this tutorial, we will look at what Cura is and does, the process of installing Cura 2 onto a PC already running Cura 21.x...
#install#cura 2#firmware upgrade#slicer
When making a webcam mount for your 3D Printer, there are physical limitations for where you can have the camera sitting safely throughout the whole print. A while back, we remixed a really nicely designed bed mount for the Raspi Camera so ...
#taz 6#mount#third hand#webcam
Recently, we got a brand new Dual Extruder v3 Tool Head from LulzBot and took a dive into the design of it, mainly, what makes it so great for Dual Extrusion with our 3D Printers. First, a quick recap, Dual Extruding is the process of using...
#3d printing#dual extruder#soluble filament
Dual Extruding with FDM 3D Printers is typically reserved for the most expert-level makers. By adding the ability to print with 2 materials, you open yourself up to a spread of conditions that simply didn't exist with a single extruder setu...
The Maker Revolution celebrates the creation of new devices and the modification of existing ones - the transition from a consumer buying goods to eventually having a major part in their creation. The Maker Revolution places strong emphasis...
#poster#infographic#maker#movement#revolution
With winter currently in full swing, there's a particularly annoying 3D printing problem that is rearing its ugly head, Warping. For those who don't know, warping is what happens when parts of a printed model shrink due to cold drafts acros...
#3d printing#enclosure#printedsolid#warping
Wouldn't it be great to have a single image, that encapsulated a tonne of handy 3D printing tips and information to hang on the wall behind your 3D Printer? Well, we agree so much so that we've gone ahead and created this infographic/cheat ...
#3d printing#cheat sheet#poster
Hailing from Aleph Objects in Loveland, Colorado, the Lulzbot range of 3D printers are world renown for their quality, reliability and ease of use. The reason they're so popular? Apart from the gilded Lulzbot technical support (practically ...
#3d printing#differences#mini#taz
Toolheads for your 3D printer come in all shapes and sizes. The different models available from Lulzbot are all designed with a specific purpose in mind, usually to add a filament type to your 3D printing repertoire. Dual extruders enable y...
#3d printing#lulzbot#extruders#moarstruder
Website features/issues
Content errors/improvements
Missing products/categories
Search results relevance
