When you say 'switch' most people think of a standard pushbutton and for good reason. They're incredibly versatile and are used in all kinds of projects.
Items 26-50 of 53
  1. 16mm Panel Mount Momentary Pushbutton - Red
    SKU: ADA1445 Brand: Adafruit
    OK, this item is pretty simple - it's a panel mount pushbutton. It's not that exciting, no LEDs, no bells & whistles. But Adafruit really like it anways, look at that...
    6 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
    Delivered by Nov 13th
  2. Tactile Switch Buttons (6mm slim) x 20 pack
    SKU: ADA1489 Brand: Adafruit
    Slim clicky momentary switches are standard input "buttons" on electronic projects. These are half the width of classic 6mm tactile switches so they line up better...
  3. Metal illuminated pushbutton-Blue Ring
    SKU: FIT0115-B Brand: DFRobot
    This is a water proof push button with illuminator. It is made by stainless steel with excellent quality.
    Available with 8 to 12 day lead time
  4. Metal illuminated pushbutton-Red Ring
    SKU: FIT0115-R Brand: DFRobot
    This is a water proof push button with illuminator (LED). It is made by stainless steel with excellent quality.
  5. Gravity: Analog ADKeyboard Module V2
    SKU: DFR0075 Brand: DFRobot
    This keyboard uses an analog input to read the five key state which saves IO resource for the Arduino. It can be used together with our I/O expansion boards to make amazing interactive project.
  6. Momentary Push Button Switch - 12mm Square
    SKU: COM-09190 Brand: Sparkfun
    This is a standard 12mm square momentary button. What we really like is the large button head and good tactile feel (it ‘clicks’ really well). This button is great for user input on a PCB or a good, big reset button on a breadboard. Breadboard friendly!
    58 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  7. Black Soft Caps for Tactile Buttons (10-pack)
    SKU: CE09218 Brand: The Pi Hut
    How neato are these little hats! These little guys push on top of your tactile buttons and make the whole prototyping experience so much more luxurious....
    7 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  8. Clear Soft Caps for Tactile Buttons (10-pack)
    SKU: CE09219 Brand: The Pi Hut
    4 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  9. Tactile Switch Assortment - 25 Different Buttons - 10 pcs each - Through Hole and Surface Mount
    SKU: ADA5493 Brand: Adafruit
    When designing your next PCB, if you're not sure what sort of tactile switches you can fit, or how they would look, this Tactile Switch Assortment...
    Available with 7 to 12 day lead time
  10. Rugged Metal Silver Finish Pushbutton - 16mm 6V RGB Latching
    SKU: ADA4659 Brand: Adafruit
    By popular demand, Adafruit now have latching rugged metal push buttons with a full color RGB LED ring light! These chrome-plated metal buttons are rugged, but certainly not lacking in flair. Simply drill a 16mm hole into any material up to 1/4" thick and you can fit these in place – there's even a rubber gasket to keep water out of the enclosure.
  11. IP67 Rated Momentary Red Pushbutton Switch SPST
    SKU: CE07538 Brand: Core Electronics
    IP67 rated for harsh environments, low profile dome shape, momentary action.
    10 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  12. IP67 Rated Momentary Black Pushbutton Switch SPST
    SKU: CE07539 Brand: Core Electronics
    20 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  13. Metal Pushbutton with Wires - Latching (16mm, Yellow)
    SKU: COM-27246 Brand: Sparkfun
    This is a perfect choice if you are in need of a heavy duty push button! These metal push buttons are a very tough, small, panel-mount latching switch...
    Available with 5 to 8 day lead time
  14. Metal Pushbutton - Latching (16mm, Red)
    SKU: COM-13400 Brand: Sparkfun
  15. Metal Pushbutton - Latching (16mm, Blue)
    SKU: COM-13381 Brand: Sparkfun
  16. Metal Pushbutton - Latching (16mm, Green)
    SKU: COM-13382 Brand: Sparkfun
  17. Metal Pushbutton - Latching (16mm, White)
    SKU: COM-13388 Brand: Sparkfun
  18. Metal Pushbutton - Momentary (16mm, Red)
    SKU: COM-13405 Brand: Sparkfun
    This is a perfect choice if you are in need of a heavy duty push button! These metal push buttons are a very tough, small, panel-mount momentary switch...
  19. Metal Pushbutton - Momentary (16mm, Blue)
    SKU: COM-13399 Brand: Sparkfun
  20. Metal Pushbutton - Momentary (16mm, Green)
    SKU: COM-13411 Brand: Sparkfun
  21. Metal Pushbutton - Momentary (16mm, Yellow)
    SKU: COM-13447 Brand: Sparkfun
  22. Gravity: LED Switch - White
    SKU: DFR0789-W Brand: DFRobot
    This is a simple LED-illuminated self-lock switch button. It’s just like a basic switch button, but it lights up color(red/yellow/green/blue/white) when pressed...
  23. Kailh Mechanical Key Switches - Linear Black - 12 pack - Cherry MX Black Compatible
    SKU: ADA5876 Brand: Adafruit
    For crafting your very own custom keyboard, these Kailh Black Linear mechanical key switches are deeee-luxe! With smooth actuation and Cherry MX...
  24. PiicoDev Button
    SKU: CE08500 Brand: PiicoDev Guides (2)
    An accessible, tactile interface adds control to your project.
    218 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  25. Square Silicone Button PWM Controller - 3 Wire - 3.6V to 12VDC
    SKU: ADA5436 Brand: Adafruit
    This Square Silicone Button PWM Controller is a satisfyingly-squishy, easy-to-wire PWM output button controller with three color power-adjustment statuses...
