PiicoDev RFID Module - Guide for micro:bit
Radio Frequency IDentification (RFID) uses electromagnetic fields to identify and communicate with tags. Each RFID module emits radio waves that energise the passive tag, which then responds with its own identifying number or data, as reque...
#nfc #id #tag
#nfc #id #tag
PiicoDev Magnetometer QMC6310 - Guide for MicroBit
This guide is for the previous revision of the PiicoDev Magnetometer QMC6310 - if you have the latest revision featuring the MMC5603 - head to the guide for updated links and instructions.Let's get started with the PiicoDev® Magnetomet...
#compass #field #hall #magnet
PiicoDev Buzzer Module - Guide for Micro:bit
Introduction Let's play tones and melodies on a PiicoDev® Buzzer Module with a Micro:bit. This guide will cover connecting the hardware, running an example to make sure everything works and playing simple melodies. Of course, the Micr...
#piezo
#piezo
PiicoDev RGB LED Module - Microbit Guide
Let's get started with the PiicoDev® 3x RGB LED Module. In this guide, we'll connect the LED Module to our Raspberry Pi Pico and get it working with some example code to display colourful patterns. To follow along, it's best to ...
#neopixel #ws2812 #ws2812b #neopixels
PiicoDev Colour Sensor VEML6040 - Micro:bit Guide
Introduction Let's read colour data from a PiicoDev® Colour Sensor with a Micro:bit V2, and create a colour sorting machine. This guide will cover connecting the hardware, downloading some example code and remixing it. To f...
#rgb #color #hsl #hsv
PiicoDev OLED Module SSD1306 - Micro:bit Guide
Let's get started with the PiicoDev® OLED Module SSD1306. In this guide, we'll connect the PiicoDev OLED to our Raspberry Pi Pico and get it working with some example code to display text, shapes, and animations. To f...
PiicoDev Capacitive Touch Sensor CAP1203 - Micro:bit Guide
Let's get started with the PiicoDev® Capacitive Touch Sensor. In this guide, we'll connect the PiicoDev Capacitive Touch Sensor to our Micro:bit V2 and get it working with some example code to detect touch events. We'll also remix the c...
PiicoDev Pressure Sensor MS5637 - Micro:bit Guide
Introduction This guide will help you read barometric pressure from your PiicoDev® Pressure Sensor and a Micro:bit To follow along, it's best to have: A Micro:bit V2 A PiicoDev Pressure Sensor MS5637 A PiicoDev Adapter for M...
#sensor #pressure #altimeter #altitude #barometric
PiicoDev Distance Sensor VL53L1X - Micro:bit Guide
Introduction This guide will help you read distance data in millimetres from your PiicoDev Distance Sensor and a Micro:bit. To follow along, it's best to have: A Micro:bit A PiicoDev Distance Sensor VL53L1X A PiicoDev adapter for Mic...
#sensor #distance #bit #micro #microbit #piicodev #vl53l1x
Program a Micro:Bit in your Web Browser
In this article, we'll program a Micro:bit v2 using a web browser. We'll connect a Micro:bit to our computer, open python.microbit.org and begin coding our first script. Contents What You'll Need Connect your Micro:bit Open the Progr...
#micropython #browser #programmer
PiicoDev Precision Temperature Sensor TMP117 - Micro:bit Guide
Introduction This guide will help you read temperature data from your PiicoDev Precision Temperature Sensor and a Micro:bit. To follow along, it's best to have: A Micro:bit A PiicoDev Precision Temperature Sensor TMP117 A PiicoDev a...
#sensor #temperature #bit #micro #piicodev
PiicoDev Ambient Light Sensor VEML6030 - Micro:bit Guide
Introduction This guide will help you read light intensity data from your PiicoDev Ambient Light Sensor and a Micro:bit. To follow along, it's best to have: A Micro:bit A PiicoDev Ambient Light Sensor VEML6030 A PiicoDev adapter for ...
#sensor #light #microbit #piicodev #veml6030 #ambient
PiicoDev Atmospheric Sensor BME280 - Micro:bit Guide
Introduction This guide will help you read weather data (Temperature, Air Pressure and Humidity) from your PiicoDev Atmospheric Sensor and a Micro:bit. To follow along, it's best to have: A Micro:bit v2 (v1 does not...
#sensor #microbit #atmospheric #bme280 #piicodev
How to Program a MicroBit using Thonny
Let's get set up with scripting in Thonny for the Micro:bit. We'll install Thonny, configure for Micro:bit, and write our first script. All you'll need to follow along is a Micro:bit v2 GO kit Contents Install Thonny Set u...
Every good E-Textiles or Wearables project needs to start somewhere, and the natural starting point for any project is choosing the right microcontroller. There are many good choices out there, and we will compare a few of the best and brig...
MOVE Mini Assembly Guide
The :MOVE MINI allows you to turn your micro:bit into a simple robot! In this guide, we will give you some tips and tricks for assembling the :MOVE mini. This is a DIY assembly item and takes 30-60 minutes to fully assemble. There is a grea...
#mini #microbit #bot #microbit robot #move #move mini #robot #servo lite
Micro:bit Temperature and Humidity Sensing
The Micro:bit has the ability to measure temperature by sensing the temperature of the silicon die inside the main CPU. This works because the Micro:bit runs cold, and the temperature of the CPU is usually a good approximation of ...
#education #sensor #temperature #makecode #microbit #dht11 #humidity
Micro:bit Light and UV Sensing
Every Micro:bit has the ability to measure visible light, but what about UV light? Imagine that you are growing a plant on the window sill in a well-lit room. Does your plant have enough light? Plants need UV light to photosynthesize e...
#education #educators #classroom #sensor #learning #light #makecode #microbit #sensing #teachers #uv
Micro:bit Soil Moisture Sensor
The Micro:bit is great for small portable projects like a soil moisture sensor. In this tutorial, we will walk through how to program a Micro:bit to make a reliable and consistent soil moisture sensor that will give consistent readings. The...
#education #sensor #learning #makecode #sparkfun #microbit #soil moisture
MicroPython Primer for Makers - What is MicroPython?
This Tutorial is all about the MicroPython Programming Language. We will discuss what MicroPython is, why you will want to use it in your projects and we will share some resources to help you learn further! What is MicroPython? MicroPyt...
#python #micropython #circuitpython #repl
Data Logging with the Micro:bit and OpenLog
The Micro:bit by BBC is a great data collection tool, it just needs a little help remembering what it has measured! This tutorial is made for those Micro:bit projects where transmitting your sensor data over radio or Bluetooth to a computer...
#logging #data logging #bbc #sparkfun #microbit #data #openlog
Natural Disaster Sensor Project for Micro:bit
The Micro:bit is a feature-packed development board that’s perfect for the classroom or the beginner programmer. Each Micro:bit has a built-in radio that can transmit and receive signals sent from other Micro:bits. The radio has a ran...
#stem #sensor #radio #temperature #data logging #motion #natural disaster #data plotting #microbit #wind
micro:bit in the classroom
Check out our Getting started with micro:bit video if you'd like to see a quick tutorial on writing a program, start-to-finish, with a micro:bit. In a Nutshell The micro:bit is a versatile and classroom-friendly, programmable ele...
#bbc #bit #lesson #micro
Getting Started with micro:bit
Check out our micro:bit in the classroom video if you'd like to see how micro:bit integrates into classrooms, years 7-12. After a quick review of the hardware, we'll fire up a micro:bit and write our first program. All you...
#tutorial #bit #micro
Items 1 to 10 of 24 total
Page
Show per page
