PiicoDev Atmospheric Sensor BME280 - Micro:bit Guide
Updated 06 April 2022
This guide will help you read weather data (Temperature, Air Pressure and Humidity) from your PiicoDev Atmospheric Sensor and a Micro:bit.
If you prefer not to use the Micro:bit adapter, there are other connection options in our PiicoDev Connection Guide.
Plug your Micro:bit into the PiicoDev adapter (buttons LED matrix facing up), connect your sensor to the adapter via the PiicoDev cable and connect your Micro:bit to your computer with a USB lead.
piicodev-atmospheric-microbit-connections
For sensors with an ASW switch: If your sensor has a switch labelled ASW, ensure it is in the OFF position before proceeding.
bme280-asw-switch
It will be best to keep this file wherever you like to keep your coding projects eg. Documents > PiicoDev
Example Code
Open Thonny, connect to your micro:bit and upload the three files from the previous step.
Press Ctrl D to restart your micro:bit and run the main script - weather data should begin streaming up the shell
example-script-for-microbit
Above: Atmospheric data is streaming up the Shell. From left to right: Temperature (degC), Barometric Pressure (hPa) and Relative Humidity (%)
Using Multiple Sensors
It's possible to use up to two Atmospheric sensors connected together - they just need to be set up with different addresses. The default address for Atmospheric Sensors is 0x77 - If you've been following this tutorial this is the address being used by default when no address is specified. To add a second sensor, we need to change its address to 0x76, as follows.
For Sensors with an Address Switch ("ASW")
If your second sensor has an address switch (labelled "ASW"), switch it to the ON position. If your sensor does not have an ASW switch, follow these steps instead.
Use a pen, toothpick or other fine tip to make this easier. If your ASW switch is protected by a thin, orange film - carefully peel that off first before attempting to set the switch.
two-atmospheric-sensors-connected-together
Two PiicoDev Atmospheric Sensors being used on the same bus - this is made possible by setting each device to a unique address. The left sensor has ASW:OFF, and the right sensor has ASW:ON.
piicodev-atmospheric-sensor-address-switch
A closeup of the switch configuration.
For Sensors with no Address Switch
If your second sensor doesn't have an address switch you'll need to (carefully!) change its address. Find the ADR jumper on the back of the sensor. Cut the trace between the centre tab and the tab labelled 0x77. Next, use solder to join the centre tab and the tab labelled 0x76.
piicodev-atmospheric-sensor-adr-jumper
Code
The following code will collect and print data from each Atmospheric Sensor individually. The first sensor (with address=0x77) is initialised as sensorA. The second sensor (with address=0x76) is initialised as sensorB. Once we have two sensors initialised, we can call the values() function for each to read them individually.
# PiicoDev Atmospheric Sensor BME280 - Using multiple sensors
# Connect two sensors, each with a different address. They can be initialised and read independently.
from PiicoDev_BME280 import PiicoDev_BME280
sensorA = PiicoDev_BME280() # initialise the first sensor (defaults to 0x77). This is identical to "PiicoDev_BME280(address=0x77)"
sensorB = PiicoDev_BME280(address=0x76) # initialise the second sensor at address 0x76
    dataA = sensorA.values() # read all data from the first sensor
    dataB = sensorB.values() # read all data from the second sensor
    myString = "A: "   str(dataA)   "   B: "   str(dataB) # create output string with both data
    print(myString)
    sleep_ms(100)
When you run the above code, the Python Shell should print three values for A, and three values for B. These are the Temperature, Pressure and Humidity as measured by each sensor. In the first sample, we can see that sensorA reads 28.24 degrees C, while sensorB reads 28.11 degrees C.
piicodev-atmospheric-sensor-multiple-device-data
sensor microbit atmospheric bme280 piicodev
