This guide will help you read barometric pressure from your PiicoDev® Pressure Sensor and a Micro:bit
- A Micro:bit V2
- A PiicoDev Pressure Sensor MS5637
- A PiicoDev Adapter for Micro:bit
- A PiicoDev Cable
Plug your Micro:bit into the PiicoDev adapter (buttons + LED matrix facing up), connect your motion sensor to the adapter via the PiicoDev cable and connect your Micro:bit to your computer with a USB lead.
- PiicoDev_Unified.py - The PiicoDev Unified Libraries: Drives I2C communications for PiicoDev modules
- PiicoDev_MS5637.py - The device driver.
- main.py - an example script for this PiicoDev Sensor
It will be best to keep this file wherever you like to keep your coding projects eg. Documents > PiicoDev
Example Code
We'll be working in Thonny - if you're unfamiliar working with Thonny see our guide for Thonny and Micro:bit.
Open Thonny, connect to your Micro:bit and upload the three files. (Hint: View the files menu with View > Files)
Restart your Micro:bit with keyboard shortcut, Ctrl+D and it should begin printing barometric pressure measurements in hectopascal, which is equivalent to millibar - a commonly used unit for describing barometric pressure: 1hPa = 100Pa = 1mbar.
Above: Pressure data streams up the Shell, while the Plot shows historic data.
Remix
Did you know you can also infer altitude from air pressure? Comment out the pressure print statement and uncomment the altitude print statement. Run the script again and now the Pico will infer altitude-above-sea-level from air pressure. There can be a bit of error here since your local weather conditions will affect the reading. You can optionally pass in the local air pressure at sea level to the read_altitude() function to correct for weather effects. You can find the current air pressure at sea level for your area with an internet search.
We can now measure air pressure from our PiicoDev Pressure Sensor, and use it to infer altitude.
