This guide will help you read distance data in millimetres from your PiicoDev Distance Sensor and a Micro:bit.
If you prefer not to use the Micro:bit adapter, there are other connection options in our PiicoDev Connection Guide.
Plug your Micro:bit into the PiicoDev adapter (buttons + LED matrix facing up), connect your distance sensor to the adapter via the PiicoDev cable and connect your Micro:bit to your computer with a USB lead.
- PiicoDev_Unified.py - The PiicoDev Unified Libraries: Drives I2C communications for PiicoDev modules
- PiicoDev_VL53L1X.py - The device driver.
- main.py - an example script for this PiicoDev Sensor
It will be best to keep this file wherever you like to keep your coding projects eg. Documents > PiicoDev
Example Code
Open Thonny, connect to your micro:bit and upload the three files from the previous step.
Press Ctrl+D to restart your micro:bit and run the main script - distance data should begin streaming up the shell
Above: Distance data (in millimetres) streams up the shell. The plot to the right shows historic data as I move my hand back and forth over the sensor.
Try moving your hand in front of the sensor and watch how the data changes.
Remix - Musical Instrument
Now that we can measure distance, we can use that as the input for a fun musical instrument. The following code measures distance and, depending on the distance, select a different musical note to play on the Micro:bit's speaker - give it a try! Replace the code in main.py with the following code. We'll cover how it works in the video.
from microbit import button_a
import music
notes = ["C4","D4","E4","F4","G4","A5","B5","C5"]
if button_a.is_pressed():
dist = distSensor.read() # read the distance in millimetres
noteIndex = min(round(dist / 75), 7) # convert distance to a note-number 0-7
print(str(dist) + " mm => note " + notes[noteIndex]) # convert the number to a string and print
music.play(notes[noteIndex])
sleep_ms(500)
How nice! Now we can measure distance and use that data in creative ways - like making a fun musical instrument.
