PiicoDev Ambient Light Sensor VEML6030 - Micro:bit Guide
Updated 23 September 2021
This guide will help you read light intensity data from your PiicoDev Ambient Light Sensor and a Micro:bit.
If you prefer not to use the Micro:bit adapter, there are other connection options in our PiicoDev Connection Guide.
Plug your Micro:bit into the PiicoDev adapter (buttons + LED matrix facing up), connect your sensor to the adapter via the PiicoDev cable and connect your Micro:bit to your computer with a USB lead.
piicodev-veml6030-microbit-connections
It will be best to keep this file wherever you like to keep your coding projects eg. Documents > PiicoDev
Example Code
Open Thonny, connect to your micro:bit and upload the three files from the previous step.
Press Ctrl+D to restart your micro:bit and run the main script - light data should begin streaming up the shell
example-script-for-microbit
Above: Plotted data starts at ambient levels, then I cover the sensor with my hand and the data dips. A flashlight is then shined on the sensor with creates a large peak.
Now we can easily read light data with our Pico.
Remix - Day/Night message
In the final part of the video, we modify the example code to keep track of whether it is day or night (bright/dark). When light data transitions between bright and dark, we can create a Good Morning or Goodnight sound with our micro:bit - You can use this structure for decision-making in your own projects - be sure to code along!
sensor light microbit piicodev veml6030 ambient
