Measure and detect force, pressure, and weight with precision using our range of force sensors, load cells, and tactile sensors for various applications.
Items 26-31 of 31
  1. Force-Sensing Linear Potentiometer: 1.4″×0.4″ Strip
    SKU: POLOLU-2729 Brand: Pololu
    This force-sensing linear potentiometer (FSLP) from Interlink Electronics is a passive component with resistances that depend on the magnitude and location of the force applied at some point along the 1.4″ (3.6 cm) active length of the strip, making it easy to add novel touch interfaces or tactile sensors to your project. An external resistor (typically 4.7 kΩ to 10 kΩ) is required but not included.
  2. Force-Sensing Linear Potentiometer: 4.0″×0.4″ Strip, Customizable Length
    SKU: POLOLU-2730 Brand: Pololu
    Force-sensing linear potentiometers (FSLPs) from Interlink Electronics are passive components with resistances that depend on the magnitude and location of the force applied to the strip, making it easy to add novel touch interfaces or tactile sensors to your project. This 4″ (10 cm) strip can be cut to shorter, predefined lengths (1″, 2″, or 3″) to better suit your application. An external resistor (typically 4.7 kΩ to 10 kΩ) is required but not included.
    1 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
    Delivered by Jan 16th
  3. RP-C7.6-LT Thin Film Pressure Sensor
    SKU: SEN0298 Brand: DFRobot
    This is a circular flexible thin film pressure sensor of long legs with a diameter of 7.6mm, which can be used to realize highly sensitive detection of pressure...
  4. Force Sensitive Resistor (7mm, 5KG)
    SKU: CE09431 Brand: Core Electronics
    Use the force...sensitive resistor! Add an easy-to-implement haptic analog sensor to your projects.
    17 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  5. Load Cell - 10kg, Straight Bar with Hook (HX711)
    SKU: SEN-21669 Brand: Sparkfun
    This straight bar load cell (sometimes called a strain gauge) can translate up to 10kg of pressure (force) into an electrical signal...
    Available with 5 to 8 day lead time
  6. M5Stack Precision Weight Sensor (I2C/HX711)
    SKU: CE10064 Brand: M5Stack
    Discover M5Stack's high-precision weight sensor featuring 24-bit accuracy, I2C communication, and STM32+HX711 chip integration - perfect for industrial, healthcare, and laboratory applications where precise weight measurement is crucial.
    3 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
