Get all the essential accessories and modules for your Raspberry Pi projects, including PiicoDev sensors, Makerverse prototyping boards, and GlowBit LED displays.
Items 26-32 of 32
  1. Raspberry Pi USB 3.0 Hub
    SKU: CE09941 Brand: Raspberry Pi
    Need more USB ports? This handy accessory turns one USB-A port into four!
    19 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
    Delivered by Feb 26th
  2. reTerminal DM Industrial HMI - Raspberry Pi CM4 Controller
    SKU: SS114070262 Brand: Seeed Studio
    Discover the reTerminal DM Industrial HMI, a powerful Raspberry Pi CM4-powered controller featuring hybrid connectivity, IP65 protection, and versatile interfaces including CAN bus, RS485, RS232, and Gigabit Ethernet for advanced industrial automation and
    Available with 8 to 10 day lead time
  3. Raspberry Pi OS 64GB Preloaded uSD Card
    SKU: CE10104 Brand: Raspberry Pi
    This 64GB MicroSD Card is preloaded with the Official Raspberry Pi OS. For beginners and first-time users, this higher capacity card will allow for tons of additional space for projects on any Pi!
    135 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  4. Official Raspberry Pi 128GB A2-Class micro SD card
    SKU: CE10105 Brand: Raspberry Pi
    Reliable, fast, and tested storage, ready to go for your Raspberry Pi projects!
    $64.00 AUD, inc GST
    85 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  5. Raspberry Pi 45W Power Supply (USB-C)
    SKU: CE10156 Brand: Core Electronics
    Power up any USB-C devices with this beefy 45W power supply, with PD up to 20V 2.25A!
    $25.30 AUD, inc GST
    113 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  6. Raspberry Pi 4 Case, Black/Grey (Official)
    SKU: CE09815 Brand: Raspberry Pi
    Designed by Raspberry Pi themselves, this case will be the perfect fit for Raspberry Pi 4 Model B.
    164 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  7. Official Raspberry Pi 256GB A2-Class micro SD card
    SKU: CE10300 Brand: Raspberry Pi
    Fast, reliable and tested storage, with a huge capacity - ready for any Raspberry Pi project.
    $92.00 AUD, inc GST
    17 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
Take a look at our Raspberry Pi Tutorials along with our free Online Workshop. For makers, by makers.
