Motor controllers consist of drivers, combined with logic circuits designed to handle higher-level interfaces such as serial, PWM, analog, and other common inputs.
The Motoron M2H24v16 Dual High-Power Motor Controller makes it easy to control DC motors from a Raspberry Pi (Model B+ or newer) through an I²C interface....
The Motoron M2H18v20 Dual High-Power Motor Controller makes it easy to control DC motors from a Raspberry Pi (Model B+ or newer) through an I²C interface....
The Motoron M2H18v18 Dual High-Power Motor Controller makes it easy to control DC motors from a Raspberry Pi (Model B+ or newer) through an I²C interface....
The RoboClaw motor controllers from Basicmicro can control a pair of brushed DC motors using USB serial, TTL serial, RC, or analog inputs. Integrated dual...
This discrete MOSFET H-bridge motor driver enables bidirectional control of one high-power DC brushed motor. The small 1.3" × 0.8" board supports a wide...
Explore the ATOMIC Motion Base, a versatile STM32-powered controller featuring 4 servo channels and 2 DC motor interfaces, designed for ATOM series with built-in 700mAh battery for portable robotics and motor control projects.
Explore the ATOMIC H-Bridge Motor Driver, a compact 24V/1.5A DC motor controller featuring integrated protection circuits, real-time voltage monitoring, and seamless compatibility with ATOM series controllers.
This powerful motor controller makes basic control of a brushed DC motor easy, with quick configuration over USB using our free software. It supports five...
Website features/issues
Content errors/improvements
Missing products/categories
Product assignments to categories
Search results relevance
