PiicoDev Distance Sensor VL53L1X - Raspberry Pi Pico Guide
Updated 09 July 2024
This guide will help you read distance data in millimeters from your PiicoDev® Distance Sensor and a Raspberry Pi Pico
Plug your Pico into the Expansion Board, connect your distance sensor to the Expansion Board via the PiicoDev cable, and finally connect your Pico to your computer with a USB lead.
connect-piicodev-distance-sensor-to-raspberry-pi-pico
Download MicroPython modules
We will need three files to easily read data from the Distance Sensor:
  • Download the device module: PiicoDev_VL53L1X.py (right-click, "save link as")
Example Code
Open Thonny, connect to your Pico and upload the three files (that we just downloaded) to your Pico. (Hint: View the files menu with View > Files)
Restart your Pico (Keyboard shortcut, Ctrl+D) and you should be seeing your Pico printing the distance it reads from the distance sensor.
piicodev-distance-sensor-demo-code
Above: Distance data streams up the Shell, while the Plot shows historic distance data. I move my hand back and forth in front of the sensor to create the wave pattern in the plot.
pi raspberry sensor distance pico piicodev vl53l1x
