How to Setup a Raspberry Pi Pico and Code with Thonny
Updated 23 April 2023
This guide will help you get started with the Raspberry Pi Pico and the Thonny Python IDE, which has out-of-the-box support for Micropython and Pico.
Install Thonny
Set up Thonny
Select Interpreter
REPL interface (Shell)
from machine import Pin
led = Pin(25, Pin.OUT)
led.toggle()
REPL Interface
LED On
Writing a Script
from time import sleep
n = 0;
    led.toggle()
    n = n + 1
    sleep(0.5)
Return to the REPL and press Ctrl+D (or use the Stop/Restart button) to restart your Pico. The LED should flash at a steady rate and the shell should begin printing multiples of thirteen.
Script Output
Installing a Package
An example of installing the micropython-servo libraryAn example of installing the micropython-servo library
