These step-up/step-down converters are a perfect way to regulate a DC voltage for your project's needs. Click on a product for datasheets and more.
Items 26-39 of 39
  1. 6V Step-Up/Step-Down Voltage Regulator S8V9F6
    SKU: POLOLU-4966 Brand: Pololu
    This synchronous switching step-up/step-down regulator efficiently produces 6 V from input voltages between 1.4 V and 16 V. (Note: minimum startup voltage...
    Delivered by Sep 10th
  2. 5V Step-Up/Step-Down Voltage Regulator S8V9F5
    SKU: POLOLU-4965 Brand: Pololu
    This synchronous switching step-up/step-down regulator efficiently produces 5 V from input voltages between 1.4 V and 16 V. (Note: minimum startup voltage...
    9 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  3. 3.3V Step-Up/Step-Down Voltage Regulator S8V9F3
    SKU: POLOLU-4964 Brand: Pololu
    This synchronous switching step-up/step-down regulator efficiently produces 3.3 V from input voltages between 1.4 V and 16 V. (Note: minimum startup...
    6 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  4. 150W DC-DC Converter 13.8V @ 10A
    SKU: CE07298 Brand: Core Electronics
    This is a waterproof DC-DC converter. With 8-40V DC input, it converts to 13.8V@10A which is an ideal supply for automotive components.
    $44.95 AUD, inc GST
    21 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  5. Adafruit TPS65131 Split Power Supply Boost Converter - +6~15 / -6V~-15V
    SKU: ADA6280 Brand: Adafruit
    Need those tricky split-rail voltages for your vintage electronics? The Adafruit TPS65131 Split Rail Boost Converter generates both positive and negative...
  6. 5V Step-Up/Step-Down Voltage Regulator S13V30F5
    SKU: POLOLU-4082 Brand: Pololu
    This powerful synchronous switching step-up/step-down regulator efficiently produces 5 V from input voltages between 2.8 V and 22 V. Its ability to ...
  7. 5V, 2A Step-Up/Step-Down Voltage Regulator S13V20F5
    SKU: POLOLU-4085 Brand: Pololu
    This powerful synchronous switching step-up/step-down regulator efficiently produces 5 V from input voltages between 2.8 V and 22 V. Its ability to...
  8. 5V, 1A Step-Up/Step-Down Voltage Regulator S13V10F5
    SKU: POLOLU-4083 Brand: Pololu
    4 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  9. 5V, 1.5A Step-Up/Step-Down Voltage Regulator S13V15F5
    SKU: POLOLU-4084 Brand: Pololu
  10. 3.3V Step-Up/Step-Down Voltage Regulator w/ Fixed 3V Low-Voltage Cutoff S9V11F3S5C3
    SKU: POLOLU-2873 Brand: Pololu
    The S9V11F3S5C3 switching step-up/step-down regulator efficiently produces a fixed 3.3 V (default) or 5 V (selectable) output whether it is higher or...
  11. 3.3V Step-Up/Step-Down Voltage Regulator w/ Adjustable Low-Voltage Cutoff S9V11F3S5CMA
    SKU: POLOLU-2871 Brand: Pololu
    The S9V11F3S5CMA switching step-up/step-down regulator efficiently produces a fixed 3.3 V (default) or 5 V (selectable) output whether it is higher or...
  12. 5V Step-Up/Step-Down Voltage Regulator w/ Adjustable Low-Voltage Cutoff S9V11F5S6CMA
    SKU: POLOLU-2870 Brand: Pololu
    The S9V11F5S6CMA switching step-up/step-down regulator efficiently produces a fixed 5 V (default) or 6 V (selectable) output whether it is higher or lower...
  13. 2.5-9V Fine-Adjust Step-Up/Step-Down Voltage Regulator S9V11MA
    SKU: POLOLU-2869 Brand: Pololu
    The S9V11MA switching step-up/step-down regulator efficiently produces a finely adjustable output between 2.5 V and 9 V whether it is higher or lower than...
  14. 2.5-9V Fine-Adjust Step-Up/Step-Down Voltage Regulator w/ Adjustable Low-Voltage Cutoff S9V11MACMA
    SKU: POLOLU-2868 Brand: Pololu
    The S9V11MACMA switching step-up/step-down regulator efficiently produces a finely adjustable output between 2.5 V and 9 V whether it is higher or lower...
