PiicoDev Pressure Sensor MS5637 - Micro:bit Guide
Updated 23 September 2021
This guide will help you read barometric pressure from your PiicoDev® Pressure Sensor and a Micro:bit
We'll program with Thonny in this tutorial. If you haven't used Thonny before, check out our guide for Programming a Micro:bit with Thonny. If you prefer, you can program your Micro:bit using python.microbit.org instead (see our guide).
Plug your Micro:bit into the PiicoDev adapter (buttons + LED matrix facing up), connect your motion sensor to the adapter via the PiicoDev cable and connect your Micro:bit to your computer with a USB lead.
If you're unfamiliar with connecting PiicoDev modules, read the PiicoDev Connection Guide before proceeding.
connect-piicodev-pressure-sensor-to-microbit
It will be best to keep this file wherever you like to keep your coding projects eg. Documents > PiicoDev
Example Code
We'll be working in Thonny - if you're unfamiliar working with Thonny see our guide for Thonny and Micro:bit.
Open Thonny, connect to your Micro:bit and upload the three files. (Hint: View the files menu with View > Files)
Restart your Micro:bit with keyboard shortcut, Ctrl+D and it should begin printing barometric pressure measurements in hectopascal, which is equivalent to millibar - a commonly used unit for describing barometric pressure: 1hPa = 100Pa = 1mbar.
piicodev-pressure-sensor-demo-code
Above: Pressure data streams up the Shell, while the Plot shows historic data.
Remix
Did you know you can also infer altitude from air pressure? Comment out the pressure print statement and uncomment the altitude print statement. Run the script again and now the Pico will infer altitude-above-sea-level from air pressure. There can be a bit of error here since your local weather conditions will affect the reading. You can optionally pass in the local air pressure at sea level to the read_altitude() function to correct for weather effects. You can find the current air pressure at sea level for your area with an internet search.
piicodev-pressure-sensor-ms5637-altitude-measurement-remix
We can now measure air pressure from our PiicoDev Pressure Sensor, and use it to infer altitude.
sensor pressure altimeter altitude barometric
