PiicoDev Ambient Light Sensor VEML6030 - Raspberry Pi Pico Guide
Updated 29 August 2021
This guide will help you read light intensity data from your PiicoDev® Ambient Light Sensor and a Raspberry Pi Pico
In the video we use a PiicoDev Platform to keep everything safe and secure.
Plug your Pico into the Expansion Board, connect your light sensor to the Expansion Board via the PiicoDev cable, and finally connect your Pico to your computer with a USB lead.
pico-veml6030-connections
It will be best to keep this file wherever you like to keep your coding projects eg. make a directory Documents > PiicoDev
Example Code
Open Thonny, connect to your Pico and upload the three files from the previous step.
Press Ctrl+D to restart your Pico and run the main script - light data should begin streaming up the shell
If you're unfamiliar with Thonny, read our setup guide.
piicodev-light-sensor-veml6030-example-raspberry-pi-pico
Above: Light data streams up the shell. The plotter shows historic light data, which starts at about 175lux, then ramps down as the sensor is gradually covered. Finally, the sensor is uncovered and the light data jumps back to ambient levels.
Now we can easily read light data with our Pico.
Tip: Open the Plotter (View > Plotter) to see a nice plot of your temperature data
Remix - Day/Night message
In the final part of the video, we modify the example code to keep track of whether it is day or night (bright/dark). When light data transitions between bright and dark, we can print an appropriate greeting eg. "Good Morning" or "Goodnight". You can use this structure for decision-making in your own projects - be sure to code along!
raspberry pi sensor light pico piicodev veml6030
