Getting Started with the xTool S1 | Unboxing to First Cut
In this guide, we will be unboxing and setting up the xTool S1, and walking through your very first cut using xTool Studio. We are going to cover the entire process, from getting the machine onto your bench and installing the laser head, t...
#setup #xtool
#setup #xtool
xTool F2 Ultra Setup Guide | Assembly and Calibration
In this guide, we are going to walk through the first-time setup for your xTool F2 Ultra so you can get cutting and engraving quickly! A quick but important note: consult your included instruction manual alongside this guide. The packagin...
#laser cutting #xtool #mopa laser
In this guide, we’re going to get you all the way from "I don’t know what a laser cutter is" to holding your very first custom creation cut on the xTool P3. We’re going to start with some important safety tips, look at ho...
In this guide, we will be setting up the xTool P3, a powerful CO2 laser cutter that tries to bring industrial level features to a desktop format and price tag, and we are going to walk through the entire assembly process, from putting toge...
In this guide, we will be taking a hands-on look at the xTool P3, an 80-watt CO2 laser cutter that aims to bring industrial capability to a desktop format and price tag. We are going to be exploring its features, and seeing how this deskto...
Laser Cut High Rise Case for the Arduino Uno
If you put a shield on top of an Arduino Uno there aren’t very many options available to protect it all inside a case. You can always make one yourself though, so that’s exactly what we did! This “High Rise” case for...
#arduino #laser #laser cut #arduino case #arduino uno #high rise #highrise #shield case #uno case
Making Boxes in Fusion 360 for Laser Cutting
When making a box with a laser cutter, its entirely possible to make your design as a single flat drawing through careful planning and measurement – but who wants to do that!? This is a guide to making a box quickly and easily using F...
#box #laser cutting #fusion 360 #laser cut #parameters
Using Slicer for Fusion360 for Laser Cutting
Laser cutting is a very fast production and manufacturing method that has one limitation. You can only cut flat surfaces! Well don’t let that stop you from creating 3D objects and sculptures with a laser cutter, Fusion360 has a great ...
#slicer #fusion360 #engraving #laser #laser cutting #3d modeling #slicer for fusion360
Convert an Image to a Vector Graphic for Laser Cutting
Interested in creating designs to be laser cut? In this tutorial, we will learn how to use Gimp and Inkscape to convert a graphic image to a vector image that you can cut on a laser cutter! In order for the job control software to turn you...
#graphic #laser #laser cutting #convert #gimp #inkscape #vector #vector graphic
Getting Started Guide for Laser Cutting
Welcome to the exciting world of laser cutting! For all those makers out there looking to start creating with a laser cutter, this tutorial will have the basic information you need to get started! We recently added a Laser Cutting Service t...
#cutting #ectching #engrave #engraving #etch #laser #laser cutting #service #services
