This Makeblock Vacuum Suction Cup is made from silicone, and adheres well to smooth surfaces like a windshield, mirror, window, or anything else that's clean and smooth...
Made from 6061 aluminum extrusion , 8mm thick, anodized surface. Compatible with MXL Timing Belt. Can also be used as a car wheel. Sold in Packs of 4. Size Charts(mm):...
Openlab In most cases ,when you buy some timing belts on the market, it is always not the size which you want or fixing open-end timing beltsis a big problem. Makeblock...
The chain can be used together with the sprocket for transmission of motion and power. Compared with synchronous belt, the chain can transmit more force and drive...
This linear motion shaft of 8 mm in diameter and 96mm in length is suitable for using as shaft or supporting part. It is made from high-carbon steel and chrome plated...
This is a 1.75" long JST SH communication cable which can be cut and hacked to your needs and can even be used as pigtails. This little guy can really help your GPS project if you don’t have a lot of space to spare! This cable has two a 6-pin JST connectors with 1mm pitch. Wired pin 1 to pin 1.
Let there be light(s)! This festive string of addressable RGB LEDs can add color to indoor or outdoor displays. Much like our addressable LED strips, this chain of lights is composed of 20 individually sealed 10mm RGB LEDs and drivers. The driver for this chain is our old friend, the WS-2801 constant current LED driver. The WS2801 is a common, well-supported driver and example code is available for various microcontrollers. The 2-wire control scheme allows you to control the entire chain over only two GPIOs and because data cascades across the drivers, you can chain as many of these together as you can power!
The GP2Y0A710K infrared sensor is a new version of GP2Y0A700K which takes a continuous distance reading and reports the distance as an analog voltage with a distance range of 1m (39.3") to 5.5m (216.5").
This is an awesome little microSD USB reader. Just slide your microSD card into the inside of the USB connector, then stick this into a USB port and the card’s contents will pop up on your computer. Very sneaky - we love it! This little guy is great for pulling data logs off microSD media. This reader also includes an indicator LED which will light up if a microSD card is present. This device is completely plug-and-play, so no drivers needed.
The ZM 0.3 Megapixel serial JPEG still camera module has a compact size, low power comsuption, and stable operation. 5.0V DC Supply. UART: Up to 115200bps for transferring JPEG images.
Last month, We released the UNO Base. A beautiful acrylic base for Arduino UNO. It's a nice gift for my UNO baby. It's a nice shoe, a good protection, an eye-catching killer. Then my UNO is extremely different to others.
An essential for working with slotted aluminum extrusion, these slim metal nuts slide into the ends of the extrusion. The oval shape means that as they screwed-into...
Website features/issues
Content errors/improvements
Missing products/categories
Product assignments to categories
Search results relevance
