Motor controllers consist of drivers, combined with logic circuits designed to handle higher-level interfaces such as serial, PWM, analog, and other common inputs.
Items 26-44 of 44
  1. Motoron M2H24v14 Dual High-Power Motor Controller for Raspberry Pi (Connectors Soldered)
    SKU: POLOLU-5051 Brand: Pololu Guides (1)
    The Motoron M2H24v14 Dual High-Power Motor Controller makes it easy to control DC motors from a Raspberry Pi (Model B+ or newer) through an I²C interface....
    1 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
    Delivered by Apr 7th
  2. Motoron M2U256 Dual Serial Motor Controller
    SKU: POLOLU-5067 Brand: Pololu
    The Motoron M2U256 Dual I²C Motor Controller offers a compact solution for controlling two DC motors using a UART serial interface. Multiple Motoron...
  3. Pololu H2 High-Power Motor Driver 36v11 CS
    SKU: POLOLU-2993 Brand: Pololu
    This discrete MOSFET H-bridge motor driver enables bidirectional control of one high-power DC brushed motor. The small 1.3" × 0.8" board supports a wide...
  4. RoboClaw 2x60AHV, 60VDC Motor Controller (V8)
    SKU: POLOLU-3688 Brand: Pololu
    The RoboClaw motor controllers from Basicmicro can control a pair of brushed DC motors using USB serial, TTL serial, RC, or analog inputs. Integrated dual...
  5. RoboClaw 2x60A Motor Controller (V8)
    SKU: POLOLU-3687 Brand: Pololu
  6. RoboClaw 2x15A Motor Controller (V6B)
    SKU: POLOLU-3683 Brand: Pololu
  7. High-Power Simple Motor Controller G2 24v12
    SKU: POLOLU-1365 Brand: Pololu
    This powerful motor controller makes basic control of a brushed DC motor easy, with quick configuration over USB using our free software. It supports five...
  8. Motoron M2S24v14 Dual High-Power Motor Controller Shield for Arduino (Connectors Soldered)
    SKU: POLOLU-5039 Brand: Pololu
    The Motoron M2S24v14 Dual High-Power Motor Controller Shield for Arduino makes it easy to control two high-power DC motors from an Arduino or...
  9. Motoron M2U256 Dual Serial Motor Controller (Header Pins Soldered)
    SKU: POLOLU-5066 Brand: Pololu
  10. Motoron M2T256 Dual I²C Motor Controller (Header Pins Soldered)
    SKU: POLOLU-5064 Brand: Pololu
    The Motoron M2T256 Dual I²C Motor Controller offers a compact solution for controlling two DC motors using an I²C interface. Multiple Motoron controllers...
  11. Motoron M1U256 Single Serial Motor Controller
    SKU: POLOLU-5063 Brand: Pololu
    The Motoron M1U256 Single I²C Motor Controller offers a compact solution for controlling two DC motors using a UART serial interface. Multiple Motoron...
  12. Motoron M1T256 Single I²C Motor Controller
    SKU: POLOLU-5061 Brand: Pololu
    The Motoron M1T256 Single I²C Motor Controller offers a compact solution for controlling one DC motor using an I²C interface. Multiple Motoron controllers...
  13. Motoron M1T550 Single I²C Motor Controller (Header Pins Soldered)
    SKU: POLOLU-5074 Brand: Pololu
    The Motoron M1T550 Single I²C Motor Controller offers a compact solution for controlling one DC motor using an I²C interface. Multiple Motoron controllers...
  14. Motoron M3H550 Triple Motor Controller for Raspberry Pi (Connectors Soldered)
    SKU: POLOLU-5071 Brand: Pololu
    The Motoron M3H550 Triple Motor Controller makes it easy to control DC motors from a Raspberry Pi (Model B+ or newer) through an I²C interface. Each...
  15. Motoron M3S550 Triple Motor Controller Shield for Arduino (Connectors Soldered)
    SKU: POLOLU-5068 Brand: Pololu
    The Motoron M3S550 Triple Motor Controller Shield for Arduino makes it easy to control DC motors from an Arduino or Arduino-compatible board through an...
  16. RoboClaw ST 2x45A Motor Controller (V6B, screw terminal I/O)
    SKU: POLOLU-3686 Brand: Pololu
  17. RoboClaw 2x7A Motor Controller (V6B)
    SKU: POLOLU-3682 Brand: Pololu
    6 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  18. Motoron M2U550 Dual Serial Motor Controller (Header Pins Soldered)
    SKU: POLOLU-5080 Brand: Pololu
    The Motoron M2U550 Dual I²C Motor Controller offers a compact solution for controlling two DC motors using a UART interface. Multiple Motoron controllers...
  19. Motoron M1U550 Single Serial Motor Controller (Header Pins Soldered)
    SKU: POLOLU-5076 Brand: Pololu
    The Motoron M1U550 Single I²C Motor Controller offers a compact solution for controlling one DC motor using a UART serial interface. Multiple Motoron...
