Micro SD cards are one of the most popular form factors for portable data storage thanks to their compact design, so we've got a few options for expanding your storage.
Items 26-39 of 39
  1. Adafruit QSPI DIP Breakout Board - W25Q64 - 64 MBit 8 MByte - W25Q64JVSSIQ
    SKU: ADA5633 Brand: Adafruit
    For many modern and powerful chips like the RP2040, ESP32, RT10xx, and STM32 series microcontrollers, designers can save money and reduce the number of...
    Available with 7 to 12 day lead time
  2. Adafruit QSPI DIP Breakout Board - W25Q128 - 128 MBit 16 MByte - W25Q128JVSSIQ
    SKU: ADA5634 Brand: Adafruit
    Delivered by Dec 6th
  3. Adafruit SPI FLASH Breakout - W25Q16 - 16 Mbit / 2 MByte
    SKU: ADA5635 Brand: Adafruit
    Sometimes you need a little extra storage for your microcontroller projects: for files, images, fonts, audio clips, etc. If you need lots of space, like...
  4. Adafruit SPI FLASH Breakout - W25Q64 - 64 MBit / 8 MByte
    SKU: ADA5636 Brand: Adafruit
  5. Adafruit SPI FLASH Breakout W25Q128 - 128 MBit / 16 MByte
    SKU: ADA5643 Brand: Adafruit
  6. microSD Adapter
    SKU: CE09444 Brand: Core Electronics
    If you need to load or store large amounts of data, look no further than this 3.3V SPI microSD card module.
    31 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  7. Crucial P3 500GB Gen4 NVMe SSD
    SKU: CE09887 Brand: Core Electronics
    4700/1900 MB/s R/W 110TBW 350K/460K IOPS 1.5M hrs MTTF Full-Drive Encryption M.2 PCIe4
    20 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  8. Corsair Force MP600 MICRO 1TB M.2 2242 NVMe SSD
    SKU: CE09888 Brand: Core Electronics Guides (1)
    5100/4300MB/s 600K/890K 600TBW 1.5M MTTF
    17 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  9. Western Digital Blue M.2 NVME SSD 250GB
    SKU: CE09917 Brand: Western Digital
    Ideal for Raspberry Pi and other SBCs using an NVME expansion
  10. Slimline USB 3.0 7 Port Hub
    SKU: CE08387 Brand: Core Electronics
    Breaks out USB 3.0 functionality to 7 ports.
    3 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  11. RasPiKey: Plug And Play EMMC Module For Raspberry Pi - 16GB - 16GB
    SKU: CE08414 Brand: The Pi Hut
    RasPiKey is a 16GB or 32GB (select version above) eMMC module which can be inserted into your Raspberry Pi’s Micro SD card slot. It works like a micro SD...
    5 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  12. SanDisk USB 3.0 MobileMate MicroSD Reader/Writer for MicroSD cards
    SKU: CE08436 Brand: Core Electronics
    A super fast microSD card reader for all of your Maker needs!
    15 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  13. Western Digital Green M.2 SATA SSD 240GB
    SKU: CE08440 Brand: Western Digital Guides (1)
    Fast Performance and Reliability to Boost Your Everyday Computing Experience in Your Desktop or Laptop PC with a 240GB M.2 SATA drive.
    14 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  14. MicroSD Card 4GB Class 10 With Adapter
    SKU: CE08668 Brand: Core Electronics
    The perfect size for embedded and datalogging projects.
    393 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
