Every project needs some quality stranded wire for connecting modules and components. We've got different gauges, as well as silicon and PVC insulation.
Nothing is going to be as thin and flexible as this wire - it feels a little like waxed thread but can carry current! You could use this in wearables or very fine assemblies where weight and bulk is at a premium.
Silicone-sheathing wire is super-flexible and soft, and its also strong! Able to handle up to 200°C and up to 600V, it will do when PVC covered wire wimps out. Adafruit like this wire for being extremely supple and flexible, so it is great for wearables or projects where the wire-harness has to be able to deal with a lot of bending.
This is a box of ten 25ft spools of stranded-core wire. Stranded-core wire is best used for wiring jigs where there's bending or movement expected. It also works...
This is a box of ten 25ft spools of solid-core wire. The wire is easy to solder to, and when bent it keeps its shape pretty well. Adafruit like to have a few spools of...
This is a spool with 60 feet of black 24 AWG stranded copper hook-up wire. It conforms to the UL1007 specification and is rated for up to 80°C and 300 VAC.
This is a spool with 50 feet of yellow 22 AWG stranded copper hook-up wire. It conforms to the UL1007 specification and is rated for up to 80°C and 300 VAC.
Website features/issues
Content errors/improvements
Missing products/categories
Product assignments to categories
Search results relevance
