Light Sensing with an LDR and Pycom
Updated 18 March 2022
One of the simplest sensors in any makers toolkit is a light sensor or LDR. An LDR works by changing its resistance from 1k ohm to 10K ohm depending on how much light is striking it. In this tutorial, we will show you how to use one with a Pycom Lopy4 and transmit your readings to TTN via LoRaWAN!
The Circuit
An LDR needs to be used with a 10k ohm resistor. This drops the voltage down to a level easily interpreted by the ADC on the Lopy4. We want to see values about the middle of the range when in a normally lit room. The Pycom Lopy4 has 12-bit ADC, so the maximum reading will be 4096. We will be using the Pycom Expansion Board 3.0 and the Lopy4, but any Pycom board will work! If you are connecting to your Pycom board directly refer to the relevant pinout diagram.
Pycom-lopy4-expansionboard-ldr-schematic
The following code takes light measurements every ten seconds, and then sends them to The Things Network via LoRaWAN
# Measuring light with an LDR
from network import LoRa
import socket
import utime
import binascii
import pycom
import ustruct
import machine
from machine import Pin
adc = machine.ADC()               # create an ADC object
apin = adc.channel(pin=Pin.exp_board.G31) # Lopy4 specific: (pin = 'P17')   create an analog pin on P17 & connect TMP36
# Light measurment
def light_measure():
    print("")
    print("Reading LDR Sensor...")
    value = apin()
    print("ADC count = %d" %(value))
    # LoPy  has 1.1 V input range for ADC
    light = value
    print("light = %5.1f" % (light))
    return light
pycom.heartbeat(False)
# set LED to red
pycom.rgbled(0x7f0000)
# lora config
# access info
app_eui = binascii.unhexlify('XXXXXXXX')
app_key = binascii.unhexlify('XXXXXXXXXXXXXXXXXXXXXXXX')
# wait for a connection
while not lora.has_joined():
	utime.sleep(1)
	if utime.time() > 15:
		print("possible timeout")
		machine.reset()
	pass
pycom.rgbled(0x004600)
print('Network joined!')
# setup the socket
s.setblocking(False)
s.bind(1)
count = 0
while count < 200:
	# take light measurment, turn the light blue when measuring
	pycom.rgbled(0x00007d)
	utime.sleep(1)
	light = light_measure()
	print("light:  ", light)
	# could be extended like this struct.pack('f', light) + struct.pack('c',"example text")
    # 'h' packs it into a short, 'f' packs it into a float, must be decoded in TTN
	packet = ustruct.pack('h', light)
	s.send(packet)
	print ("Unpacked value is:", ustruct.unpack('h',packet)[0])
	rx_pkt = s.recv(64)
	if len(rx_pkt) > 0:
		pycom.rgbled(0xffa500)
	count += 1
	utime.sleep(10)
Decoding the Payload
Now we have our data arriving in The Things Network as payloads, but we need to decode them! Under Payload Formats in TTN we will use the following javascript code to decode our payloads:
function Decoder(bytes, port) {
  // Decode an uplink message from a buffer
  // (array) of bytes to an object of fields.
  var decoded = {};
  // Decode bytes to int
  var testShort = (bytes[1] << 8) | bytes[0];
  // Decode int
  decoded.Light = testShort;
  return decoded;
Going Further
If you want to learn more about Pycom check out our Pycom Tutorials. If you want to learn more about connecting to The Things Network and using LoRaWAN check out our The Things Network Tutorials. There are many more sensors and devices that can be used with the Pycom Lopy4, get out there and experiment!
