PiicoDev Magnetometer QMC6310 - Guide for MicroBit
Updated 13 January 2025
This guide is for the previous revision of the PiicoDev Magnetometer QMC6310 - if you have the latest revision featuring the MMC5603 - head to the guide for updated links and instructions.
Let's get started with the PiicoDev® Magnetometer. In this guide, we'll connect the Magnetometer to our micro:bit, get it working as a compass, and read the magnetic field strength of a nearby magnet.
Connect the Magnetometer to your MicroBit
Plug your micro:bit into the Adapter - make sure the buttons are facing up, as shown in the picture below. Connect your magnetometer to the Adapter via the PiicoDev cable, and finally connect your micro:bit to your computer with a USB lead.
connect-piicodev-magnetometer-to-raspberry-micro-bit
Download MicroPython modules
  • Download the device module: PiicoDev_QMC6310.py (right-click, "save link as")
  • Download the example script: compass.py (right-click, "save link as" and save as "main.py")
Example 1 - Compass and Calibration
We'll be working in Thonny - if you're unfamiliar working with Thonny see our guide for getting started with Thonny and MicroBit.
Open Thonny, connect to your micro:bit and navigate to where you stored the files from the last step. Right-click each file and select "Upload to /" to upload them to your micro:bit (Hint: View the files menu with View > Files)
Open main.py and run the script (click the Green Play Button, or Ctrl+R). You will be prompted to calibrate the magnetometer: Slowly rotate the sensor on a flat surface until calibration is complete. You can see the calibration progress shown by a progress bar in the shell.
piicodev-magnetometer-qmc6310-calibration
Once calibration is complete, your micro:bit will begin printing the measured heading into the shell. This is the same heading that you would read off a magnetic compass. The heading is the direction the top edge (with the PiicoDev label) of the module is pointing when placed on a level surface like a table.
piicodev-magnetometer-qmc6310-heading-example
piicodev-magnetometer-qmc6310-heading-compare
You may notice a new file named calibration.cal has appeared on your micro:bit - this is the calibration data. This calibration data will be automatically loaded every time the script runs, so you can comment-out compass.calibrate() if you don't want to calibrate on every power-up. It's still a good idea to calibrate periodically, or if you notice your heading has drifted.
Remix - True North
So far we have been working with Magnetic North - this is the direction a magnetic compass will point. To find a true heading, we need to input some more information. Magnetic Declination is the difference between Magnetic North and True North (or "Geographic North"). The value for declination changes depending on location. In Newcastle, Australia, the declination is about 12° (as of 2022). There are lots of online tools that will help you find the declination in your area (here's one example). Once you know the declination in your area, you can input that angle into the setDeclination() function. Re-run your script and you should notice the heading data has been offset slightly. Your magnetometer is now indicating its measurement for True North.
Example 2 - Detect a Magnet
In this example, we'll measure magnetic-field-strength. This is useful to detect the presence of a nearby magnet. Replace the code in main.py with the following code.
magSensor = PiicoDev_QMC6310(range=3000) # initialise the magnetometer
threshold = 120 # microTesla or 'uT'.
    strength = magSensor.readMagnitude()   # Reads the magnetic-field strength in microTesla (uT)
    myString = str(strength) + ' uT'       # create a string with the field-strength and the unit
    print(myString)                        # Print the field strength
    if strength > threshold:               # Check if the magnetic field is strong
        print('Strong Magnet!')
    sleep_ms(1000)
A note about calibration: In Example 1 we performed a 2-axis calibration (rotating the magnetometer on a flat surface. For best results in this example a 3-axis calibration is necessary. To calibrate 3-axes, call the calibrate() function, and rotate the device slowly in all axes.
piicodev-magnetometer-qmc6310-field-strength
Example 3 - Raw Data
# Prints the raw axis readings in micro-Tesla
magSensor = PiicoDev_QMC6310() # Initialise the sensor (defaults to range=3000uT)
magSensor.setRange(1200)
    print(raw_data)             # Print the data
    sleep_ms(200)
We can measure the properties of magnetic fields using a 3-axis magnetometer. Built-in functions allow us to easily measure the sensor's heading in a magnetic field, and we've even been able to use the magnetometer like a compass.
If you make something cool with this starter project we'd love for you to share it on our forums! And if you'd like some help with this guide, start the conversation below - We're full-time makers and here to help!
Resources
Magnetometer Library: PiicoDev Unified MicroPython module for QMC6310
OLED Library: PiicoDev Unified MicroPython module for SSD1306
compass field hall magnet
