We've put together a collection of basic wheels that are great for general robotics, no matter how big or small your robot may be.
Items 26-50 of 52
  1. Pololu Wheel for Standard Servo Splines (25T, 5.8mm) - 90×10mm, Red, 2-Pack
    SKU: POLOLU-4936 Brand: Pololu
    These red plastic wheels have silicone tires and measure 90 mm (3.54") in diameter. They mount onto standard servo splines with 25 teeth and a 5.8 mm...
  2. Pololu Wheel for Standard Servo Splines (25T, 5.8mm) - 70×8mm, White, 2-Pack
    SKU: POLOLU-4929 Brand: Pololu
    These white plastic wheels have silicone tires and measure 70 mm (2.75") in diameter. They mount onto standard servo splines with 25 teeth and a 5.8 mm...
    Special Price $12.84 AUD, inc GST
    Regular Price $15.10 AUD, inc GST
    Delivered by Mar 9th
  3. Pololu Wheel for Standard Servo Splines (25T, 5.8mm) - 70×8mm, Red, 2-Pack
    SKU: POLOLU-4926 Brand: Pololu
    These red plastic wheels have silicone tires and measure 70 mm (2.75") in diameter. They mount onto standard servo splines with 25 teeth and a 5.8 mm...
  4. Pololu Wheel for Micro Servo Splines (20T, 4.8mm) - 60×8mm, White, 2-Pack
    SKU: POLOLU-4914 Brand: Pololu
    These white plastic wheels have silicone tires and measure 60 mm (2.36") in diameter. They mount onto micro servo splines with 20 teeth and a 4.8 mm...
  5. Pololu Wheel for Micro Servo Splines (20T, 4.8mm) - 60×8mm, Red, 2-Pack
    SKU: POLOLU-4911 Brand: Pololu
    These red plastic wheels have silicone tires and measure 60 mm (2.36") in diameter. They mount onto micro servo splines with 20 teeth and a 4.8 mm...
  6. Pololu Wheel for Micro Servo Splines (20T, 4.8mm) - 40×7mm, White, 2-Pack
    SKU: POLOLU-4909 Brand: Pololu
    These white plastic wheels have silicone tires and measure 40 mm (1.57") in diameter. They mount onto micro servo splines with 20 teeth and a 4.8 mm...
  7. Pololu Wheel for Micro Servo Splines (20T, 4.8mm) - 40×7mm, Red, 2-Pack
    SKU: POLOLU-4906 Brand: Pololu
    These red plastic wheels have silicone tires and measure 40 mm (1.57") in diameter. They mount onto micro servo splines with 20 teeth and a 4.8 mm...
  8. Pololu Wheel for Standard Servo Splines (25T, 5.8mm) - 70×8mm, Black, 2-Pack
    SKU: POLOLU-4925 Brand: Pololu
    These black plastic wheels have silicone tires and measure 70 mm (2.75") in diameter. They mount onto standard servo splines with 25 teeth and a 5.8 mm...
  9. Pololu Wheel for Micro Servo Splines (20T, 4.8mm) - 60×8mm, Black, 2-Pack
    SKU: POLOLU-4910 Brand: Pololu
    These black plastic wheels have silicone tires and measure 60 mm (2.36") in diameter. They mount onto micro servo splines with 20 teeth and a 4.8 mm...
  10. Pololu Wheel for Micro Servo Splines (20T, 4.8mm) - 40×7mm, Black, 2-Pack
    SKU: POLOLU-4905 Brand: Pololu
    These black plastic wheels have silicone tires and measure 40 mm (1.57") in diameter. They mount onto micro servo splines with 20 teeth and a 4.8 mm...
  11. Scooter/Skate Wheel 200×30mm - Black
    SKU: POLOLU-3283 Brand: Pololu
    This black polyurethane scooter/skate wheel measures 200 mm (7.9") in diameter and 30 mm (1.2") in width and works with standard 608 bearings as well as...
    1 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  12. Scooter Skate Wheel 144×29mm - Black
    SKU: POLOLU-3281 Brand: Pololu
    This black polyurethane scooter/skate wheel measures 144 mm (5.7") in diameter and 29 mm (1.2") in width and works well with standard 608 bearings
  13. Scooter/Skate Wheel 100×24mm - Black
    SKU: POLOLU-3278 Brand: Pololu
    This black polyurethane scooter/skate wheel measures 100 mm (3.9") in diameter and 24 mm (1") in width and works with standard 608 bearings as well as our...
  14. Scooter/Skate Wheel 84×24mm - Black
    SKU: POLOLU-3275 Brand: Pololu
    This black polyurethane scooter/skate wheel measures 84 mm (3.3") in diameter and 24 mm (1") in width and works with standard 608 bearings as well as our...
  15. Scooter/Skate Wheel 70×25mm - Black
    SKU: POLOLU-3272 Brand: Pololu
    This black polyurethane scooter/skate wheel measures 70 mm (2.75") in diameter and 25 mm (1") in width and works with standard 608 bearings as well as our...
  16. Pololu Wheel 40×7mm Pair - White
    SKU: POLOLU-1454 Brand: Pololu
    These white plastic wheels have silicone tires and measure 40 mm (1.57") in diameter, and they press-fit onto the 3mm D shafts on many of our motors,...
  17. Pololu Wheel 40×7mm Pair - Red
    SKU: POLOLU-1453 Brand: Pololu
    These red plastic wheels have silicone tires and measure 40 mm (1.57") in diameter, and they press-fit onto the 3mm D shafts on many of our motors,...
  18. Pololu Wheel 40×7mm Pair - Black
    SKU: POLOLU-1452 Brand: Pololu
    These black plastic wheels have silicone tires and measure 40 mm (1.57") in diameter, and they press-fit onto the 3mm D shafts on many of our motors,...
  19. Red Robot Wheels (pair)
    SKU: CE08422 Brand: The Pi Hut
    A pack of 2x red robot wheels for your next robotics project. These are the same red wheels we ship with our Edukit robotics kit, and fit the same style...
    4 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  20. Wheel for Micro Continuous Rotation FS90R Servo
    SKU: ADA2744 Brand: Adafruit
    Adafruit are keepin' it wheel with this one! Need a great drive solution for your little robotic friends? This black plastic Micro Continuos Rotation Servo Wheel is equipped...
    Available with 7 to 12 day lead time
  21. Skinny Wheel for TT DC Gearbox Motors
    SKU: ADA3757 Brand: Adafruit
    Plastic gear-box motors (also known as 'TT' motors) are an easy and low cost way to get your projects moving. But Adafruit have noticed that there are not a lot of nice...
  22. Orange and Clear TT Motor Wheel for TT DC Gearbox Motor
    SKU: ADA3766 Brand: Adafruit
    Usually when one needs an orange wheel it's a garnish for a cocktail, like a tasty Sidecar. And speaking of cars, this wheel is for driving, not drinking! Need a...
  23. 4-Bar Odometry Pod (32mm Wheel)
    SKU: GB-3110-0001-0002 Brand: goBilda
    Help your robot find its way with the goBILDA® 4-Bar Odometry Pod! It’s a precisely-designed sensor that ups the accuracy of localization.....
    Available with 14 to 21 day lead time
  24. ACEBOTT Tank Tread Expansion pack for Smart Car
    SKU: CE10165 Brand: ACEBOTT
    Take your ACEBOTT ESP32 Smart Car off-road!
  25. Finnboard Motor Discs (wheels) for Craft & Code, Refill pack of 50
    SKU: KT-56131 Brand: Kitronik
    Replacement pre-cut finnboard pieces for the Kitronik Craft and Code kits, a lesson in a box and single versions. Supplied as a pack of 50....
    Available with 8 to 10 day lead time
