Here are some other tips for your uGateway:
We recommend you update the Raspberry Zero password - we've left it as default so you can make changes without a fuss.
There is a folder on the Raspberry Pi Desktop with service scripts inside. You can change the region by running region-select.sh (it will allow selections between AS923 and AU915, we recommend AS923 unless your TTN community is already committed to AU915).
If you want to setup the device in your own TTN Console, then email us a reply to your order email along with the last 6 digits of your Gateway EUI (which is shown when region-select.sh is run). Also include your TTN username in the email. We’ll transfer the Gateway to your TTN account.
The service script update.sh will run on power-up to check for updates. uGateway is already rock-solid from our testing, though we’ll use this mechanism to make updates a breeze.
To monitor statistics on your uGateway visit this URL (where "xxxxxx" are the last 6 digits of your Gateway EUI in lowercase):
http://noc.thethingsnetwork.org:8085/api/v2/gateways/eui-b827ebfffexxxxxx
For example http://noc.thethingsnetwork.org:8085/api/v2/gateways/eui-b827ebfffe08c9aa
We’re here to help – post a question in our maker forum and we’ll dive in to get you back on track!
