PiicoDev Ultrasonic Rangefinder | Getting Started Guide
Updated 22 May 2023
Similar to how bats echo-locate and how submarines use sonar, the PiicoDev® Ultrasonic Rangefinder uses sound waves to measure the distance to an object. It sends out a high-pitched sound wave, which bounces off of the object and comes back to the sensor. The time it takes for the sound wave to go out and come back is used to calculate the distance to the object. Think of it like shouting and listening for an echo! By knowing how long it takes for the echo to come back, we can calculate how far away the object is.
Distance data can be used in all kinds of creative ways! Plenty of consumer devices use distance data to determine the presence of humans or obstacles - things like non-contact faucets which can control the flow of water if hands are present in a wash sink; or vehicle detectors in parking garages that indicate if a parking space is vacant.
This guide will walk through connecting a PiicoDev Ultrasonic Rangefinder to a dev. board and provide some example code to get started taking distance measurements. There's even some project inspiration further down. Let's jump in!
  • Hardware and Connections
  • Setup Thonny
  • Download / Install PiicoDev Modules
  • Measure Distance
  • Code Remix - Proximity Alert
  • Multiple Rangefinders on the same PiicoDev Bus
  • Conclusion
  • Resources
  • Project Ideas
To follow along you'll need:
First, make sure your PiicoDev Ultrasonic Rangefinder is assembled correctly. Plug the ultrasonic ranger into the 4-pin female header on the PiicoDev module such that it points outwards. Be careful here - If you connect the ranger incorrectly both it and the PiicoDev module may become damaged.
Make sure all the ID switches are OFF before proceeding.
Plug your Pico into the Expansion Board. Make sure it is installed in the correct orientation - Pin 0 on the expansion board should be adjacent to the Pico's USB connector.
Connect your PiicoDev Ultrasonic Rangefinder to the expansion board with a PiicoDev Cable.
Mount the Adapter onto your Pi's GPIO. Make sure it is plugged in the correct orientation - An arrow on the Adapter will point to the Pi's Ethernet connector (on a Pi 3 the Ethernet connector and USB ports are swapped.)
Connect your PiicoDev Ultrasonic Rangefinder to the Adapter with a PiicoDev Cable.
Plug your micro:bit into the Adapter, making sure the buttons on the micro:bit are facing up.
Setup Thonny
Select your dev board from the tabs above to get ready for programming with Thonny for the first time.
If you have already programmed with PiicoDev modules before, there's probably no need to follow these steps again.
Install Thonny
Set up Thonny
Select Interpreter
REPL interface (Shell)
from machine import Pin
led = Pin(25, Pin.OUT)
led.toggle()
REPL Interface
LED On
Writing a Script
from time import sleep
n = 0;
    led.toggle()
    n = n + 1
    sleep(0.5)
Return to the REPL and press Ctrl+D (or use the Stop/Restart button) to restart your Pico. The LED should flash at a steady rate and the shell should begin printing multiples of thirteen.
Script Output
Installing a Package
An example of installing the micropython-servo libraryAn example of installing the micropython-servo library
Good news! Thonny comes pre-installed with Raspberry Pi OS. However, to work with PiicoDev we need to enable I2C communications as follows:
  • Power on your Raspberry Pi.
  • Open the Preferences > Raspberry Pi Configuration, select the Interfaces tab
  • Ensure I2C is Enabled
Let's get set up with scripting in Thonny for the Micro:bit. We'll install Thonny, configure for Micro:bit, and write our first script.
All you'll need to follow along is a Micro:bit v2 GO kit
Install Thonny
Download Thonny here and run the installer.
Set up Thonny
Open Thonny, and in the menu bar find Run > Select interpreter and choose MicroPython (BBC micro:bit)
select-microbit-interpreter-in-thonny
Click the red STOP button to restart the MicroPython on your micro:bit if necessary. The Shell tab should display a block of text that indicates MicroPython is running:
thonny-shell-restarted
from microbit import *
import audio
audio.play(Sound.HAPPY)
microbit-thonny-repl-play-audio
Writing a Script
The REPL is great for test-driving some new commands and performing short experiments - the real power is in scripting though.
import audio
print("Hello!")
        display.show(Image.HAPPY)
        display.clear()
Return to the REPL and press Ctrl+D to restart your micro:bit. If something went wrong, use the Stop/Restart button, then Ctrl+D.
Now, when we press the A button, the Shell will print the next multiple of 13, or if we press the B-button, our micro:bit gives us a smile and a hello sound.
thonny-example-script-for-microbit
  • The Blue line is the constant 13,
  • The Orange Line is the multiple variable that increases slowly, and
  • The Red line is the result variable, which increases really quickly.
Useful Tips
  • You can stop a running script by selecting the Shell window and pressing Ctrl+C. This is useful if we want to make changes to the file(s) stored on the micro:bit.
  • Reboot your micro:bit (or other MicroPython device) by selecting the Shell window and pressing Ctrl+D
  • If something goes wrong, you can always click the red STOP button in the menu bar
Uploading and Downloading Files
download-script-from-microbit-to-computer
If you have any questions feel free to start the conversation below or open a topic in our forums - we're full-time makers and happy to help!
Install Thonny
Set up Thonny
import audio
Writing a Script
import audio
print("Hello!")
        display.clear()
Useful Tips
We need these files to easily drive the PiicoDev Ultrasonic Rangefinder:
  • Save the following files to your preferred coding directory - In this tutorial, we save to My Documents > PiicoDev.
  • Upload the files to your Pico. This process was covered in the Setup Thonny section.
The PiicoDev Unified Library is responsible for communicating with PiicoDev hardware, and the device module contains functions for driving specific PiicoDev devices.
We will now install/upgrade the PiicoDev python module for Thonny. This module contains all the drivers to work with all current PiicoDev hardware. Even if you have already installed the PiicoDev modules before, it's still worth upgrading to the latest version if one is available.
First, run Thonny by clicking the:
  1. Pi Start Menu
  2. Programming
  3. Thonny IDE
We need to set up a virtual environment to install the PiicoDev module into. This only needs to be done once as Thonny will remember an environment you have already made. If you are unsure if you have already set one up, you can always create a new one by following these steps.
To set up a virtual environment, click on run  > configure interpreter, to open up the interpreter tab.
In this window, we can create a new virtual environment in the bottom right. A notification window will first pop up, just click OK.
In this window, we are going to create a new empty folder in our Home Directory which will be the location of our virtual environment. To do so follow these steps:
  1. Select the Home tab on the left-hand side of the window.
  2. Click the Create Folder button in the top right.
  3. Enter the name of the new folder. You can call it what you want, but we will call ours "myenv". Once you have written the name, click Create next to it.
  4. Click OK in the bottom left.
Thonny will then set up your virtual environment and when it has finished, it will return to the Interpreter tab. Click OK, and you will have successfully set up the environment.
Note: the Python Executable path now points to the environment we just created.
Remember, you only need to do this once as the next time you open Thonny it will use this environment.
Next, open the package manager. From within Thonny click Tools > Manage Packages
Enter "piicodev" and click "Search on PyPI"
Finally, Install PiicoDev. If you already have PiicoDev installed, there may be an Upgrade button instead, to upgrade to a newer version.
With the PiicoDev module installed we are now ready to begin programming with PiicoDev hardware.
  • Upload the files to your micro:bit. This process was covered in the Setup Thonny section.
Measure Distance
The PiicoDev Ultrasonic Rangefinder samples distance continuously at a constant rate. You can read the latest sample from the .distance_mm attribute (or .distance_inch if you prefer imperial).
The following code is a minimal example for reading data from the Rangefinder, and controlling its onboard LED.
# Read distance from the PiicoDev Ultrasonic Rangefinder
from PiicoDev_Ultrasonic import PiicoDev_Ultrasonic
ranger = PiicoDev_Ultrasonic() # Initialise the rangefinder
    print(ranger.distance_mm)
    ranger.led = not ranger.led # blink the LED every loop
    sleep_ms(100)
As I move my hand back and forth the distance measurement changes. This image shows a Micro:bit but the experience is the same for all dev. boards.
Let's do a quick code remix - we can modify the above example so that the Rangefinder's LED is only illuminated when the measured range is less than 100mm.
The .led attribute can be set to either True or False. Rather than toggle the LED every loop like the previous example, we can set .led to the result of an expression:
(ranger.distance_mm < 100) will evaluate as True whenever the measured distance is less than 100mm, else it will evaluate as False. This is a pretty compact way of including the functionality we desire without having to create a new variable or using an if statement.
# Turn on the LED when range is less than 100mm
    ranger.led = (ranger.distance_mm < 100)
    sleep_ms(100)
    sleep_ms(100)
Let's do a quick code remix - we can modify the above example to create an audible alert whenever the range is less than 100mm.
To do this we can import the music package and use the .pitch method to play a tone.
# Make an audible proximity alert
import music
    if ranger.distance_mm < 100:
        music.pitch(880, 100) # play a 880Hz tone for 100ms
    sleep_ms(100)
It's possible to connect multiple PiicoDev Ultrasonic Rangefinders on the same PiicoDev bus, though beware! These sensors are quite capable of interfering with each other if pointed together, or at the same object - so consider the path reflected sound may take.
Begin by setting a unique ID for each module. The ID switches are located in the centre of the module. Use a fine pen or similar instrument to set the ID switches as shown in the image below.
In the initialisation code, we will use the id argument to differentiate the Rangefinders. id is a list that encodes the ID switch positions; 1=ON and 0=OFF.
  • The first rangefinder (range_a) will have all its ID switches off, and will be initialised with the argument id=[0,0,0,0]
  • The second rangefinder (range_b) will have ID 1,3 ON and the rest off, and will be initialised with the argument id=[1,0,1,0]
The following example shows how to sample two ranges independently.
# Read distance from two PiicoDev Ultrasonic Rangefinders independently
range_a = PiicoDev_Ultrasonic(id=[0,0,0,0])
range_b = PiicoDev_Ultrasonic(id=[1,0,1,0]) # id argument must match ID switch positions
    print(range_a.distance_mm, range_b.distance_mm)
    sleep_ms(100)
Note: ID switches are how PiicoDev abstracts away I2C Addressing - you don't have to remember the address if you can just read the switch positions.
If you prefer to work with actual addresses instead, the following table shows the relationship between ID Switches and I2C Addresses.
Sample Period
The sample period (milliseconds) can be updated by setting the .period_ms attribute which accepts integers between 0 (disabled) and 65335. The default value is 20.
Most users won't need to change the default sample period, but the option is available and useful if you also wish to enable/disable the sensor.
ranger.period_ms = 1000 # sample once per second
ranger.period_ms = 0 # disable the sensor entirely
print(ranger.period_ms) # query and display the sample period
For longer sample periods, you may want to poll the Rangefinder status and only read new ranges when they become available (instead of reading out the same data multiple times). For this, you can check the .new_sample_available attribute. The following example sets the sample period to 1000ms, and checks for a new sample every 100ms. Each sample is printed exactly once.
# Only read the Rangefinder when a new sample is available
ranger.period_ms = 1000 # set a slow sample period
    if ranger.new_sample_available:
    sleep_ms(100)
It's pretty amazing to be able to measure distance so easily! Check out the project ideas featured below if you'd like some inspiration of what useful and creative projects you can complete with an Ultrasonic Rangefinder. If you have any questions or need some help, start the conversation below. We're full-time makers and happy to help.
Happy making!
Resources
This guide has taken every care to document the PiicoDev Ultrasonic Rangefinder to be useful for most makers. If you really want to look under the hood and explore the hardware and software, we've provided these additional resources.
Project Ideas
This invisible tripwire project is a flexible starter project with loads of applications. You could set it up to range across a doorway - when somebody passes through the door a message is displayed. This is a useful starter project for other range-alert style projects - for example, you could create an invisible limbo-bar that tells you when somebody didn't limbo low enough!
The project is self-calibrating, meaning you don't have to manually set any range thresholds. The tripwire will adapt to a steady-state range, and if it detects any sudden, large errors in the range measurement a trip event is reported. This is handled by continuously updating an average range (using exponential smoothing). A trip event occurs when any one range sample deviates too far from the average.
# A self-calibrating tripwire that looks for gross changes in distance
# Slowly calibrates for new distances - no manual tuning required.
tuning = 0.1                   # a tuning parameter that affects how quickly new distances are calibrated
sensitivity = 50               # [mm] any change greater than this amount will count as a trip
average = ranger.distance_mm   # Initialise the moving average with a range sample
sleep_ms(1000)
    distance = ranger.distance_mm
    print(distance, average)
    # check if the wire has been tripped
    if abs(average - distance) > sensitivity:
        print("Trip!")
        ranger.led = True # Indicate a trip
        ranger.led = False
    # update the moving average https://en.wikipedia.org/wiki/Exponential_smoothing
    average = tuning * distance + (1 - tuning) * average
    sleep_ms(100)
A theremin is a musical instrument controlled without physical contact. Real theremins use changing electric fields to control the sound output - here we can use the hands proximity to the Ultrasonic Rangefinder. Hold your hand closer to produce lower notes, and farther away to produce higher notes.
This project requires a PiicoDev Buzzer, and the PiicoDev_Buzzer.py module.
# A non-contact musical instrument. Hold your hand near the rangefinder and move
# closer or farther to play different notes.
from PiicoDev_Buzzer import PiicoDev_Buzzer
buzzer = PiicoDev_Buzzer()
def get_note_from_distance(distance):
    """Converts a distance [mm] to a note [Hz] from a supplied scale"""
    scale_Hz = [523, 587, 659, 698, 784, 880, 988, 1047] # Cmajor scale
    note_number = round( (distance - 100) / 50 ) # spaces notes 50mm apart, starting 100mm away from the rangefinder
    # make sure the note stays within bounds
    if 0 <= note_number < len(scale_Hz):
        return scale_Hz[note_number]
        return 0 # silence if not being actively played
note_duration = 250 # [ms]
    note = get_note_from_distance(distance)
    buzzer.tone(note, note_duration)
    print(distance, note)
    sleep_ms(note_duration)
This project uses the plotter in Thonny to draw a simple obstacle-avoiding, 2D-scrolling game - similar to Flappy Bird or the timeless classic Helicopter Game. The player flies through a winding cave and must avoid crashing into the walls. The player position is controlled by the Ultrasonic Rangefinder.  The cave is procedurally generated - the frame counter drives a generate_cave() function which uses simple trig functions (sin, cos) to create an infinite cave.
# Cave explorer game. Use the ultrasonic rangefinder to control the position of the player as you
# fly through a narrow, winding cave. Don't crash into the walls!
import math
buzzer = PiicoDev_Buzzer() # Initialise the buzzer
def generate_cave():
    """generate a new cave floor and ceiling based of the frame number. Changing these constants will affect game difficulty"""
    floor = range + \
                 range/2 * math.sin(2*math.pi * frame/200) + \
                 range/4 * math.cos(2*math.pi * frame/88)  + \
                 range/4 * math.sin(2*math.pi * frame/33)
    ceiling = floor + cave_size
    return floor, ceiling
def player_in_bounds():
    return player > cave_floor and player < cave_ceiling
def play_start_sound():
    buzzer.tone(1200,300)
def play_crash_sound():
    sleep_ms(300)
    buzzer.tone(600,300)
# Game Variables
cave_size = 150   # height of the cave
cave_floor = 150  # starting floor height
range = 150       # how much room the player needs to move around
frame = 0         # frame counter is used to generate the cave, and keep score
bound_counter = 0 # how many frames the player was out of bounds. glitches happen, so we look for consecutive out-of-bounds to trigger a crash
state = 'prestart'
print("Game starts when player is in bounds")
sleep_ms(1000)
    # Update the game
    cave_floor, cave_ceiling = generate_cave()
    player = ranger.distance_mm
    # Check for out-of-bounds
    if player_in_bounds():
        bound_counter = 0
        if state == 'prestart':
            state = 'play'
            play_start_sound()
        bound_counter += 1
    # Plot the game state
    print(f"{player} {cave_ceiling} {cave_floor} 0 {2*range + cave_size}")
    # Crash when out of bounds for consecutive frames
    if bound_counter > 2 and state == 'play':
        print(f"You crashed! Score: {frame}")
        play_crash_sound()
        break;
    frame += 1
    sleep_ms(100)
distance ultrasonic ranger rangefinder piicodev
