This guide will help you read temperature data from your PiicoDev Precision Temperature Sensor and a Micro:bit.
- A Micro:bit
- A PiicoDev Precision Temperature Sensor TMP117
- A PiicoDev adapter for Micro:bit
- A PiicoDev Cable
If you prefer not to use the Micro:bit adapter, there are other connection options in our PiicoDev Connection Guide.
Ensure the default address is set
For temperature sensors with an address switch labelled "ASW" (hardware versions v12 and above), make sure the first switch is ON and the rest are OFF.
For earlier revisions of the temperature sensor, the address was set by a solder jumper on the back. In this case, make sure that address 0x48 is selected.
Plug your Micro:bit into the PiicoDev adapter (buttons + LED matrix facing up), connect your temperature sensor to the adapter via the PiicoDev cable and connect your Micro:bit to your computer with a USB lead.
- PiicoDev_Unified.py - The PiicoDev Unified Libraries: Drives I2C communications for PiicoDev modules
- PiicoDev_TMP117.py - The device driver.
- main.py - an example script for this PiicoDev Sensor
It will be best to keep this file wherever you like to keep your coding projects eg. Documents > PiicoDev
Example Code
Open Thonny, connect to your micro:bit and upload the three files from the previous step.
Press Ctrl+D to restart your micro:bit and run the main script - temperature data should begin streaming up the shell
Above: Plotted data starts at room temperature (23degC) and climbs sharply when I warm the sensor with my hands. When I remove my hands, the temperature falls gradually.
The example also reads temperature in Fahrenheit and Kelvin - Modify the print statement to call the appropriate variable as you like.
eg.
print("It's " + tempStringF + "°F")
Now we can easily read temperature in Celsius, Fahrenheit and Kelvin.
Tip: Open the Plotter (View > Plotter) to see a nice plot of your temperature data
Connecting Multiple Sensors
It's possible to connect up to four temperature sensors to the same PiicoDev bus and read them independently - they each require a unique address. In the connect section, we set our sensor to the default address (0x48): where only the first ASW switch is ON. To read from more sensors, they need to be configured with unique addresses. For example, the second sensor should have the ASW2 switch ON, and the rest off. The third should have the ASW3:ON and the rest off - and similarly a fourth sensor.
The following example will read two sensors independently. This example looks similar to the first example in this tutorial, except now the initialisation functions are passed the asw argument. This is a list of four numbers that represent the positions of the ASW switches. sensorA has the first switch set, so asw=[1,0,0,0]. Likewise, sensorB has the second switch set, so the second element is 1 and the rest are 0: asw=[0,1,0,0]. This logic can be expanded to a maximum of four sensors.
# PiicoDev TMP117 - reading multiple sensors
# This program independently reads the temperature from two PiicoDev TMP117 precision temperature sensors
# Each sensor should have its ASW switches configured to match the asw argument during initialisaiton, eg.
# sensorA: asw=[1,0,0,0] so the first switch should be ON and the rest OFF
# sensorB: asw=[0,1,0,0] so the second switch should be ON and the rest OFF
# this logic expands to a maximum of four sensors
from PiicoDev_TMP117 import PiicoDev_TMP117
sensorA = PiicoDev_TMP117(asw=[1,0,0,0]) # initialise the sensor
sensorB = PiicoDev_TMP117(asw=[0,1,0,0]) # initialise the sensor
# Advanced users may prefer to set the address explicitly, instead:
# sensorA = PiicoDev_TMP117(address=0x48) # initialise the sensor
# sensorB = PiicoDev_TMP117(address=0x49) # initialise the sensor
# Read and print the temperature in various units
tempA = sensorA.readTempC() # read from sensor A
tempB = sensorB.readTempC() # read from sensor B
# print both results
print("A:" + str(tempA) + " " "B:" + str(tempB))
sleep_ms(1000) # delay 1 second
