Radio Frequency IDentification (RFID) uses electromagnetic fields to identify and communicate with tags. Each RFID module emits radio waves that energise the passive tag, which then responds with its own identifying number or data, as reque...
#nfc#id#tag
This guide is for the previous revision of the PiicoDev Magnetometer QMC6310 - if you have the latest revision featuring the MMC5603 - head to the guide for updated links and instructions.Let's get started with the PiicoDev® Magnetomet...
#compass#field#hall#magnet
Let's play tones and melodies on a PiicoDev® Buzzer Module with a Micro:bit. This guide will cover connecting the hardware, running an example to make sure everything works and playing simple melodies.
Of course, the Micr...
#piezo
Let's get started with the PiicoDev® 3x RGB LED Module. In this guide, we'll connect the LED Module to our Raspberry Pi Pico and get it working with some example code to display colourful patterns.
To follow along, it's best to ...
#neopixel#ws2812#ws2812b#neopixels
Let's read colour data from a PiicoDev® Colour Sensor with a Micro:bit V2, and create a colour sorting machine. This guide will cover connecting the hardware, downloading some example code and remixing it.
To f...
#rgb#color#hsl#hsv
To f...
Let's get started with the PiicoDev® OLED Module SSD1306. In this guide, we'll connect the PiicoDev OLED to our Raspberry Pi Pico and get it working with some example code to display text, shapes, and animations.
To f...
To f...
Let's get started with the PiicoDev® Capacitive Touch Sensor. In this guide, we'll connect the PiicoDev Capacitive Touch Sensor to our Micro:bit V2 and get it working with some example code to detect touch events. We'll also remix the c...
This guide will help you read barometric pressure from your PiicoDev® Pressure Sensor and a Micro:bit
A Micro:bit V2
A PiicoDev Pressure Sensor MS5637
A PiicoDev Adapter for M...
#sensor#pressure#altimeter#altitude#barometric
A Micro:bit V2
This guide will help you read distance data in millimetres from your PiicoDev Distance Sensor and a Micro:bit.
A Micro:bit
A PiicoDev Distance Sensor VL53L1X
A PiicoDev adapter for Mic...
A Micro:bit
In this article, we'll program a Micro:bit v2 using a web browser.
We'll connect a Micro:bit to our computer, open python.microbit.org and begin coding our first script.
What You'll Need
Connect your Micro:bit
Open the Progr...
#micropython#browser#programmer
What You'll Need
Open the Progr...
This guide will help you read light intensity data from your PiicoDev Ambient Light Sensor and a Micro:bit.
A Micro:bit
A PiicoDev Ambient Light Sensor VEML6030
A PiicoDev adapter for ...
#sensor#light#microbit#piicodev#veml6030#ambient
A Micro:bit
This guide will help you read temperature data from your PiicoDev Precision Temperature Sensor and a Micro:bit.
A Micro:bit
A PiicoDev Precision Temperature Sensor TMP117
A PiicoDev a...
#sensor#temperature#bit#micro#piicodev
A Micro:bit
A PiicoDev a...
This guide will help you read weather data (Temperature, Air Pressure and Humidity) from your PiicoDev Atmospheric Sensor and a Micro:bit.
A Micro:bit v2 (v1 does not...
#sensor#microbit#atmospheric#bme280#piicodev
Let's get set up with scripting in Thonny for the Micro:bit. We'll install Thonny, configure for Micro:bit, and write our first script.
All you'll need to follow along is a Micro:bit v2 GO kit
Install Thonny
Set u...
#bit#micro#microbit
Install Thonny
Set u...
Every good E-Textiles or Wearables project needs to start somewhere, and the natural starting point for any project is choosing the right microcontroller. There are many good choices out there, and we will compare a few of the best and brig...
The :MOVE MINI allows you to turn your micro:bit into a simple robot! In this guide, we will give you some tips and tricks for assembling the :MOVE mini. This is a DIY assembly item and takes 30-60 minutes to fully assemble. There is a grea...
#mini#microbit#bot#microbit robot#move#move mini#robot#servo lite
The Micro:bit has the ability to measure temperature by sensing the temperature of the silicon die inside the main CPU. This works because the Micro:bit runs cold, and the temperature of the CPU is usually a good approximation of ...
Every Micro:bit has the ability to measure visible light, but what about UV light? Imagine that you are growing a plant on the window sill in a well-lit room. Does your plant have enough light? Plants need UV light to photosynthesize e...
The Micro:bit is great for small portable projects like a soil moisture sensor. In this tutorial, we will walk through how to program a Micro:bit to make a reliable and consistent soil moisture sensor that will give consistent readings. The...
This Tutorial is all about the MicroPython Programming Language. We will discuss what MicroPython is, why you will want to use it in your projects and we will share some resources to help you learn further!
What is MicroPython?
MicroPyt...
#python#micropython#circuitpython#repl
MicroPyt...
The Micro:bit by BBC is a great data collection tool, it just needs a little help remembering what it has measured! This tutorial is made for those Micro:bit projects where transmitting your sensor data over radio or Bluetooth to a computer...
The Micro:bit is a feature-packed development board that’s perfect for the classroom or the beginner programmer. Each Micro:bit has a built-in radio that can transmit and receive signals sent from other Micro:bits. The radio has a ran...
Check out our micro:bit in the classroom video if you'd like to see how micro:bit integrates into classrooms, years 7-12.
After a quick review of the hardware, we'll fire up a micro:bit and write our first program. All you...
#tutorial#bit#micro
Check out our Getting started with micro:bit video if you'd like to see a quick tutorial on writing a program, start-to-finish, with a micro:bit.
In a Nutshell
The micro:bit is a versatile and classroom-friendly, programmable ele...
#bbc#bit#lesson#micro
In a Nutshell
Website features/issues
Content errors/improvements
Missing products/categories
Search results relevance
