How to Program a MicroBit using Thonny
Updated 19 July 2021
Let's get set up with scripting in Thonny for the Micro:bit. We'll install Thonny, configure for Micro:bit, and write our first script.
All you'll need to follow along is a Micro:bit v2 GO kit
Install Thonny
Download Thonny here and run the installer.
Set up Thonny
Open Thonny, and in the menu bar find Run > Select interpreter and choose MicroPython (BBC micro:bit)
select-microbit-interpreter-in-thonny
REPL interface (Shell)
Click the red STOP button to restart the MicroPython on your micro:bit if necessary. The Shell tab should display a block of text that indicates MicroPython is running:
thonny-shell-restarted
We can immediately start executing code in the REPL - Enter this code in the shell tab: print("Hello, World!")
from microbit import *
import audio
audio.play(Sound.HAPPY)
microbit-thonny-repl-play-audio
Writing a Script
The REPL is great for test-driving some new commands and performing short experiments - the real power is in scripting though.
import audio
print("Hello!")
        display.show(Image.HAPPY)
        display.clear()
Return to the REPL and press Ctrl+D to restart your micro:bit. If something went wrong, use the Stop/Restart button, then Ctrl+D.
Now, when we press the A button, the Shell will print the next multiple of 13, or if we press the B-button, our micro:bit gives us a smile and a hello sound.
thonny-example-script-for-microbit
  • The Blue line is the constant 13,
  • The Orange Line is the multiple variable that increases slowly, and
  • The Red line is the result variable, which increases really quickly.
Useful Tips
  • You can stop a running script by selecting the Shell window and pressing Ctrl+C. This is useful if we want to make changes to the file(s) stored on the micro:bit.
  • Reboot your micro:bit (or other MicroPython device) by selecting the Shell window and pressing Ctrl+D
  • If something goes wrong, you can always click the red STOP button in the menu bar
Uploading and Downloading Files
download-script-from-microbit-to-computer
If you have any questions feel free to start the conversation below or open a topic in our forums - we're full-time makers and happy to help!
bit micro microbit
