Exciting Features - Ultimaker Cura
Updated 03 February 2021
Ultimaker Cura is an excellent slicing software to get the best out of your 3D printers and make the greatest models it possibly can, but it can do so much more! Cura is a brilliant means to inspire and expand your own creativity particularly once you have dived into its expansive hidden options. So, I have gone through and found the best hidden Cura setting that inspires me to make. Some of the settings will increase the speed or efficiencies of your prints, others will improve the overall aesthetics and others will open doors of functionality. Quick links for the features of this guide is seen below.
There is an Ultimaker Cura Overview Guide on our website which is a great reference point if this is your first time encountering Cura and you want to hit the ground running. Simply put Ultimaker Cura is a software which allows you to turn the computer file of your model into a recipe for a 3D printer to follow. It is completely free software available online with a great track record, used by over a million users worldwide and handles around 1.4 million prints per week. If solutions and advice on how to solve 3D print errors are needed an excellent guide is Improving 3D Printed Models - Ultimaker Cura.
Most of these printing setting here will be hidden features in Cura. To be able to make them visible in the Printer Settings Menu go to |Top Tool Bar > Settings > Configure Setting Visibility| then find the particular setting in the list and click on its Checkbox. If you have got any questions, queries or things you would like to see added please let us know your thoughts!
Wire printing
Wire Prints!Wire printing is an amazing setting which prints interesting and intricate three-dimensional wireframe objects. The wire printing setting creates a G-Code recipe for your 3D printer which that will make a single layer wireframe out of the edges of any 3D CAD file. This method lets interesting highly complex designs be produced from very simple CAD models.
This setting is greats for rough dimensional understanding as it produces a version of the model which has the same size and shape as a solid final product but made with significantly less plastic and at ten times the speed. When a products form factor is still being tested and refined this method will lets you test ergonomics and how it will fit into existing other products super-fast. Also, an idea I have bouncing around is combining a wireframe model with Paper Mache to make some neat custom lamps.
Now components printed using this method are very fragile as they are a single layer with the entire inside of the model hollow. Extra care is important when you take it off the build plate. As this is an experimental setting it will take more effort by the user to print successfully. There are also heaps of parameters solely focused on wire printing. Printing in this method I would recommend using a larger nozzle, increasing flow percentage, maxing line width, increasing temperature, increased cooling and using PLA (or material with similar properties, check out Ultimaker 3D Printer Material Guide for a reference).
To access this option to |Top Tool Bar > Settings > Configure Setting Visibility > Type ‘Wire Printing’ in search bar > Click on Checkbox| makes it visible. You can now find Wire Printing in Print Settings Custom under Experimental heading. Follow a similar process to get related settings.
Spiral Mode
Vase ModeSpiral Mode, also referred to as vase mode, throws the whole traditional layer by layer method out the window. Spiral Mode instead chooses to print solely the edge of a part while smoothly and continuously raising the height axis as it spirals upwards. The final component will then be made of a long, unbroken string of filament laid on top of itself. The Spiral Mode is by no means limited to only making vases. Beautiful colour transitioning model can be made easily using rainbow filament and this method. If the final model is made from translucent material and this method the single-layer walls will be semi-transparent, a great avenue to make unique lamps.
Now, this method means you can only load a single model at a time as the filament will never be retracted and supports won’t be possible. By experimenting with your own machine and material you’ll be able to find the sweet spot. Vase mode is an immensely quick way of printing your file and the three important parameters to adjust to maximise your results are below.
  • Wall Line Width - This is the most crucial factor and depends mainly on the nozzle size that is being used. Use a larger nozzle size as it will create a much stronger print. You can also increase the flow of the material and line width inside print settings.
  • Speed - Using vase mode you will want to print slower. Each rotation requires a good amount of cooling time before the next rotation is built on top of it. A 25-30 mm printing speed would be a good starting point more if larger nozzle sizes are being used (0.6mm or a 0.8mm). If you find your prints are warping in a weird way this is the setting to change.
  • Temperature - Larger mass flow rates require a hotter print head to ensure the filament is reaching temperature. By increasing temperature in 5-10° increments, you'll be able to dial in the perfect temperature for your set up.
Vase mode is available in several different slicing software and in Cura is referred to as Spiralise Outer Contour. To access this option go to |Top Tool Bar > Settings > Configure Setting Visibility > Type ‘Spiralize Outer Contour’ in search bar > Click on Checkbox| to make it visible. You can now find Spiralize Outer Contour in Print Settings Custom under Special Modes heading. Follow a similar process to get related settings.
Mould Feature
The ability to quickly and easily make negatives of CAD designs is a really excellent hidden feature in Ultimaker Cura. This feature will print the selected model in negative with a wall surrounding it. This negative can then be used as a mould to produce casts from it. Silicone rubber or Plaster of Paris are both excellent materials that can fill a plastic mould and produce pleasing components.  It is crucial to spend some time considering whether the printed mould part will be a single-use, destroy after the filling material is solidified, mould or a clamshell-type multi-use mould. It is also worth thinking about overflow channels, locating pins and pouring basin locations particularly if it's a reusable mould. Seen below there are three settings that determine the dimension of the negative in combination with the original CAD design.
  • Minimal Mould Width - Determines the minimum width of the mould.
  • Mould Roof Height - Determines the height of the mould above the horizontal parts in your model.
  • Mould Angle - Determines the maximum angle the mould may make outside of the model. Can be implemented in such a way that no support needed on the outside of the mould.
To access this option go to |Top Tool Bar > Settings > Configure Setting Visibility > Type ‘Mold’ in search bar > Click the Checkbox| to make them visible. You can now find ‘Mold’ in Print Settings Custom under Special Modes. Follow a similar process to get related settings.
Mould in Cura
Fuzzy Skin
Furry!Cura offers different ways to alter the surface appearance of your CAD models and one of the most useful being fuzzy skin. This setting will turn the surfaces of your model knurled and bumpy giving it a pleasing furry looking appearance (like a shag carpet or the coat of a mini-schnauzer puppy). Perfect for creating models with hairy looking skin or creating designs with improved ergonomic at locations where it is gripped. Also when made out of a black plastic it’ll also give the appearance of a grippy metal component. By default, this setting will be applied to all outside surfaces but the exact location of the fuzzy skin can be adjusted in settings or by overlaying models. There are parameters to adjust both the density and thickness of the textured appearance. This is a really neat feature which effect can be seen in Preview view before printing.
To access Fuzzy Skin option to the |Top Tool Bar > Settings > Configure Setting Visibility > Type ‘Fuzzy Skin' in search bar > Click on Checkbox| to make it visible. You can now find Fuzzy Skin in Print Settings Custom under Experimental Modes. Follow a similar process to get related settings.
Adaptive Layers
Adaptive Layers is a method of retaining quality whilst increasing the speed of the print. When properly set up the 3D printer will take more time in certain sections to print at a higher resolution and faster in other areas where this is not required. It does this by analysing the geometry of the CAD model. Areas with major curvature or changes will be printed with thinner layers while areas with minor variations will be printed with thicker layers. This results in curved surfaces looking great whilst having a smaller total print time as compared to just using the smaller layer height for the entire object.
There are a few settings available which will allow you to decide exactly how adaptive layers will be implemented.
  • Adaptive Layers Minimum Variation - This controls the maximum allowed layer height difference compared to the base layer height setting.
  • Adaptive Layers Variation Step Size - Determines the difference in the height of the next layer compared to the previous one.
  • Adaptive layers Threshold - Determines how often thinner layers will be used. Smaller values result in more layers that are thin.
To access Adaptive Layers go to the |Top Tool Bar > Settings > Configure Setting Visibility > Type ‘Adaptive Layers’ in search bar > Click on Checkbox| to make it visible. You can now find Adaptive Layers in Print Settings Custom under Experimental Modes. Follow a similar process to get related settings. As this is an experimental setting it will take some practice to get the best possible result but I see a huge potential for this technology into the future.
Adaptive Layers in Cura
Ironing Feature
IroningIn the pursuit of beautiful surface finishes with 3D printing, Ironing is a technique up there with the best of them. This is where the nozzle travels over the top-most layer after printing it to literally iron the top layers to a smooth surface. It seems like a simple process but anyone who has had to wake up earlier to iron clothes ready for the day knows how complicated that can be. Thankfully default parameters function quite well and it will work consistently with common filament types. Ironing has a huge potential and there is no reason not to use this feature in all 3D prints where aesthetics and excellent surfaces are desired. The following settings for ironing can be adjusted to get the desired surface finish:
  • Ironing Pattern - The print nozzle will follow a pattern which will be ironed into the surface.
  • Ironing Line Spacing - Determines the space between every line.
  • Ironing Inset - Ironing is applied to an offset of the outer edge of the model in the X-Y direction.
  • Ironing Flow - While ironing this is the amount of material being extruded on to the top of the last layer.
  • Ironing Speed, Acceleration and Jerk - These three setting determine the exact movements of ironing to fine-tune the process.
To access Ironing go to |Top Tool Bar > Settings > Configure Setting Visibility > Type ‘Ironing’ in search bar > Click on Checkbox| to make it visible. You can now find Ironing in Print Settings Custom under Shell. Follow a similar process to get related settings.
Concentric Top/Bottom Pattern
Concentric filesIn the pursuit of aesthetics in 3D printing just by altering the first layer and top layer pattern to concentric is a really simple change which yields great results. Changing the Top/Bottom pattern is a relatively unknown hidden feature in Cura but it is an excellent fail-proof change. It won't take any longer to print nor will it weaken the final model and particularly when printing cylindrical components it looks really good. There are also a number of other types of patterns to explore but concentric yields the nicest results. Worth knowing if the model has a really tiny bottom or top you can run into issues with where small holes appear because the filament isn’t laid down.
To access Concentric Top/Bottom Pattern go to |Top Tool Bar > Settings > Configure Setting Visibility > Type ‘Top/Bottom Pattern’ in search bar > Click on Checkbox| to make it visible. You can now find Top/Bottom Pattern in Print Settings Custom under Shell. Follow a similar process to get related settings.
Pattern Types
Tree Supports
Tree support 1Tree supports are basically exactly what they sound like and are an excellent material saving method to sustain overhangs. Instead of printing supports in straight lines up from the build plate we can use tree-like structures to support models. These supports start from a couple of ‘trunks’ near the base of your print and branch out like a tree to support overhangs in your model as height increases. When this setting is selected they will automatically be generated by Ultimaker Cura when the model is sliced (make sure your model is properly positioned as it will take Cura a longer time to process). These supports are hollow and can be designed to follow different angles.  You can save both on material and print time by 3D printing with these supports. Since tree-type supports comparatively don’t touch the model as much, they offer better surface finish to traditional methods. Tree supports are great when 3D printing organic shapes, such as human or animals, as the branches will arch around the model. Furthermore, for overhangs that are small or not very steep, less than 70 degrees from the horizontal, this is an excellent choice. For big roof sections, I wouldn’t recommend this support structure as they only touch the model at a few points.
There are a couple of settings which will allow you to get the best possible result seen below:
  • Tree Support Branch Angle - Determines the maximum overhang angle the branch may use to print sideways.
  • Tree Support Branch Distance - Determines the support density.
  • Tree Support Branch Diameter - Determines the diameter of the branch where it touches the model.
  • Tree Support Branch Diameter Angle - Determines the growth angle of the branches, a larger angle increases the bottom width.
  • Tree Support Collision Resolution - A method to check and avoid collisions.
To access Tree Support go to |Top Tool Bar > Settings > Configure Setting Visibility > Type ‘Tree Support’ in search bar > Click on Checkbox| to make it visible. You can now find Tree Support in Print Settings Custom under Experimental. Follow a similar process to get related settings.
Tree Support 2
Conical Supports
Conical Support in CuraConical supports an alternative method of supporting overhangs and can save both time and material. They are also very much what they sound like, using this setting will produce support structures that are small at the bottom and wide at the top where they are required. Using this method of support type can save up to 50% of material from the support. This is an experimental feature but it gets very consistent excellent results. It is a relatively unknown mainly because it is a hidden feature in Cura but in the future I see this being the default method to support all roof overhangs. New Addition - My experience using the default settings for Conical Supports when using PVA gives mixed results, without increasing the minimum width they can end up falling over.
  • Conical Support Angle - Determines the growth angle of the conical from the build plate. A larger angle increases the bottom width of the support.
  • Conical Support Minimum Width - Determines how small the conical support can be at the base of the build plate.
To access Conical Support go to |Top Tool Bar > Settings > Configure Setting Visibility > Type ‘Conical Support’ in search bar > Click on Checkbox| to make it visible. You can now find Conical Support in Print Settings Custom under Experimental. Follow a similar process to get related settings.
Explanation of Support
Colour Blind Assist
And a very important feature for those in need, new themes have been installed in Cura by default with a Colourblind Assist Light and Colourblind Assist Dark. This will make a higher distinction between colours in the application, with changes like the yellow/green lines in the layer view. Cura can also be swapped into Dark mode by altering its theme. You can see a screenshot of Colourblind Assist Dark below.
To access this feature go to |Top Tool Bar > Preferences > General > Theme| from here the pull-down menu can be used to select a theme.
Dark Colourblind Theme pulling an X-Ray of a Doggo
3d printing cura ultimaker exciting features
