These are very bright LEDs. The LEDs are so bright that it hurts to look directly at them. Please take a look at the pictures to get an idea of the intensity. All lenses are clear.
Need some really bright LEDs? Adafruit are big fans of these 5mm clear UV / Purple LEDs. These emit UV 'blacklight' in the UVA spectrum so they are great for projects...
Need some really bright LEDs? Adafruit are big fans of these clear yellow LEDs, in fact Adafruit use them exclusively in their kits. They are very bright! They go easily into...
You're at New York's hottest cyberpunk club is Near Field Commune(ication), and it's got everything, Adabot & the Circuit Playground, Collin's wondrous, mind-blowing...
You don’t have to worry about adding a resistor to an LED if you get an LED with a built in resistor! This pack contains 20x 5mm LEDs in four different colors. There...
Have you ever seen those strings of fairy lights, or pre-lit Christmas trees, that change colors with a little remote? Have you ever noticed that they only...
Sure, we've got all sorts of diffused bare LEDs in all sorts of colors and sizes. But have you ever laid your peepers on this fantastic five-pack of...
Sure, we've got all sorts of diffused bare LEDs in all sorts of colors and sizes. But have you ever laid your peepers on this smooth set of spherical...
Sure, we've got all sorts of diffused bare LEDs in all sorts of colors and sizes. But have you ever laid your peepers on this set of punk spike LEDs?...
Sure, we've got all sorts of diffused bare LEDs in all sorts of colors and sizes. But have you ever laid your paws on this set of kitty-shaped LEDs?...
Discover warm white LED dots specifically designed for Tiny FX integration, featuring JST-SUR connectors and 15cm cables for seamless installation in studs and bricks.
Discover Cool White LED Dots designed for Tiny FX integration, featuring 15cm JST-SUR connectors and perfect fitment inside studs and bricks - ideal for custom lighting projects.
Explore our Blue LED Dots with JST-SUR connectors, designed specifically for Tiny FX integration and perfect for illuminating LEGO®-compatible studs and bricks with 15cm cable length.
Discover Green LED Dots designed for Tiny FX with JST-SUR connectors, perfect for illuminating LEGO® studs and bricks in your custom lighting projects.
Discover red LED Dots designed for Tiny FX with JST-SUR connectors, perfect for illuminating LEGO® compatible studs and bricks with precise fitment and 15cm cable length.
Website features/issues
Content errors/improvements
Missing products/categories
Product assignments to categories
Search results relevance
