Stepper motors require a more specific method of control than a standard brushed motor, so you'll need a proper stepper driver to control them.
Items 26-31 of 31
  1. TB67S581FNG Stepper Motor Driver Carrier
    SKU: POLOLU-2988 Brand: Pololu
    This breakout board for Toshiba’s TB67S581FNG microstepping bipolar stepper motor driver features adjustable current limiting, over-current and...
  2. RoboClaw 2x45A Motor Controller (V6B, pin header I/O)
    SKU: POLOLU-3685 Brand: Pololu
    The RoboClaw motor controllers from Basicmicro can control a pair of brushed DC motors using USB serial, TTL serial, RC, or analog inputs. Integrated dual...
  3. Pololu High-Power Stepper Motor Driver 36v4
    SKU: POLOLU-3730 Brand: Pololu
    This discrete MOSFET stepper motor driver enables control of one bipolar stepper motor. It supports a wide 8 V to 50 V operating voltage range and can...
  4. MP6500 Stepper Motor Driver Carrier, Potentiometer Current Control
    SKU: POLOLU-2966 Brand: Pololu
    This breakout board for the MPS MP6500 microstepping bipolar stepper motor driver has a pinout and interface that are very similar to that of our popular...
  5. Adafruit STSPIN220 Stepper Motor Driver Breakout Board
    SKU: ADA6353 Brand: Adafruit
    Stepper motors are used for CNC machines, 3D printers, and whenever else one needs precise, powerful motion. But to get good behavior from steppers, you...
    Available with 8 to 12 day lead time
  6. 28BYJ-48 Stepper Motor Module with Driver for STEM Robotics (5V, 0.9 kgf·cm)
    SKU: DFR1199 Brand: DFRobot
    The all-in-one 28BYJ-48 stepper motor module with an integrated driver. Its plug-and-play 4-pin interface is perfect for Arduino classroom projects...
    $20.10 AUD, inc GST
