Every project needs some quality stranded wire for connecting modules and components. We've got different gauges, as well as silicon and PVC insulation.
Items 51-75 of 90
  1. Silicone Cover Stranded-Core Wire - 50ft 30AWG Green
    SKU: ADA3168 Brand: Adafruit
    Silicone-sheathing wire is super-flexible and soft, and its also strong! Able to handle up to 200°C and up to 600V, it will do when PVC covered wire wimps out. Adafruit...
    1 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
    Delivered by Feb 5th
  2. Silicone Cover Stranded-Core Wire - 50ft 30AWG White
    SKU: ADA3169 Brand: Adafruit
    $10.30 AUD, inc GST
    As low as $9.78 AUD, inc GST
    Available with 7 to 12 day lead time
  3. Silicone Cover Stranded-Core Wire - 50ft 30AWG Blue
    SKU: ADA3166 Brand: Adafruit
    $10.05 AUD, inc GST
    As low as $9.55 AUD, inc GST
  4. Silicone Cover Stranded-Core Wire - 50ft 30AWG Yellow
    SKU: ADA3167 Brand: Adafruit
    $10.15 AUD, inc GST
    As low as $9.64 AUD, inc GST
  5. Silicone Cover Stranded-Core Ribbon Cable - 4 Wires 1 Meter Long - 28AWG Black
    SKU: ADA3891 Brand: Adafruit
    For those who are fans of Adafruit's silicone-covered wires, but are always looking to up their wiring game. Adafruit now have Silicone Cover Ribbon cables! These may look a...
  6. Silicone Cover Stranded-Core Ribbon Cable - 4 Wires 1 Meter Long - 30 AWG Black
    SKU: ADA3889 Brand: Adafruit
  7. Silicone Cover Stranded-Core Ribbon Cable - 4 Wires 1 Meter Long - 26AWG Black
    SKU: ADA3892 Brand: Adafruit
  8. Stranded Wire: Yellow, 30 AWG, 100 Feet
    SKU: POLOLU-2604 Brand: Pololu
    This is a spool with 100 feet of yellow 30 AWG stranded copper hook-up wire. It conforms to the UL1007 specification and is rated for up to 80°C and 300 VAC.
  9. Stranded Wire: Green, 30 AWG, 100 Feet
    SKU: POLOLU-2605 Brand: Pololu
    This is a spool with 100 feet of green 30 AWG stranded copper hook-up wire. It conforms to the UL1007 specification and is rated for up to 80°C and 300 VAC.
  10. Stranded Wire: Blue, 30 AWG, 100 Feet
    SKU: POLOLU-2606 Brand: Pololu
    This is a spool with 100 feet of blue 30 AWG stranded copper hook-up wire. It conforms to the UL1007 specification and is rated for up to 80°C and 300 VAC.
  11. Stranded Wire: White, 30 AWG, 100 Feet
    SKU: POLOLU-2609 Brand: Pololu
    This is a spool with 100 feet of white 30 AWG stranded copper hook-up wire. It conforms to the UL1007 specification and is rated for up to 80°C and 300 VAC.
  12. Stranded Wire: Yellow, 28 AWG, 90 Feet
    SKU: POLOLU-2614 Brand: Pololu
    This is a spool with 90 feet of yellow 28 AWG stranded copper hook-up wire. It conforms to the UL1007 specification and is rated for up to 80°C and 300 VAC.
  13. Stranded Wire: Green, 28 AWG, 90 Feet
    SKU: POLOLU-2615 Brand: Pololu
    This is a spool with 90 feet of green 28 AWG stranded copper hook-up wire. It conforms to the UL1007 specification and is rated for up to 80°C and 300 VAC.
  14. Stranded Wire: Blue, 28 AWG, 90 Feet
    SKU: POLOLU-2616 Brand: Pololu
    This is a spool with 90 feet of blue 28 AWG stranded copper hook-up wire. It conforms to the UL1007 specification and is rated for up to 80°C and 300 VAC.
  15. Stranded Wire: White, 28 AWG, 90 Feet
    SKU: POLOLU-2619 Brand: Pololu
    This is a spool with 90 feet of white 28 AWG stranded copper hook-up wire. It conforms to the UL1007 specification and is rated for up to 80°C and 300 VAC.
  16. Stranded Wire: Yellow, 26 AWG, 70 Feet
    SKU: POLOLU-2624 Brand: Pololu
    This is a spool with 70 feet of yellow 26 AWG stranded copper hook-up wire. It conforms to the UL1007 specification and is rated for up to 80°C and 300 VAC.
  17. Stranded Wire: Green, 26 AWG, 70 Feet
    SKU: POLOLU-2625 Brand: Pololu
    This is a spool with 70 feet of green 26 AWG stranded copper hook-up wire. It conforms to the UL1007 specification and is rated for up to 80°C and 300 VAC.
  18. Stranded Wire: Blue, 26 AWG, 70 Feet
    SKU: POLOLU-2626 Brand: Pololu
    This is a spool with 70 feet of blue 26 AWG stranded copper hook-up wire. It conforms to the UL1007 specification and is rated for up to 80°C and 300 VAC.
  19. Stranded Wire: White, 26 AWG, 70 Feet
    SKU: POLOLU-2629 Brand: Pololu
    This is a spool with 70 feet of white 26 AWG stranded copper hook-up wire. It conforms to the UL1007 specification and is rated for up to 80°C and 300 VAC.
  20. Stranded Wire: Black, 24 AWG, 60 Feet
    SKU: POLOLU-2630 Brand: Pololu
    This is a spool with 60 feet of black 24 AWG stranded copper hook-up wire. It conforms to the UL1007 specification and is rated for up to 80°C and 300 VAC.
  21. Stranded Wire: Red, 24 AWG, 60 Feet
    SKU: POLOLU-2632 Brand: Pololu
    This is a spool with 60 feet of red 24 AWG stranded copper hook-up wire. It conforms to the UL1007 specification and is rated for up to 80°C and 300 VAC.
  22. Stranded Wire: Yellow, 24 AWG, 60 Feet
    SKU: POLOLU-2634 Brand: Pololu
    This is a spool with 60 feet of yellow 24 AWG stranded copper hook-up wire. It conforms to the UL1007 specification and is rated for up to 80°C and 300 VAC.
  23. Stranded Wire: Green, 24 AWG, 60 Feet
    SKU: POLOLU-2635 Brand: Pololu
    This is a spool with 60 feet of green 24 AWG stranded copper hook-up wire. It conforms to the UL1007 specification and is rated for up to 80°C and 300 VAC.
  24. Stranded Wire: Blue, 24 AWG, 60 Feet
    SKU: POLOLU-2636 Brand: Pololu
    This is a spool with 60 feet of blue 24 AWG stranded copper hook-up wire. It conforms to the UL1007 specification and is rated for up to 80°C and 300 VAC.
  25. Stranded Wire: White, 24 AWG, 60 Feet
    SKU: POLOLU-2639 Brand: Pololu
    This is a spool with 60 feet of white 24 AWG stranded copper hook-up wire. It conforms to the UL1007 specification and is rated for up to 80°C and 300 VAC.
