These step-down (Buck) converters are a perfect way to decrease a DC voltage to something suitable for your project's needs.
Items 101-116 of 116
  1. Pololu 12V, 1A Step-Down Voltage Regulator D24V10F12
    SKU: POLOLU-2834 Brand: Pololu
    The compact (0.5" × 0.7") D24V10F12 synchronous buck voltage regulator takes an input voltage of up to 36 V and efficiently reduces it to 12 V while...
    Delivered by Dec 10th
  2. Pololu 9V, 1A Step-Down Voltage Regulator D24V10F9
    SKU: POLOLU-2833 Brand: Pololu
    The compact (0.5" × 0.7") D24V10F9 synchronous buck voltage regulator takes an input voltage of up to 36 V and efficiently reduces it to 9 V while...
  3. Pololu 6V, 1A Step-Down Voltage Regulator D24V10F6
    SKU: POLOLU-2832 Brand: Pololu
    The compact (0.5" × 0.7") D24V10F6 synchronous buck voltage regulator takes an input voltage of up to 36 V and efficiently reduces it to 6 V while...
  4. Pololu 3.3V, 1A Step-Down Voltage Regulator D24V10F3
    SKU: POLOLU-2830 Brand: Pololu
    The compact (0.5" × 0.7") D24V10F3 synchronous buck voltage regulator takes an input voltage of up to 36 V and efficiently reduces it to 3.3 V while...
  5. DC-DC Buck Mini Module, Compact Size And Easy To Integrate (3.3V/5V, up to 4A)
    SKU: WS-29035 Brand: Waveshare
    DC-DC Buck Mini Module, Compact Size And Easy To Integrate, Configurable 3.3V Or 5V buck voltage regulation output, Immersion Gold Process...
    21 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  6. 24V, 4A Step-Down Voltage Regulator D42V55F24
    SKU: POLOLU-5579 Brand: Pololu
    Note 1: Typical continuous output current at 42 V in. Actual achievable continuous output current is a function of input voltage and is limited by thermal...
    $56.30 AUD, inc GST
  7. 12V, 4.5A Step-Down Voltage Regulator D42V55F12
    SKU: POLOLU-5577 Brand: Pololu
    $56.30 AUD, inc GST
  8. 8.4V, 5A Step-Down Voltage Regulator D42V55F8
    SKU: POLOLU-5575 Brand: Pololu
    Special Price $38.50 AUD, inc GST
    Regular Price $56.30 AUD, inc GST
  9. 5.3V, 6A Step-Down Voltage Regulator D42V55F5.3
    SKU: POLOLU-5572 Brand: Pololu
    $56.30 AUD, inc GST
  10. DC-DC Step Down Buck Converter (15~24V to 12V/12A)
    SKU: DFR1208 Brand: DFRobot
    The 12A DC-DC Buck Converter is an efficient 5-24V to 12V step-down module with over-temperature & short-circuit protection. Ideal for drones, robots &...
    $27.60 AUD, inc GST
    Available with 8 to 12 day lead time
  11. DC-DC Step Down Buck Converter (6~24V to 5V/16A)
    SKU: DFR1202 Brand: DFRobot
    The 16A DC-DC Buck Converter is an efficient 6-24V to 5V step-down module with over-temperature & short-circuit protection. Ideal for drones, robots & LED...
    $22.60 AUD, inc GST
  12. 12V, 600mA Step-Down Voltage Regulator D24V7F12
    SKU: POLOLU-5597 Brand: Pololu
    Note 1: Minimum input voltage is subject to dropout voltage considerations; see the dropout voltage section of product pages for more information...
    Special Price $4.40 AUD, inc GST
    Regular Price $4.60 AUD, inc GST
  13. 5V, 600mA Step-Down Voltage Regulator D24V7F5
    SKU: POLOLU-5593 Brand: Pololu
    $4.60 AUD, inc GST
  14. 3.3V, 600mA Step-Down Voltage Regulator D24V7F3
    SKU: POLOLU-5592 Brand: Pololu
    $4.60 AUD, inc GST
  15. Adafruit DC Power BFF Add-On for QT Py
    SKU: ADA5882 Brand: Adafruit
    We were recently working on a project where we really wanted to power a QT Py ESP32 from 12V - but the only power input on the board is basically USB 5V...
    Available with 7 to 12 day lead time
  16. UBEC DC/DC Step-Down (Buck) Converter - 5V @ 3A output
    SKU: ADA1385 Brand: Adafruit
    Your power supply problems just got SOLVED! This little circuit board may look tiny but inside is a high efficiency DC/DC step-down converter which can output up...
    9 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
