Updated 15 February 2023
Today will be all about controlling Fully Addressable LED Lights using any Espressif ESP32 Development Board and your mobile Phone all through WIFI!  All possible by WLED.
There are many ways to use your mobile phone to remotely control and manage ESP32 or even the older ESP8622 boards. Currently the best option, hands down, is WLED. A fully Open-Source phone application, WLED can be found for free in the Google Play Store or in the IOS App Store. So no matter your Phone type you can get in on the action. With the ESP32 board connected together, this application will allow you to control the LED lights exactly how you want. And you can control many, many ESP32 boards all from the singular application whilst also providing an expansive amount of easily adjustable built-in patterns.
Fully Addressable LED strips can produce whatever unique colour and brightness you want for each LED node. This provides an incredible amount of freedom. Creating a great Fully Addressable LED control system used to be complex, either having to start from scratch (coming up with light patterns and user interface) or taking the easier option and having to then use paid proprietary options (which have limited built-in patterns). This WLED application instead makes the whole experience much more user-friendly, elegant to navigate, and most importantly fun. This software is just too rad not to explore, so below are the contents of this guide.
- Setting Up WLED on the ESP32 Board
Connecting the ESP32 to Fully Addressable LEDs
- LED Patterns and Menu Overview
- Quick Troubleshooting and Tips
Check out the image below of a Sparkfun ESP32 Thing Plus C set-up and powering 28 high-density RGB WS2812B LEDs. ESP32 and ESP8266 are perfect for use in this role, and both work exactly the same with WLED software. They are cheap and provide exactly what hardware you need and nothing more. The WLED software is really where the magic comes in. It provides heaps of pre-set patterns and custom LED styles. More options than I have seen elsewhere on paid software and much easier to create your own custom light using WLED.
Set Up for Guide
Now I have used Raspberry Pi full-sized computers to control fully addressable LED before (mainly because of previous lack of great software/knowledge to work with ESP32 Development Boards) but Raspberry Pis are so much more than a simple addressable LED control, they are full-on computers. So when it comes to a single addressable LED strip that you want to be good to go 24/7 but not necessarily be shining LED light everywhere all the time ESP32 are perfect for this application in regards to the much lower current draw (particularly when dormant), ease of power-cycling and significantly cheaper installation. Linked here is a great guide comparing the newer ESP32 to the ESP8266 board.
Below is a list of everything you will need to get started with WLED. All the electronics here operate at 5V.
ESP32 or ESP8266 Board. There are many types, for this guide I have used an ESP32 Thing Plus C. You could use a FireBeetle ESP32 IOT Microcontroller or any ESP32 or ESP8266 board that you wanted.
- Fully Addressable 5V LED Strip. There are many types, for this guide I have used a section of a 1M RGB LED Strip - WS2812B 144 Per Meter - Black Strip
Depending on how many LEDs you want to use you may want to have a secondary power supply for the LED strip so that it will have enough current available to the LEDs. Each RGB LED draws approximately 50mA when it is set to full brightness and powered at 5V. That means for every 30 LEDs that you have your LED strip could be drawing as much as 1.5 Amps.
As a first note, the max current you want to be pulling through an ESP32 Development Board Chip is ~1200mA. Also for those curious, the max current out of a USB3.0 is 900mA. USB1.0 and USB2.0 deliver up to 500mA. That means, for peace of mind during testing, power the system via any USB as it will then not be possible to break the ESP32 by overloading it with the current. Also, if powering the system via a battery make sure that the C rating of the battery and the Amp capacity of the wire is high enough.
Note here as well, for ESP32-S2 and ESP32-S3, WLED App compatibility is close. With some tweaking of settings, you can create a functional system but is not quite there with all the features. ESP32-C3 board are currently not supported.
Setting Up WLED on an ESP32 Board
Turn on your desktop computer and open up your preferred internet browser (in my case Chrome). With that open, type and enter directly into the URL | install.wled.me |. The website this URL will take you to will look like the image below.
Website for installation
Connect your ESP32 Board to the Computer using any USB port. Download the correct one for your board (be it ESP32 or ESP8266). Make sure it has connected correctly and is in boot mode. You may need to install particular firmware for your device or drivers for your computer to have it pop up correctly in the COM Port list of devices. If you are running into issues here check the Troubleshooting section below. With that done click on the Install Button using the most up-to-date version and select the correct COM port. The installation process will then occur and should take less than 5 minutes, the image below shows the completed install.
Installation Complete!
As a Big note, WLED has made it even easier to provide WIFI details to the ESP32, these details can now be entered in as soon as you finish the installation process. See this option in the below image. If you do this you can skip past providing WIFI details section.
New Method of providing Wifi details
With that done unplug the USB and plug it back in to quickly reboot the ESP32 (which will now have the WLED software flashed to it). As a note, this is an ESP32 board and thus under normal operation, you can rip power from it at any time with absolutely no fear of damaging it.
The software we have flashed to it will run on boot. At this stage, we haven’t provided the ESP32 with any local WIFI details. So right now, your ESP32 is going to be running as a WIFI access point that we can connect to using any computer or phone (kind of like running headless with a Raspberry Pi, except easier to access).
Restart the ESP32 Board Manually
At this point, I jumped onto my phone and searched for WIFI nearby, check the image below for a visual understanding of all the next steps.
Look for a network called | WLED-AP |. Join that and then type | wled1234 | when it requests a password. This will open up a | Sign in to network | page. You can also get to this page by opening up an internet browser (like Chrome) and typing the numbers and letters | http://4.3.2.1 | into the URL. Now on this page click on WIFI Settings. This will open up a new section called WIFI Setup. Here alter the Network Name and Network Password to be your internet network name and password. Now the ESP32 will be able to connect directly to our router instead of directly to our computer/phone. As a note, you can connect directly to the ESP32 and control lights without providing WIFI details but adding multiple ESP32 and creating an ecosystem of multiple LEDs all-around your house is much better managed by providing them all with WIFI credentials. Press | Save and Connect | and your ESP32 will reboot and then connect to your WIFI.
Process to Give WIFI details to ESP32 Board
From here everything can now be done via the WLED App, make sure you have it installed on your phone if you haven’t already (you can also find it for free in the Google Play Store or in the IOS App Store).
Give your ESP32 a hard reset again by pulling power from it and plugging it back in. Reconnect your phone/computer to your desired WIFI. Having done this and after a couple of seconds, you should now be able to see WLED as a device that has connected to your internet system (all internet routers have some way of showing this). See in the image below, my phone, my computer (a Raspberry Pi), and my ESP32 Board are all connected to the same WIFI internet (sections in white have been hidden for security reasons).
Router List of Connected devices
You can now access your ESP32 device through your router using your Phone through the WLED App (or on your Computer using a Browser with the IP Address as the URL). Sweet!
From here on out we will be using the Android Version of the WLED APP but keep in mind that you could be using any computer or an IOS Phone (like the iPhone). When you first open up the WLED App it will look like the left of the image below. Click on the Plus symbol to open up the discovery page. Press Start discovery which will search through your WIFI for all boards running WLED software connected. Once it says | Found WLED! | like it says in the image below press the Tick button on the top right. This will bring you back to the home page where you will have a list of all the WLED Boards on your network. From here by clicking anywhere on the header you will be able to open up the phenomenal light settings section of this APP. This is where the magic really is.
Setting up your ESP32 Board in the App
Now if your ESP32 Board (or ESP8266 Board) has an onboard addressable LED used as a multi-status LED (like the Thing Plus C ESP32 WROOM board that I’m using here) you will be able to control it directly using this setup. You can see this in the image below, as I change the colour selected by pressing on the colour wheel it changes the multi-status LED to match.
Colours!
Connecting Up ESP32 to Fully Addressable LEDs
So one LED is pretty Cool that must mean ~30 LED is 30 times cooler! There’s no Law of Diminishing Marginal Excitement at play here. To do this we must then connect the ESP32 to some Addressable LEDs just like in the schematic and image below. The black wire is ground, the red wire is 5V positive power and the green wire is the data wire, telling the lights what brightness and colour each should be. The easiest way to get this connection is by soldering headers to the board and adding Dupont connectors to the end of the strip.
Simple Schematic Low Amp Requirements
Having done so and your LEDs are all wired up like the image below then you should be getting light through your system! Note that in the image below I have two ESP32 boards with one disconnected just to better show off the wire connection points.
Real Life version of above Schematic - Very Left Board there only for Clarification
Thus we can now choose certain colours from the colour wheel and baddaboom we have remotely activated fully operational addressable LEDs! Having achieved this we can get right onto exploring what is on offer with this WLED software!
Choosing custom LED light patterns is where the magic really is. See the image below for the main UI on the left and the Effects Menu on the right. Keep in mind the effect menu can be scrolled through for a long time. A particular favourite of mine is Fireworks.
So let's have a quick look at this user interface. We have a simple | Power | button, this will turn the lights on or off (but not the ESP32 board). We have a | Timer | button, so we can organise the lights to come on and off at certain points during the day. We have a | Sync | button to update new LED patterns. We have a | Peek | button to test out custom-created light patterns. There is an | Info | button, providing details about the board and setup. There is also a | Config | menu which is talked about in the next troubleshooting section. Below this is a general brightness slider, the colour wheel including contrast and brightness tweak bars, and the ability to select multiple different colours (for use with the effects and segments).
Clicking on the | Effects | button will take you to a new deeper page (with an awesome and long list of effects) that can all have customisation done to, from speed, intensity, and colours. Clicking on the | Segments | button will also open a new deeper page allowing you to decide exactly what colours you want each portion of your LED strip to be.
So much Choice
Starting off simple we can select block colours for the WLEDs by pressing anywhere on the colour wheel. Personally, my recommendation to you at this point is just to explore the expansive options. This is the most fun part after all! Just check out the crazy custom colours that I created on my phone in less than 1 minute that appears to flow up the strip in the image below. This pattern would be much harder to code from first principles than it is just to use this brilliant WLED App.
Zoomed out version of Set-up
If you can locate your ESP32 or ESP8622 Board when you connect it to the computer or if it doesn't pop up on one of the COM ports. Make sure that the firmware is fully updated for the particular board your using and that you connect the board to the computer in bootloader mode. To connect an ESP32 board in bootloader mode you may need to hold in the tactile boot button on the ESP32 board and then put power into the system by plugging it into the computer. There are a number of other potential methods to do this depending on the particular microcontroller used so refer to the datasheet of your particular board if running into strife. Also make sure you are using a cable (be it USB-C or USB-Micro etc) which has the ability to send data through it, not just power. Definitely try a couple of different connections cords as they are not all made equal, even if they look the same.
If your issue is that you have set it up like the images above and not getting any LED action. Double-check that you have allocated | Pin 4 | to be the pin to send out data to the fully addressable LEDs, you can find this in the | LED & Hardware Setup | menu easily found in the app. See the image below for a screen capture of what this setting menu looks like, make sure to scroll down to access this option.
If at the end of your strip some LEDs are not lighting up. Make sure the count of LED pixels matches the software. In the same | LED and Hardware setup | menu, you can directly tell the system how many LEDs you have hooked up. Adjust the value to the exact correct amount as this will make some effects look even better.
If the colours produced are inversed to desired. Make sure that the correct type of Colour Order for your Fully Addressable LED has been chosen. Common types are GRB, RGB, and BRG. This is found in the | LED and Hardware setup | menu.
You can also set up a current limiter in this | LED and Hardware setup | menu so you won't ever 'let the smoke out' of your microcontroller. ESP32 Board likes to have less than 1300mA running through them. If more current is required to power a long LED strip then you will need to power the LEDs with a separate power supply. Make sure both systems share the same ground when running this kind of system. A LED driver board with standoffs to mount an ESP32 board directly to it would be a great way to simplify this.
WIFI works perfectly but I personally ran into some issues setting these devices up using my phone's hotspot. I highly recommend using a WIFI from a router.
LED and Hardware Setup Menu on App
Where To Now
Here are some cute projects that I have put together using WLED. WLED has been good to me, it'll be good to you too. Starting with my 3D Printed Koala Night light using that same strip of WS2812B used in this guide.
Night lite
Also my LED GlowBit Matrix Grid. More on that very soon.
Plamsa
And even my little Dinosaur Night light just to demonstrate some examples of what you can do. Find the CAD for the Dinosaur Light linked here
Dino light
led neopixel esp32 esp8266 addressable ws2812b leds glowbit
