PiicoDev Real Time Clock (RTC) RV-3028 - Getting Started Guide
Updated 08 July 2022
This guide will help you get started with a PiicoDev Real Time Clock. We'll set and read the time/date, observe the power-backup capability, and configure the RTC with an alarm.
A Real-Time Clock (RTC) is a timekeeping device that accurately tracks the passage of time. Most RTCs feature a calendar and alarm so they may be used to schedule actions. The PiicoDev Real-Time Clock is based on a low-power and very accurate RV-3028, factory calibrated to within 30 seconds per year. Power to the RTC is backed-up by a supercapacitor, capable of running the clock for up to a week without external power. When power is connected, the supercap is recharged. From dead-flat, it takes about three minutes to charge the supercap enough to sustain shorter power outages. A full charge takes about an hour.
Hardware and Connections
To follow along you'll need:
Plug your Pico into the expansion board. Make sure it is plugged in the correct orientation - Pin 0 on the expansion board should be to the left of the Pico's USB connector.
Connect your RTC to the expansion board with a PiicoDev Cable.
Mount the Adapter onto your Pi's GPIO. Make sure it is plugged in the correct orientation - An arrow on the Adapter will point to the Pi's Ethernet connector (on a Pi 3 the Ethernet connector and USB ports are swapped.)
Connect your RTC to the Adapter with a PiicoDev Cable.
Plug your micro:bit into the Adapter, making sure the buttons on the micro:bit are facing up.
Setup Thonny
Select your dev board from the tabs above to get ready for programming with Thonny for the first time.
If you have already programmed with PiicoDev modules before, there's probably no need to follow these steps again.
Install Thonny
Set up Thonny
Select Interpreter
REPL interface (Shell)
from machine import Pin
led = Pin(25, Pin.OUT)
led.toggle()
REPL Interface
LED On
Writing a Script
from time import sleep
n = 0;
    led.toggle()
    n = n + 1
    sleep(0.5)
Return to the REPL and press Ctrl+D (or use the Stop/Restart button) to restart your Pico. The LED should flash at a steady rate and the shell should begin printing multiples of thirteen.
Script Output
Installing a Package
An example of installing the micropython-servo libraryAn example of installing the micropython-servo library
Good news! Thonny comes pre-installed with Raspberry Pi OS. However, to work with PiicoDev we need to enable I2C communications as follows:
  • Power on your Raspberry Pi.
  • Open the Preferences > Raspberry Pi Configuration, select the Interfaces tab
  • Ensure I2C is Enabled
Let's get set up with scripting in Thonny for the Micro:bit. We'll install Thonny, configure for Micro:bit, and write our first script.
All you'll need to follow along is a Micro:bit v2 GO kit
Install Thonny
Download Thonny here and run the installer.
Set up Thonny
Open Thonny, and in the menu bar find Run > Select interpreter and choose MicroPython (BBC micro:bit)
select-microbit-interpreter-in-thonny
Click the red STOP button to restart the MicroPython on your micro:bit if necessary. The Shell tab should display a block of text that indicates MicroPython is running:
thonny-shell-restarted
from microbit import *
import audio
audio.play(Sound.HAPPY)
microbit-thonny-repl-play-audio
Writing a Script
The REPL is great for test-driving some new commands and performing short experiments - the real power is in scripting though.
import audio
print("Hello!")
        display.show(Image.HAPPY)
        display.clear()
Return to the REPL and press Ctrl+D to restart your micro:bit. If something went wrong, use the Stop/Restart button, then Ctrl+D.
Now, when we press the A button, the Shell will print the next multiple of 13, or if we press the B-button, our micro:bit gives us a smile and a hello sound.
thonny-example-script-for-microbit
  • The Blue line is the constant 13,
  • The Orange Line is the multiple variable that increases slowly, and
  • The Red line is the result variable, which increases really quickly.
Useful Tips
  • You can stop a running script by selecting the Shell window and pressing Ctrl+C. This is useful if we want to make changes to the file(s) stored on the micro:bit.
  • Reboot your micro:bit (or other MicroPython device) by selecting the Shell window and pressing Ctrl+D
  • If something goes wrong, you can always click the red STOP button in the menu bar
Uploading and Downloading Files
download-script-from-microbit-to-computer
If you have any questions feel free to start the conversation below or open a topic in our forums - we're full-time makers and happy to help!
Install Thonny
Set up Thonny
import audio
Writing a Script
import audio
print("Hello!")
        display.clear()
Useful Tips
Download / Install PiicoDev Modules
We will need these files to easily drive the PiicoDev Real Time Clock:
  • Save the following files to your preferred coding directory - In this tutorial, we save to My Documents > PiicoDev.
  • Upload the files to your Pico. This process was covered in the Setup Thonny section.
The PiicoDev Unified Library is responsible for communicating with PiicoDev hardware, and the device module contains functions for driving specific PiicoDev devices.
We will now install/upgrade the PiicoDev python module for Thonny. This module contains all the drivers to work with all current PiicoDev hardware. Even if you have already installed the PiicoDev modules before, it's still worth upgrading to the latest version if one is available.
First, run Thonny by clicking the:
  1. Pi Start Menu
  2. Programming
  3. Thonny IDE
We need to set up a virtual environment to install the PiicoDev module into. This only needs to be done once as Thonny will remember an environment you have already made. If you are unsure if you have already set one up, you can always create a new one by following these steps.
To set up a virtual environment, click on run  > configure interpreter, to open up the interpreter tab.
In this window, we can create a new virtual environment in the bottom right. A notification window will first pop up, just click OK.
In this window, we are going to create a new empty folder in our Home Directory which will be the location of our virtual environment. To do so follow these steps:
  1. Select the Home tab on the left-hand side of the window.
  2. Click the Create Folder button in the top right.
  3. Enter the name of the new folder. You can call it what you want, but we will call ours "myenv". Once you have written the name, click Create next to it.
  4. Click OK in the bottom left.
Thonny will then set up your virtual environment and when it has finished, it will return to the Interpreter tab. Click OK, and you will have successfully set up the environment.
Note: the Python Executable path now points to the environment we just created.
Remember, you only need to do this once as the next time you open Thonny it will use this environment.
Next, open the package manager. From within Thonny click Tools > Manage Packages
Enter "piicodev" and click "Search on PyPI"
Finally, Install PiicoDev. If you already have PiicoDev installed, there may be an Upgrade button instead, to upgrade to a newer version.
With the PiicoDev module installed we are now ready to begin programming with PiicoDev hardware.
  • Upload the files to your micro:bit. This process was covered in the Setup Thonny section.
Set and Read the Time and Date
The following example shows how to set and read the time. The script initialises the RTC which enables charging the supercap. The date and time are set numerically, and the weekday is set with an integer between 0 and 6.
The setDateTime() method pushes the values we have set onto the RTC. Conversely, the getDateTime() method pulls the current date-time from the RTC and stores that data into the attributes (day, month, year, etc.). That means any time we want to get the current time, we must first call getDateTime().
We can query the name of the weekday by reading from the weekdayName property which contains a string ("Monday", "Tuesday" ... "Sunday"). weekdayName assumes that Monday is day zero. If you prefer, you can also set the weekday using weekdayName eg. rtc.weekdayName = "Monday"
timestamp() is a special method that first updates the current date-time, and then returns a string in the format YYYY-MM-DD HH:MM:SS. This is useful for printing timestamps to the shell or a log file.
# PiicoDev Real Time Clock RV-3028
# An example of how to set and read the date, time, and weekday
from PiicoDev_RV3028 import PiicoDev_RV3028
rtc = PiicoDev_RV3028() # Initialise the RTC module, enable charging
# Set the time by assigning values to rtc's attributes
# Replace the following values with the current date/time
rtc.day = 6
rtc.month = 5
rtc.year = 2022
rtc.hour = 11
rtc.minute = 57
rtc.second = 00
rtc.ampm = '24' # 'AM','PM' or '24'. Defaults to 24-hr time
rtc.weekday = 4 # Rolls over at midnight, works independently of the calendar date
rtc.setDateTime() # Sets the time with the above values
# Get the current time
rtc.getDateTime()
# Print the current time, and today's name
# You can read from individual time attributes eg hour, minute, weekday.
print("The time is " + str(rtc.hour) + ":" + str(rtc.minute))
print("Today is " + str(rtc.weekdayName) + "\n") # weekdayName assumes counting from 0=Monday.
    print(rtc.timestamp()) # timestamp() automatically updates time, and returns a pre-formatted string. Useful for printing and datalogging!
    sleep_ms(1000)
After running the script, you ought to see:
  • First, a message that reads "The time is..." and "Today is..." with the correct time and week day name.
  • Second, the current timestamp being printed every second.
Running on Backup Power
In the previous example, the PiicoDev RTC was automatically configured to charge the supercapacitor during initialisation. If your RTC has remained powered for a few minutes since running the example then the capacitor will have enough charge to withstand a power outage. Let's test it out!
  • Stop the example script if you haven't already
  • Disconnect the RTC for some time
  • Reconnect the RTC
Now we'll check if the clock has kept accurate time during the power outage. Run the following code - which is a stripped-down version of the previous example that just reads the timestamp. All going well, you should see accurate timestamps printing in the shell!
Be careful not to accidentally set the time again during this process! There should be no need to call setDateTime(), since we already set the correct time in the previous example.
# A simple example to read the date, timestamp and weekday from the PiicoDev RTC
    sleep_ms(1000)
Advanced Examples
These examples use more advanced features of the RTC. As such, their documentation is a little more terse. Select a tab to see the example.
The following example checks whether the current time matches a pre-set scheduled time to perform an action. The action is only performed once. This can be used to create an alarm, or schedule events in the future. The alarmSetup() method accepts values for minutes, hours, and weekday (or date).
The status of the alarm can be checked with the checkAlarm() method, which returns True the first time it is called after an alarm has triggered. Subsequent calls to checkAlarm() will return False, until the alarm is triggered again. This means you don't have to query checkAlarm() at the exact time the alarm is set for.
By default, alarmSetup() will also configure the hardware interrupt pin (INT) to trigger on an alarm event.
# Some examples of how to set an alarm
# Alarms can trigger on a combination of minutes, hours, and weekday/date
rtc = PiicoDev_RV3028() # Initialise the RTC module (24-hr mode by default), enable charging
### Trigger once per hour, at the start of the hour
rtc.alarmSetup(minutes=0)
### Trigger on the 3rd day of the week (count from zero) at 1:23 PM
# rtc.alarmSetup(weekday=2, hours=13, minutes=23)
### Trigger on the first day of the month
# rtc.alarmSetup(date=1)
    if rtc.checkAlarm():
        print("Alarm Triggered")
    sleep_ms(2000)
The PiicoDev RTC features a clock output pin (CLK) that generates a square wave - the frequency is user configurable. Valid frequencies are: 0Hz (off, Low), 1, 32, 64, 1024, 8192 and 32,768Hz
# Set the CLK output pin frequency
rtc.configClockOutput(1) # The frequency, in Hz, of the square wave on the CLK output pin. Valid values are: 32768, 8192, 1024, 64, 32, 1, and 0 (always low).
The PiicoDev RTC features a UNIX time register that can be set independently of the date-time. UNIX time is represented as the number of seconds since the last epoch. When reset to zero, this timer can be useful for keeping uptime or a mission-timer for data logging
rtc.setUnixTime(0) # reset UNIX time
    print(rtc.getUnixTime()) # display UNIX time
    sleep_ms(1500)
The PiicoDev RTC features an External Event Interrupt pin (EVI) and Time Stamp function that can capture the time of an external event. The example below configures the EVI pin to capture the timestamp of a falling edge. If multiple events occur before the event time is queried, only the most recent timestamp is returned.
# Read the EVI pin event time.
# The program will continue listening for an event until one is detected.
rtc.resetEventInterrupt(edge = 'falling')
rtc.getDateTime()
print('Monitoring started at: ' + rtc.timestamp())
while (rtc.getEventInterrupt() is False):
    print('Waiting for 10 seconds.  If there is a falling edge on EVI pin the time will be recorded.')
    sleep_ms(10000)
print('Event occurred at: ', end='')
rtc.getDateTime(eventTimestamp=True)
print(rtc.timestamp(eventTimestamp=True))
Technical Resources
Pin Description
GND Power Input, Ground
3V3 Power Input, 3.3V. Tolerant up to 5V (Note 1)
SDA I2C Communications - Data
SCL I2C Communications - Clock
INT Interrupt Output, Low when an interrupt occurs
EVI Event Input - pull to Ground to trigger an event interrupt
CLK
Clock output, square wave configurable from 1Hz to 32,768Hz
(Note 1) The RV-3028 RTC will operate down to Vcc of 1.2V however at this voltage the included supercapacitor will not hold sufficient charge to guarantee that time is kept through a power failure. Time is lost when the capacitor voltage drops below about 900 mV and it will typically only charge to Vcc-0.3V due to an internal Schottky diode. The RV-3028 works up to 5V, but this is only recommended for freestyle prototyping ie. not connected to any other PiicoDev hardware. PiicoDev is a 3.3V system.
License
You're welcome to reuse and remix this content for any NonCommercial purposes.
This content is distributed under CC BY-NC-SA 4.0:
You are free to Share (copy and redistribute the material in any medium or format); and Adapt (remix, transform, and build upon the material) so long as the purpose is NonCommercial. If you remix, transform, or build upon the material, you must distribute your contributions under the same license. Read the full license.
If you want to use this content for commercial purposes, send us an email to discuss.
raspberry pi rtc microbit piicodev raspberry pi pico micro:bit real time clock
