This guide will help you read motion data from your PiicoDev® Motion Sensor and a Micro:bit.
If you prefer not to use the Micro:bit adapter, there are other connection options in our PiicoDev Connection Guide.
Plug your Micro:bit into the PiicoDev adapter (buttons + LED matrix facing up), connect your motion sensor to the adapter via the PiicoDev cable and connect your Micro:bit to your computer with a USB lead.
- PiicoDev_Unified.py - The PiicoDev Unified Libraries: Drives I2C communications for PiicoDev modules
- PiicoDev_MPU-6050.py - The device driver.
- main.py - an example script for this PiicoDev Sensor
It will be best to keep this file wherever you like to keep your coding projects eg. Documents > PiicoDev
Accelerometer Example
We'll be working in Thonny - if you're unfamiliar working with Thonny see our guide for Thonny and Micro:bit.
Open Thonny, connect to your Micro:bit and upload the three files. (Hint: View the files menu with View > Files)
Restart your Micro:bit (Keyboard shortcut, Ctrl+D) and you should see acceleration data streaming up the shell. Open the plotter with View > Plotter and see how the data reacts when you move the sensor.
Above: Acceleration data streams up the Shell, while the Plot shows historic data. Here the sensor is sitting flat on my desk, so the Z-axis reads about 9.8m/s^2 or about 1g.
This example plots acceleration if m/s^2. If you prefer, you can return acceleration in g by calling motion.read_accel_data(g=True)
Now, we'll perform a maneuver and observe the data. Start with the sensor laying on a level surface, then roll it so the X arrow points up, as below:
In the plot below, I've labelled the axes (x,y,z). The plot begins with my sensor sitting flat, and face-up on my desk - the Z-axis reads about 10m/s^2 and the others read zero. That makes sense, because only the z-axis is experiencing inertial forces (gravity). I then rotate the sensor so the X arrow is pointing up; we see the z-acceleration fall to zero, and the x-acceleration climb to about 10m/s^2.
Gyroscope Example
Now, we'll gather angular-velocity data from the gyroscope. In the example script, comment out the "Accelerometer Data" block and uncomment the "Gyroscope Data" block. The script should now look like this:
Data returned here is the angular velocity measured in degrees per second. Rotate about your sensor on a level surface and observe the plot:
A twist in the anticlockwise direction (positive Z) first creates a positive slope, as the twist speeds up. The slope becomes negative and falls to zero as we come to a stop. A similar shape appears when we twist to the clockwise direction (negative Z), only the data is all negative. Of course, this works in the other axes also - this is just a simple way to isolate rotation to one axis only.
Other Examples
The example script also contains a couple more examples - give them a try!
- Temperature: Read the MPU-6050's internal temperature sensor. This isn't particularly accurate, and the device may also self-heat a little - but you can do it!
- G-Force: Returns the absolute acceleration in g. Where the accelerometer example returns the acceleration components x, y, and z; this example combines the acceleration components into a single magnitude. This could be useful for detecting freefall, when g-froce is near or at zero.
