PiicoDev Magnetometer QMC6310 - Guide for Raspberry Pi Pico
Updated 13 January 2025
This guide is for the previous revision of the PiicoDev Magnetometer QMC6310 - if you have the latest revision featuring the MMC5603 - head to the guide for updated links and instructions.
Let's get started with the PiicoDev® Magnetometer. In this guide, we'll connect the Magnetometer to our Raspberry Pi Pico, get it working as a compass, and read the magnetic field strength of a nearby magnet. Finally, we'll remix the code to create a graphical compass display.
Connect the Magnetometer to your Pico
Plug your Pico into the Expansion Board, connect your magnetometer to the Expansion Board via the PiicoDev cable, and finally connect your Pico to your computer with a USB lead.
connect-piicodev-magnetometer-to-raspberry-pi-pico
Download MicroPython modules
  • Download the device module: PiicoDev_QMC6310.py (right-click, "save link as")
  • Download the example script: compass.py (right-click, "save link as" and save as "main.py")
Example 1 - Compass and Calibration
Open main.py and run the script (click the Green Play Button, or Ctrl+R). You will be prompted to calibrate the magnetometer: Slowly rotate the sensor on a flat surface until calibration is complete. You can see the calibration progress shown by a progress bar in the shell.
piicodev-magnetometer-qmc6310-calibration
Once calibration is complete, your Pico will begin printing the measured heading into the shell. This is the same heading that you would read off a magnetic compass. The heading is the direction the top edge (with the PiicoDev label) of the module is pointing when placed on a level surface like a table.
piicodev-magnetometer-qmc6310-heading-example
piicodev-magnetometer-qmc6310-heading-compare
You may notice a new file named calibration.cal has appeared on your Pico - this is the calibration data. This calibration data will be automatically loaded every time the script runs, so you can comment-out compass.calibrate() if you don't want to calibrate on every power-up. It's still a good idea to calibrate periodically, or if you notice your heading has drifted.
Remix - True North
So far we have been working with Magnetic North - this is the direction a magnetic compass will point. To find a true heading, we need to input some more information. Magnetic Declination is the difference between Magnetic North and True North (or "Geographic North"). The value for declination changes depending on location. In Newcastle, Australia, the declination is about 12° (as of 2022). There are lots of online tools that will help you find the declination in your area (here's one example). Once you know the declination in your area, you can input that angle into the setDeclination() function. Re-run your script and you should notice the heading data has been offset slightly. Your magnetometer is now indicating its measurement for True North.
Example 2 - Detect a Magnet
In this example, we'll measure magnetic-field-strength. This is useful to detect the presence of a nearby magnet. Replace the code in main.py with the following code.
magSensor = PiicoDev_QMC6310(range=3000) # initialise the magnetometer
# magSensor.calibrate()
threshold = 120 # microTesla or 'uT'.
    strength = magSensor.readMagnitude()   # Reads the magnetic-field strength in microTesla (uT)
    myString = str(strength) + ' uT'       # create a string with the field-strength and the unit
    print(myString)                        # Print the field strength
    if strength > threshold:               # Check if the magnetic field is strong
        print('Strong Magnet!')
    sleep_ms(1000)
A note about calibration: In Example 1 we performed a 2-axis calibration (rotating the magnetometer on a flat surface. For best results in this example a 3-axis calibration is necessary. To calibrate 3-axes, call the calibrate() function, and rotate the device slowly in all axes.
piicodev-magnetometer-qmc6310-field-strength
Example 3 - Raw Data
# Prints the raw axis readings in micro-Tesla
magSensor = PiicoDev_QMC6310() # Initialise the sensor (defaults to range=3000uT)
magSensor.setRange(1200)
    print(raw_data)             # Print the data
    sleep_ms(200)
Project - Graphical Compass
So far we've been using the shell to visualise information collected from the magnetometer. Now for a fun mini-project. We can use a PiicoDev OLED Module to display a digital compass-needle that always points north. The following code is really similar to Example 1, except there's extra code to drive the display, and handle drawing an indicator on the display.
To follow along with this project, you'll need to save PiicoDev_SSD1306.py onto your Pico.
# Similar to the compass example, this demo uses a PiicoDev OLED module to show a compass graphic
from PiicoDev_SSD1306 import create_PiicoDev_SSD1306, WIDTH, HEIGHT
from math import sin, cos, radians # for calculating the compass-needle co-ordinates
compass = PiicoDev_QMC6310(range=1200) # Initialise the sensor with the most sensitive range. Valid ranges: 200, 800, 1200, 3000 uT
oled = create_PiicoDev_SSD1306()
# compass.calibrate() # only need to calibrate once
# Declination is the difference between magnetic-north and true-north ("heading") and depends on location
compass.setDeclination(12.5) # Found with: https://www.magnetic-declination.com/Australia/Newcastle/122944.html
centreX = int(WIDTH/2)
centreY = int(HEIGHT/2)
# This function draws the artwork onto the OLED display. It takes a heading and draws a line at that angle from the centre of the display - along with some other nice stuff.
def drawCompass(heading):
    rads = radians(heading + 180) # convert heading to radians and offset by 180 degrees (to account for y increasing down the display)
    length = 25 # compass needle length (in pixels) from centre
    # Convert polar coordinates (length, angle) to cartesian coordinates (x,y) for plotting on display. Offset the coordinates by half the screen width/height to draw from the centre - rather than the top-left of the display.
    x = int( length * sin(rads) + WIDTH/2 )
    y = int( length * cos(rads) + HEIGHT/2 )
    # Plot the compass on the display
    oled.fill(0)
    oled.line(centreX, centreY, x, y, 1) # draw the compass needle
    oled.circ(x,y,4)                     # put a north-indicator on the end
    oled.text(str(heading),100,57)       # show the heading in the bottom-right corner
    oled.show()
    heading = compass.readHeading()
    if compass.dataValid(): # only draw for valid data - prevents errors
        heading = round(heading)
    print(heading)
    sleep_ms(100)
The drawCompass() method converts the heading into x,y coordinates that draw a line to the centre of the display. A circle is drawn on the end of the line and the heading in degrees is shown in the bottom corner of the display.
piicodev-magnetometer-qmc6310-project-pico
Above: a compass needle is animated on the OLED to point North, even if the whole assembly is rotated.
We can measure the properties of magnetic fields using a 3-axis magnetometer. Build-in functions allow us to easily measure the sensor's heading in a magnetic field, and we've even built a cool graphical compass project using an extra display module.
If you make something cool with this starter project we'd love for you to share it on our forums! And if you'd like some help with this guide, start the conversation below - We're full-time makers and here to help!
Resources
Magnetometer Library: PiicoDev Unified MicroPython module for QMC6310
OLED Library: PiicoDev Unified MicroPython module for SSD1306
compass field hall magnet
