Arduino Uno Q Explained | A Hybrid Linux and Microcontroller Dev Board
Updated 29 December 2025
In this guide, we’re taking a close look at the Arduino Uno Q — Arduino’s new hybrid development board that combines a Linux single board computer with a dedicated microcontroller. A device that feels like not just another SBC chasing higher specs, but a tool built to bridge the gap between hardware control and high‑level programming. We’ll explore what makes this hybrid setup unique, how the App Lab IDE ties everything together, and where the Uno Q fits within maker projects, robotics, and embedded development.
Let’s jump in!
Linux on an Uno?
The Arduino Uno Q is a pretty unusual entry in the Uno lineup. For starters, it’s running Linux — a full desktop environment, just like you’d find on other single‑board computers. There have been a few Arduino boards throughout the years that have been capable of running Linux, but not in a regular desktop experience like the Uno Q. This is all thanks to the onboard DragonWing processor (housing containing four Cortex‑A53 cores), as well as the 2 GB of RAM and 16 GB of storage you will find on the board. There’s also a slightly higher‑spec model if you need it, with 4 GB of RAM and 32 GB of storage.
Now, if you treat this as just another competitor in the current single-board computer "space race" to get the fastest desktop PC experience for only a few watts of power, you may be a little underwhelmed.  It’s fast enough for light tasks like web browsing, coding, or following along with an online guide, but things like YouTube playback or full desktop multitasking may test your patience if you try. However, this board doesn't feel like it was built to be a daily-driver Linux computer. It feels like it was built to be a development board that happens to be able to run Linux, and that is an important point.
A few hints give that away right out of the box. The Uno Q happily runs without a heatsink or cooler; it boots straight into the development environment, and it even includes a programmable LED matrix on the board itself. The physical design also matches the standard Uno form‑factor, so hopefully most of your existing Arduino Uno shields should fit. It also adds a Qwiic connector (always appreciated) and a set of high‑speed expansion connectors underneath for things like cameras, displays, and audio modules.
That leads us to the biggest give away that this is design moreso to be a dev board; the inclusion of a microcontroller on the board in addition to the DragonWing MPU.
The Microcontroller Hybrid
The Uno Q differentiates itself from other single-board computers by including a dedicated microcontroller right on the board. This chip is very similar to what you’d find on a standard Arduino like the Uno R4. You can write a C++ sketch, compile and upload it to the chip, and it runs it like you would normally expect it to.
So why bother adding a microcontroller when other single board computers already have GPIO pins you can control through a Python script or other user‑space libraries? Well, overall, GPIO interactions are just a bit better. The big reason is how those instructions are executed. When you interact with GPIO through a microcontroller you get deterministic behaviour. This means that when your code tells a microcontroller to do something, it does so predictably and repeatably without delays.
Running code on a single board computer, with your GPIO pins being controlled through a Linux environment, you are moreso suggesting that it should happen at a certain time. Linux might pause your code to do more important tasks like handling Wi-Fi, displaying something on screen, or memory management. This pause is unpredictable and throws off the precision of your timings a little.
Now, for most projects, this is not a deal breaker. But when you are dealing with things that need relatively accurate timing, like driving motors, reading encoders, or managing high‑speed sensors, you can start to bump into issues if you are not using a microcontroller. I have a background in embedded systems, and when I look for something to control the motors or drive system in a robotics project, I often pick a microcontroller for this reason.
You also get some really handy hardware features with that microcontroller. There’s an ADC (Analog‑to‑Digital Converter) for reading analog voltages — something most SBCs can’t do natively without an external module. And there’s even a 12‑bit DAC (Digital‑to‑Analog Converter), which means the Uno Q is capable of generating smooth output voltages or clean audio signals. Other single-board computers often need to use PWM to emulate an analog output.
So realistically, for most projects, having a built‑in microcontroller might just feel like a nice extra. But there are definitely projects in the realm of at-home makers where it may be needed, and a hybrid set-up kike this fills a neat gap between a traditional Arduino board and a full Linux system.
App Lab IDE
If the hybrid hardware is what makes the Uno Q interesting, then App Lab is what makes it actually usable, as it’s the piece that ties the Linux side and the microcontroller side together. The Uno Q is not the first single board computer to have this hybrid hardware combo, but it may be the first to make it convenient to use.
App Lab is the purpose-built IDE for the Arduino Uno Q, and it’s a little different from what you might be used to. At first, it can feel a bit strange coming from something like the classic Arduino IDE or VS Code, but once you get familiar with it, it's quite nice. You can have Python, C++, JavaScript, and even HTML and CSS all running together to make one complete project.
One of the most interesting features inside App Lab is its Bricks system. Bricks are pre‑built modules that perform specific tasks — kind of like libraries, but packaged so they can run in parallel alongside your own code. There are Bricks for things like pulling live weather data from an API, analysing text sentiment, detecting keywords in speech, and a bunch of other helpful tasks. When you add a Brick to your project, App Lab automatically sets up whatever it needs in the background — in most cases, it even runs those Bricks in Docker containers, so they’re isolated and self‑contained. Don’t worry though; you don’t have to touch Docker yourself; App Lab handles that completely automatically.
Here’s what the workflow looks like in practice. If you want any sort of hardware interactions, you will write a pretty standard Arduino sketch in C++ (the GPIO pins can only be accessed through the microcontroller). Then, on the Linux side of things, you can write a Python script to import any bricks that your project requires and perform any "Linux side of things" processing that you may wish to use.  It seems like the Uno Q was designed to host web pages for your projects (with a brick specifically for this and many of the demos incorporating this as well), so you may also need to create an assets folder to hold HTML and CSS files, as well as logos, images, fonts, and anything else you want to have on this webpage.
With all your parts ready to go, it is a single run button to have all of these different things working together. Once your project (or as App Lab calls it, an "app") is running, you can find your app's output, your microcontroller's serial monitor, and your Python shell all in one section.
It takes a little adjusting if you’re used to running everything separately, but after a bit of time with it, we warmed up to it and found it to be a good solution given how much is going on.
Now, this may all sound a little involved, and like with anything new, there is definitely a small learning curve, but it is worth knowing that there is a whole host of well-documented demo apps that ship with App Lab. We found these to be helpful in two ways: they demonstrate how to use App Lab, its file structure, as well as the Bricks (with there being a demo app for pretty much every brick), and secondly, they provide a nice starting point for making your own apps.
We managed to copy the demo app, which controls an onboard LED through a webpage and spice it up a little with a mmWave radar sensor. We took a demo app which hosted a webpage with the Brick, modified the C++ code to instead read the mmWave over UART, modified the Python code to send that mmWave data to the webpage, and then wrote some custom HTML and CSS to display it all on a neat radar visualisation you can see on the left! All in all, this took only about 20 minutes (it helps that we are familiar with all these sensors and these languages), but the demo apps provided the helpful structure for it all, as well as demonstrating how to use the bridge function. The bridge function is another lynch pin in this whole system, as it's how you pass data from the microcontroller to Linux. It is quite easy to use and reminds us of using UART code-wise.
Another thing worth talking about is running computer vision on the board. This is one of the first Arduino boards capable of running meaningful computer vision on the device itself. We have made dozens of guides at this point on getting things like YOLO object detection models going on a dozen different devices, a dozen different ways. And at the time of writing, the Uno Q takes the crown both in terms of ease of setup and ease of use. This is largely due to it being a brick within App Lab, and there being examples of it ready to go, but anything that can get a project done quicker is great. However, don't expect any crazy processing performance out of the Uno Q. Like most dev boards of this calibre, you should be expecting single-digit FPS from things like YOLO object detection models. We would like to stress, as we do in most of our computer vision guides, that this is often fast enough for most projects as you can detect if a dog is on the lawn, or if a person is in a room, or count the number of cups on a desk.
ANOTHER, another thing worth talking about is that App Lab can be used in a few different ways. You can work directly on the Uno Q itself, booting into its Linux environment and coding right there, or you can install App Lab on your main computer and connect to your Uno Q either via USB or over your local network. That last option in particular is really handy as you are able to power up your Uno Q in another room and work on it remotely from your desktop PC. One quick practical note: since the Uno Q only has a single USB‑C port, you’ll likely need a USB‑C hub (ideally a PD‑rated one) if you want to connect a keyboard, mouse, and HDMI display, or any extras like webcams and microphones.
All up, App Lab is doing something pretty interesting. It bridges the gap between embedded and high‑level application development, and it really does make it easier to build projects that span across multiple languages and hardware layers. It feels less like a simple IDE, and more like a kind of project studio built to get everything working in sync — code, sensors, scripts, and web apps, all living together on one board.
Who this is for
So, we have a bit of a unique hardware combo, with a unique workflow, through a unique IDE. What and who do we think this is for.
The most obvious use case is small‑scale robotics and other maker projects where you need both high‑level processing and low‑level control on the same board. Having a proper microcontroller alongside a Linux system means you can drive motors, handle encoders, and read sensors with precise timing, while still running Python scripts, computer‑vision models, or a web interface in the background. If you’re learning robotics or starting your first integrated project, it’s a really approachable platform that steps you into both worlds at once. There are some practical bonuses here too. The Uno Q is surprisingly low‑power — we measured around 0.5 W at idle and about 2–3 W under full load — which makes it much easier to run from a battery compared to most single‑board computers. That opens the door for portable or mobile builds, like small autonomous robots or sensor platforms.
Beyond robotics, the Uno Q also makes a lot of sense in a classroom or teaching environment. It’s simple to set up with just a single USB‑C cable to get everything powered, and a student immediately has a self‑contained system that can run C++, Python, and even host small web applications. You can teach embedded control, data processing, and web interfaces all in one place without swapping between boards and computers.
Outside of those more obvious use cases, it really comes down to the needs of your project. We use different dev boards for different reasons: some for raw speed, some for low power, some for specific I/O or wireless capabilities. The Uno Q sits somewhere in the middle as a versatile hybrid option. It might not be the absolute best board for every single task, but it can handle a much wider range than usual, from pure Python projects to pure C++ sketches, all without changing platforms.
So, is it going to be the absolute best choice of board for every project? Probably not. Will we have a few kicking around the workshop for a project that needs it? Most definitely.
Regardless of your usecase, if you are looking to get started with an Uno Q, we have a guide to get you going.
Until next time, Happy Making!
microcontroller linux overview
