Getting Started with Voltage Dividers | A Practical Guide for Makers
In this guide we will be taking a practical look at Voltage dividers - one of the most fundamental circuits in the world of electronics and this guide will hopefully be the only guide a maker ever needs to read. We will be taking a look at...
#resistors #microcontroller #voltage
Ohm's Law - Practical Examples for Makers
This tutorial is a guide to the Ohm's Law / Power cheat sheet. You may have arrived here because you received a cheat sheet with your Core Electronics order. If not, no worries! You can still follow along with the examples - we've pro...
#equation
#equation
How To Choose The Right Resistor.
Resistors are the hardworking underdogs of the electrical circuit world. You have probably added a 4.7k or 330-ohm resistor into your circuit without thinking about why we use those values, let alone what the resistor is doing. We are going...
#ohms law #power limiting #resistor
How to Use Speakers and Amplifiers with Your Project
A popular question that we get all the time is ‘How do I choose a speaker or amplifier to go with my project?’. It’s a good question, and if you’re not familiar with the terminology, it can seem a bit daunting to kno...
#analogue #amplifier #audio #mono #music #speaker #stereo
Addressable RGB LED strips are one maker favourite that can really spruce up any project or even be the star attraction of one. These strips allow you to select the colour, brightness and state of any LED in a long strip and can make for ...
If you’ve ever built a robot with wheels, or any motorised parts really, you’ll have come across the issue of needing to drive it from your microcontroller. Because a standard chip is only able to output a small amount of curren...
Using Copper Tape with Paper Circuits
What is a Paper Circuit? STEM technology has evolved into all kinds of fantastic forms with many brands bringing craft and electronics together in new and innovative ways. There’s plenty of products which make use of ‘paper cir...
#circuit #copper #craft #paper #tape #wearable
Our tips for Coin Cell Batteries
Firstly, what are Coin Cell Batteries? A coin cell battery is a flat, cylindrical battery used in a bunch of small electronics applications. You might have seen them in a wristwatch, remote control or any piece of wearable tech. Typically ...
#batteries #button cell #coin cell #coin cell holders
As technology gets smaller and more powerful, wearables and portable devices are becoming more common in our everyday lives. Makers are looking to make projects portable and with that comes the need for high capacity batteries that are reli...
Our tips for using NiMH Batteries
NiMH is an abbreviation for Nickel-Metal Hydride. NiMH batteries are some of the most common rechargeable batteries we see in consumer electronics. Due to their superior chemistry, NiMH batteries have taken over Nickel Cadmium Battery appli...
#batteries #nimh #charging
Snap Circuits makes Electronics Fun and Educational
From breadboarding to soldering, the way we connect our components is critical to ending up with a working circuit. Before the new-age tech startups like littleBits and innoBits came along with their magnetic clip-together building blocks, ...
#educational #kits #snap circuits
So, you might have the best project in the world, an amazing idea and design, but no matter how clever your circuitry or how advanced your prototype is, unless you can power your project correctly, it all counts for nothing. Often you will ...
All About Electrical Switches
On and Off. It’s the basis for all electronics, from the most sophisticated computer network to a simple circuit. Electronics is all about using one thing, to control another, input and output, on and off. Even the transistors inside ...
Power Supplies for your Project
Ever had the issue where you have dozens of old phone chargers and appliance plug packs piled up in a rats nest of AC-to-DC mayhem? We tend to breeze right past these square, black power supplies, not knowing what's happening under the hood...
#ac dc #dc dc #plug pack #power supplies #wall wart
Our tips for using LiPo Batteries
Lithium Polymer (abbreviated LiPo) batteries are one of the most useful cells we see used in electronics. Typically used in mobile phones, RC models, and other small electrical appliances; their flat, pouch-like package design makes them pe...
#lipo #charging #powerboost #safety
Want to make your project portable? We've put together a quick guide to get you up to speed on battery options and help you decide which batteries might be best for your project. Batteries are a whole different game to plug packs and bencht...
All About LEDs
Hello and welcome to our tutorial where we a look at all things LED. Now first of all, what is an LED? LED stands for Light Emitting Diode and is an electronic component used to convert electrical energy to light energy. This process is cal...
#electronics #led #component #diode
Analog Electronics Crash Course
Welcome to our beginners tutorial on analog electronics. Living in the digital age that we do, it’s easy to disregard the world of discrete analog components, however these concepts form the basis for everything from your mobile phon...
#analogue #capacitors #diodes #resistors #transistors
