Light up your wearable projects with our range of LEDs and accessories, perfect for creating illuminated clothing, gadgets, and fashion statements.
Items 26-50 of 65
  1. Single-Ended Flexible LED Filament - 3V 25mm long - Cool White
    SKU: ADA6139 Brand: Adafruit
    This flexible LED filament is often seen in 'Edison-like' LED bulbs, arranged in different patterns to give a bright warm lighting effect....
    Available with 8 to 12 day lead time
  2. Single-Ended Flexible LED Filament - 3V 25mm long - Natural White
    SKU: ADA6144 Brand: Adafruit
  3. Single-Ended Flexible LED Filament - 3V 25mm long - Warm White
    SKU: ADA6141 Brand: Adafruit
    Delivered by Aug 28th
  4. Single-Ended Flexible LED Filament - 3V 25mm long - Red
    SKU: ADA6140 Brand: Adafruit
  5. Single-Ended Flexible LED Filament - 3V 25mm long - Green
    SKU: ADA6145 Brand: Adafruit
  6. Single-Ended Flexible LED Filament - 3V 25mm long - Pink
    SKU: ADA6142 Brand: Adafruit
  7. Single-Ended Flexible LED Filament - 3V 25mm long - Blue
    SKU: ADA6143 Brand: Adafruit
  8. Single ended nOOds - 128mm long Flexible LED Filament - Pink 3V
    SKU: ADA6138 Brand: Adafruit
    Our favorite food when hacking on code or electronics is a hot bowl of noodles - and around NYC these are often called 'noods'! What we've got...
  9. Single ended nOOds - 128mm long Flexible LED Filament - Natural White 3V
    SKU: ADA6137 Brand: Adafruit
  10. Single ended nOOds - 128mm Flexible LED Filament - Ice Blue 3V
    SKU: ADA6136 Brand: Adafruit
  11. Single ended nOOds - 128mm long Flexible LED Filament - Red 3V
    SKU: ADA6132 Brand: Adafruit
  12. Single ended nOOds - 128mm long Flexible LED Filament - Warm White 3V
    SKU: ADA6135 Brand: Adafruit
  13. Single ended nOOds - 128mm long Flexible LED Filament - Cool White 3V
    SKU: ADA6133 Brand: Adafruit
  14. Single ended nOOds - 128mm long Flexible LED Filament - Green 3V
    SKU: ADA6134 Brand: Adafruit
  15. Single ended nOOds - 128mm long Flexible LED Filament - Blue 3V
    SKU: ADA6131 Brand: Adafruit
  16. Single ended nOOds - 300mm long Flexible LED Filament - Warm White 3V
    SKU: ADA6154 Brand: Adafruit
  17. Single ended nOOds - 300mm long Flexible LED Filament - Pink 3V
    SKU: ADA6152 Brand: Adafruit
  18. Single ended nOOds - 300mm long Flexible LED Filament - Green 3V
    SKU: ADA6151 Brand: Adafruit
  19. Single ended nOOds - 300mm long Flexible LED Filament - Red 3V
    SKU: ADA6150 Brand: Adafruit
  20. Single ended nOOds - 300mm long Flexible LED Filament - Blue 3V
    SKU: ADA6149 Brand: Adafruit
  21. Single ended nOOds - 300mm long Flexible LED Filament - Cool White 3V
    SKU: ADA6148 Brand: Adafruit
  22. Single ended nOOds - 300mm long Flexible LED Filament - Natural White 3V
    SKU: ADA6146 Brand: Adafruit
  23. 3V 260mm Flexible LED Filament Chip (Blue)
    SKU: FIT0810 Brand: DFRobot
    This flexible LED filament Chip comes with a diameter of 2mm and a length of 260mm. The small round hole end is the positive electrode, and the non-porous end is...
  24. 3V 260mm Flexible LED Filament Chip (Green)
    SKU: FIT0809 Brand: DFRobot
    1 from local stock, 1 supplier stock; your order will dispatch between Dec 1 to Dec 10. And yes, stock levels and lead times are accurate!
  25. Multi-Function LED Headband Torch
    SKU: AX0204 Brand: Core Electronics
    This multi-function LED head torch features front and rear-mounted lamps for giving Maker tasks more light where right where you are looking, great for soldering or looking through project boxes for that pesky microcontroller you know you bought in 2017.
    Available with 4 to 6 day lead time
