Reflectance sensors are essential for projects involving line following, obstacle detection, and surface detection, providing accurate readings for robotics and automation.
Items 51-75 of 104
  1. QTR-MD-02A Reflectance Sensor Array: 2-Channel, 8mm Pitch, Analog Output
    SKU: POLOLU-4242 Brand: Pololu
    This array of IR LED/phototransistor pairs is great for precisely identifying changes in reflectance (like line detection). It operates from 2.9 V to...
  2. QTR-MD-02RC Reflectance Sensor Array: 2-Channel, 8mm Pitch, RC Output
    SKU: POLOLU-4142 Brand: Pololu
  3. QTRX-HD-03A Reflectance Sensor Array: 3-Channel, 4mm Pitch, Analog Output, Low Current
    SKU: POLOLU-4403 Brand: Pololu
  4. QTRX-HD-03RC Reflectance Sensor Array: 3-Channel, 4mm Pitch, RC Output, Low Current
    SKU: POLOLU-4303 Brand: Pololu
  5. QTR-HD-03A Reflectance Sensor Array: 3-Channel, 4mm Pitch, Analog Output
    SKU: POLOLU-4203 Brand: Pololu
  6. QTR-HD-03RC Reflectance Sensor Array: 3-Channel, 4mm Pitch, RC Output
    SKU: POLOLU-4103 Brand: Pololu
  7. QTRX-MD-03A Reflectance Sensor Array: 3-Channel, 8mm Pitch, Analog Output, Low Current
    SKU: POLOLU-4443 Brand: Pololu
  8. QTRX-MD-03RC Reflectance Sensor Array: 3-Channel, 8mm Pitch, RC Output, Low Current
    SKU: POLOLU-4343 Brand: Pololu
  9. QTR-MD-03A Reflectance Sensor Array: 3-Channel, 8mm Pitch, Analog Output
    SKU: POLOLU-4243 Brand: Pololu
  10. QTR-MD-03RC Reflectance Sensor Array: 3-Channel, 8mm Pitch, RC Output
    SKU: POLOLU-4143 Brand: Pololu
  11. QTRX-HD-05A Reflectance Sensor Array: 5-Channel, 4mm Pitch, Analog Output, Low Current
    SKU: POLOLU-4405 Brand: Pololu
  12. QTRX-HD-05RC Reflectance Sensor Array: 5-Channel, 4mm Pitch, RC Output, Low Current
    SKU: POLOLU-4305 Brand: Pololu
  13. QTR-HD-05A Reflectance Sensor Array: 5-Channel, 4mm Pitch, Analog Output
    SKU: POLOLU-4205 Brand: Pololu
  14. QTR-HD-05RC Reflectance Sensor Array: 5-Channel, 4mm Pitch, RC Output
    SKU: POLOLU-4105 Brand: Pololu
  15. QTR-HD-31RC Reflectance Sensor Array: 31-Channel, 4mm Pitch, RC Output
    SKU: POLOLU-4131 Brand: Pololu
  16. QTR-HD-31A Reflectance Sensor Array: 31-Channel, 4mm Pitch, Analog Output
    SKU: POLOLU-4231 Brand: Pololu
  17. QTRX-HD-31RC Reflectance Sensor Array: 31-Channel, 4mm Pitch, RC Output, Low Current
    SKU: POLOLU-4331 Brand: Pololu
  18. QTRX-HD-31A Reflectance Sensor Array: 31-Channel, 4mm Pitch, Analog Output, Low Current
    SKU: POLOLU-4431 Brand: Pololu
  19. QTR-MD-01RC Reflectance Sensor: 1-Channel, 7.5mm Wide, RC Output
    SKU: POLOLU-4141 Brand: Pololu
    This IR LED/phototransistor pair is great for precisely identifying changes in reflectance (like line detection). It operates from 2.9 V to 5.5 V and...
  20. QTR-MD-01A Reflectance Sensor: 1-Channel, 7.5mm Wide, Analog Output
    SKU: POLOLU-4241 Brand: Pololu
  21. QTRX-HD-01RC Reflectance Sensor: 1-Channel, 5mm Wide, RC Output, Low Current
    SKU: POLOLU-4301 Brand: Pololu
  22. QTRX-MD-01RC Reflectance Sensor: 1-Channel, 7.5mm Wide, RC Output, Low Current
    SKU: POLOLU-4341 Brand: Pololu
  23. QTRX-HD-01A Reflectance Sensor: 1-Channel, 5mm Wide, Analog Output, Low Current
    SKU: POLOLU-4401 Brand: Pololu
  24. QTRX-MD-01A Reflectance Sensor: 1-Channel, 7.5mm Wide, Analog Output, Low Current
    SKU: POLOLU-4441 Brand: Pololu
  25. QTRXL-HD-01RC Reflectance Sensor: 1-Channel, 5mm Wide, RC Output, Long Range
    SKU: POLOLU-4501 Brand: Pololu
