Slim Case for the Arduino Uno Assembly
Updated 24 May 2019
Our Slim Case for the Arduino Uno allows you to keep your Arduino safe and protected from damage or shorts, while still allowing access to all the pins! In this guide, we will show you how to assemble your new Slim Case. Every Slim Case for the Arduino Uno was designed and manufactured by us right here in Newcastle!
Render of the Slim for Arduino Uno Case Exploded
Unwrapping
The slim case will come wrapped in a small bundle, and all the layers will be covered in paper. Remove the paper from the panels. There is a paper peeler included with the case to help get the corners started.
Packaged slim for arduino uno
Layer One
Start with the bottom layer, the engraved recesses for the nut should face down.
Layer one of the slim for arduino uno
Black Layer
The next layer is the black layer, line up the outside profile with the bottom layer.
slim for the arduino uno black layer
Add Arduino!
Drop in your Arduino.
slim case for arduino uno assembly with uno
Thin Layer
Add the thin surrounding clear layer.
slim case for arduino uno middle layer
Almost Top Layer
This layer has no engravings around the bolt holes and has an oval-shaped hole for the crystal.
Slim case for arduino uno assembly almost top layer
Top Layer (Finally!)
Fit the top Layer, this has the engravings for the screw heads.
Slim for the arduino uno top layer
Tighten it Up
Insert the screws from the top.
Slim case for the arduino uno with screws
Position nuts in the recesses on the bottom of the case, and tighten the screws lightly.
Slim for arduino uno nuts in place
Finished
Slim case for the arduino uno assembled case
Now that you have completed your case, its time to get started with your Arduino! Check out our Arduino Online Workshop for everything you need to know about using your Arduino!
arduino case assembly slim case arduino uno case slim slim case for the arduino uno slim for arduino uno
